Outlaw Opel Omega STW, world's fastest megasquirted car ?
Re: Outlaw Opel Omega STW, world's fastest megasquirted car
Postby paw » Thu May 09, 2013 12:43 pm
Outlaw Opel team finally went into the MS3 world, hooray :)
Here's a videoclip from last Saturday night, first start with MS3 : http://www.youtube.com/watch?v=BW0KPIcUGFM
The drag racing season start is getting closer...Let's see how close we can get to the 7.5sec class index.
paw
Postby paw » Sat Jun 29, 2013 1:34 pm
Now we are talking !
Yesterday the Outlaw Opel shattered the team's previous quartermile record with a 7.562 sec / 289.68 kmh (179.92 MPH) run !!! YEAH !!
Very close to the Outlaw class limit of 7.500 sec, and # 1 in the qualifications :)
And still power in reserve, the best trap speed yesterday was 294.6 kmh (182.98 MPH)
Looking good for the eliminations tomorrow, and a week from now it's the European Championship Event (with National Championship as well) on the same track as this weekend (Alastaro Circuit in Finland)
Hopefully I will get some in-car footage for you soon. s*** happened, on that record run the datalogging didn't work :( Otherwise I would have included the datalogging gauges to the in-car video.
Here's at least a still photo : https://fbcdn-sphotos-f-a.akamaihd.net/ ... 9433_o.jpg
paw
Postby paw » Tue Jul 02, 2013 5:03 am
Here's the 7.562sec record run in-car video : http://www.youtube.com/watch?v=do9JwmSFSnY
paw
Postby paw » Mon Jul 08, 2013 8:38 pm
paw
Postby paw » Fri Jul 19, 2013 1:19 pm
In-car video of the wheelie : www.youtube.com/watch?v=fdS4zZ_JTUA
paw
Postby HidRo » Fri Jul 19, 2013 1:26 pm
d***!! That has to have some serious power to it :) Congrats :yeah!:
HidRo
Postby paw » Mon Oct 14, 2013 2:29 am
Updated specs ! (finally)
Car:
• 1995 Opel Omega STW MV8
Engine:
• 531CID (8.7L) Big Block Chevy
• Bore 4.6” , Stroke 4”
• Block : DART Big M BBC
• Crankshaft : Callies
• Connecting rods : Callies Ultra. Length 6.385”
• Pistons : CP. Compression ratio 10:1
• Camshaft : Comp Cams mechanical roller camshaft
• Cylinder heads : Pontiac Motorsport Severe Duty cylinder heads, 2.35” intake, 1.9” exhaust
• Damper : ATI Super Damper
• Intake manifold : Edelbrock single plane intake manifold. Custom 100mm throttle body
• Fuel system : Magnafuel (mechanical fuel pump, filter, regulator)
• Headers : 2 3/8” / 4 ½”
• Ignition : MSD Pro Billet distributor, MSD 7AL-3, MSD Pro Coil
• Supercharger : Vortech V4-“SR” centrifugal supercharger, about 1.1BAR (16PSI) boost
Engine Management System:
• Megasquirt 3 fuel injection and ignition control
• 1600cc Injectors
• 10BAR fuel pressure sensor
• Innovate Motorsport LC-1 Wideband O2
Fuel :
• E85 Ethanol
Drivetrain:
• Powerglide with transbrake
o BTE 1.80 Straight Cut 1:st gear
o 10 clutches
• Prism style rear axle
o Strange 9” Ultra case, steel spool and 3.9:1 gears
o Strange drive shafts
• 16 x 33” rear slicks
• Weld Racing Alumastar wheels
o Rear 15” x 15”
Chassis:
• CrMo tube chassie made according to SFI 25.1E rules
• 108” wheel base
• CrMo 4-link and wishbone
• Strange front struts and rear shocks
Performance:
• Best ET 2013 : 7.562sec / 289.68 KPH (179.92 MPH). Class index 7.500sec
• Best trap speed 2013 : 296 KPH (184 MPH)
paw
Postby paw » Fri Nov 01, 2013 4:52 pm
Here's an "outside" videoclip of the wheelie run : http://www.youtube.com/watch?v=gbb-PcGsy9M
On the other lane is an old Opel Ascona A Voyager with a 4 cyl billet block ! That car ran into the 7's this year for the first time! That Ascona has a loooong history in the same family. And the craftmanhip done to that Ascona is amazing!
For 2014 season for the Opel Omega...nothing big...Engine stays the same, basic maintenance, just adding a shaft speed sensor to get the torque converter slip and maybe new injectors etc misc stuff. Maintenance on the PG gearbox and replacing the casing. Chassis upgrades, moving the weight balance a bit more backwards etc. The upgrade "specs" may get a little more detailed during the winter :P
paw
Postby paw » Sat Nov 16, 2013 6:17 pm
Here's a 2013 compilation video, done by a friend of mine. I'm not quite sure if this is the final version, but here we go anyway : http://speedhunters.pic.fi/kuvat/Someti ... g+2013.mp4
Hope you guys like it!
paw
Postby paw » Sun Jul 10, 2016 8:27 am
It's been awhile since the last post. Nothing really extraordinary has happened, the former Outlaw class with its 7.500sec class limit changed to Pro Street class and 7.600 class limit so we had to slow down the car just a bit.
Other than that we added a 8ch EGT to the MS.
Here's an onboard video clip from this weekend's European Championship event : https://www.youtube.com/watch?v=yz6oY5V5PbU
paw
Postby paw » Fri Oct 28, 2016 12:50 pm
So...The 2016 season ended pretty well, second place in the National Championship!
We're ditching the well-served old Vortech supercharger and going to a tiny little turbo for the 2017 season!
For the Megasquirt, mods for boost control, exhaust backpressure measurement, turbo staging etc
With the same exact turbo a fellow racer in another class has gone 6.7secs @ 332KPH (206MPH) with a small block chevy engine
But at least for 2017 we are still staying in the same class as before which has a class limit of 7.6secs
A few pics of the first turbo mockups. Yes it's still a 531ci big block chevy engine. Might look a bit small. The engine plate with the old supercharger fixing points is still there :
paw
Postby paw » Sat Dec 10, 2016 4:31 pm
Driver's side turbo header tack welded, had to snake around the steering shaft. Primary tube length difference is 5mm (0.2 inches) :D
TODO for the ECU : 2 additional EGT measurements, 1 exhaust backpressure measurement, 1 driveshaft RPM, 1 boost control output
paw
Postby paw » Sun Dec 18, 2016 7:11 am
Passenger side turbo header tack welded for the first 3 tubes...
paw
Postby ol boy » Sun Jan 08, 2017 3:57 pm
Turbos solve everything. I'm sure you might end up in the high 6's with out much effort.
306 SBFord, Torquer II EFI intake, 60 lbs injectors, 8 LS2 coils, VS Racing 7668 turbo, 4R70W, MS2extra 3.4.x_ish
ol boy
Postby paw » Sun Feb 12, 2017 10:35 pm
Turbo exhaust plumbing done...
paw
Postby paw » Sun Apr 09, 2017 11:27 pm
Engine finally back in, headers DIY thermal coated
paw
Postby paw » Fri Apr 28, 2017 2:52 pm
A clip from last autumn : Garage wamump with a bit of throttle blipping at the end : https://www.youtube.com/watch?v=w6vujmVaArc
paw
Postby HidRo » Sat Apr 29, 2017 5:44 am
That is one hell of a taxi :P Good work!
HidRo
Postby paw » Sun May 14, 2017 10:14 pm
It's alive! Yesterday midnight was the first start ever with the turbo, after tackling some "minor challenges" throughout the day
Here's a clip : https://www.youtube.com/watch?v=BadmEcGeuRs
Still a ton of details left and get the darn thing retuned.
paw
Postby R100RT » Sun May 21, 2017 6:32 pm
Very nice workmanship on your manifold plumbing - I didn't notice if you mentioned what material spec you went with?
I prefer 321SS for high heat zones (Burns has good stock on mandrel bends most sizes & doesn't break the bank). As you most likely know, if using lighter gauge, lower grades can suffer from the dreaded "intergranular" corrosion issues and turning into fragments.
Looking forward to following your successes
1983 BMW R100RT Bike
Turbocharged - Water Injection
Sequential Ignition is great
"Perky Sleeper"
New toy - 1995 BMW K75 is on "The Mod Table", another V2 vintage Microsquirt kit'n caboodle ready to add, turbocharger in process, all the "usual suspects"
R100RT
PreviousNext
Return to Success stories
