MS3Pro, 2jz dyno results Volvo 940
tutuur
Re: MS3Pro, 2jz dyno results Volvo 940
Post by tutuur »
How is your car doing today buddy?
nathaninwa
Post by nathaninwa »
The car is running fantastic! Only 3 issues. Slight idle oscillation when settling into close closed loop. Small initial value change needed in the iat/idle table and 4th gear cruise around 1500/1600rpm I get some weird leaning going on that causes just a little surging. I bet it's the cams that cause this the most
Other than that, keeping it low key as a friend and I are driving it to the megameet
matthunter1448
Post by matthunter1448 »
Hey did you ever get a chance to look at the wiring for the crank and cams my engine is mounted and ready to wire
nathaninwa
Yes, cam sensor ground is on the firewall side, that's the side with hump in it for clocking it correctly. The same hump position is ground for the crank sensor
matthunter1448
nathaninwa wrote:Yes, cam sensor ground is on the firewall side, that's the side with hump in it for clocking it correctly. The same hump position is ground for the crank sensor
Thanks so much man which iac are u using?
nathaninwa
Gm air and coolant temp. I tried Toyota coolant but found trying to get the scaling correct was tough, so I swapped to gm
matthunter1448
nathaninwa wrote:Gm air and coolant temp. I tried Toyota coolant but found trying to get the scaling correct was tough, so I swapped to gm
No I meant idle air control I'm using the GM sensors too
nathaninwa
I tried my best to use the Toyota stepper motor, just had a hard time with it. Moved over to a Pwm motor from a mustang and absolutely happy with the results and actually recommend and only install the Pwm on any setup I'm involved with
Heck, I'm building an LS3 and modded the the throttle body to setup for a Pwm motor!
matthunter1448
which pwm valve is it the fox bodY?
nathaninwa
Yes, but I have used ranger and f150's as well from the 90's era
matthunter1448
cool ill look into those as well
tutuur
Post by tutuur »
Isn't the leaning caused by the injectors going non linear?
Wonder if MS has a function of minimum pulse width these days?
Better to have it running a bit too rich than to have it stalling because it's lean!
nathaninwa
I'll capture a lot of this over the weekend. The main reason I suspect cam reversion is while cruising in 6th I can rpm down into the 1500/1600 region at around 45/50mph and I can hear some funniness in the exhaust
tutuur
Post by tutuur »
Hhhmmm that's s***, can't someone drive a 900bhp car daily these days? :lol:
matthunter1448
where did you end up tapping for the gm coolant sensor?
nathaninwa
I put the sensor in the upper water neck like the stock. If have to look, I bet I welded a 3/8 fitting in place of the stock threads
matthunter1448
Got it the stock hole is 12 x 1.5 mm. And the GM sensor is bwd. Wt5132. Is the part number
nathaninwa
That's like the new sensor thats in the LS motors? Very good info
matthunter1448
nathaninwa wrote:That's like the new sensor thats in the LS motors? Very good info
Believe so yes. Worked great so far. Will find out more when I get the engine started in the process of wiring Image
nathaninwa
Looks like your making progress. I'm actually mid wire on an LS3 swapped 240Z I'm building and from what I have read, that sensor carries the same resistance as the older pipe plug setups
