this is a ms2v3 on a peugeot 106 1600 16v eu2,using a diy bob,to connect the stock wiring harness.
stock ecu was a marelli 1af 55 pin.
pin1AF MEGASQUIRT
1 iniettori1-4
2 iniettori2-3
3 iac1b
4 massa sensori,sensor ground
7 rele pompa,fuel pump relè
16 +5v map esterno,ext map 5v
17 massa rele iniezione,connect to ground
20 iac2b
21 iac2a
22 lambda in
23 tps in
29 air temp
30 massa ecu,ecu ground
34 +5v tps
35 +12v
36 massa potenza,power ground
37 coil 2-3
40 iac1a
42 tacho ,contagiri
47 coolant temp.
49 +sensore giri trigger,vr in
52 massa sensori,sensor ground
53 massa potenza,power ground
54 massa potenza
55 coil 1-4
hope it is a good help for forum people.
trigger is a 60-2 120 degress btdc.
http://www.youtube.com/watch?v=dUjCHbiSb54
peugeot 106 gti,rally
Re: peugeot 106 gti,rally
Good for 106 Rallye ?
This is great help !!
97 1.8T DIYPNP Seq Inj
http://megamiata.blogspot.co.il/
hi nice job. I have same engine in Saxo 16V Eu2.
I think trigger wheel is TDC 114° not 120°
can you upload msq?
can you upload msq?
Yes, it would be very helpful if you upload your .msg.i am trying to start my car these days!!
I'm use to build many ECUs for this kind of cars :
http://boutique.fenixecu.com/peugeot/16 ... 6-16s.html
Motor is TU5JP4 (NFX). I'm curious about the wiring krisstek gave since it doesn't match what I use (and that works).
i.e. :
17 is a sensor ground for MAT and MAP
52 is a transistorized ground that close the main relay which power the ECU
and so on. So I guess there are several wiring available for this car ?
Also, trigger offset if 114°btdc. Checked with a timing light on many cars.
Regards,
Manu
i.e. :
Regards,
Manu
