Toyota AE70 Corolla - 4AGE 20V - MS3X
General talk about successes. See older information on MSRUNS forum.
suberimakuri
Post by suberimakuri »
ECU Setup:
MS3 + MS3X.
Percent Baro Fuel Table 1 - multiplicative, (later when add turbo need for boost control).
AN Fuel Table 2 - main load table.
multiply map off.
AFR Table TPS, with Table Blend on kPA enabled. 0-105 AFR1, 105-250kpa AFR2.
Percent Baro Ignition Table 1 - additive - includes +10 deg below 100kpa, -ve numbers over 150kpa.
AN Ignition Table 2 - main load table.
Second baro on JS7
FIDLE radiator fan control.
Oil Pressure on EGO2.
Launch control/flat shift.
Check Engine Light.
MS3extra code 1.3.4.
Engine Setup:
4AGE Blacktop 20v block and head (block to later swap to 8.9:1 ZE)
Coby extractors (to later swap to exhaust manifold with T4B Knightsports Turbo)
1NZFE COP on MS3X outputs.
Factory tacho working thanks to Jondee86. Relay with +12v on 85, MS3X tacho out plus dash tacho connected to 86. 30/87 cable tied closed. MS3X grounds relay each rpm allowing 12V to spike through to dash. http://www.adaptronic.com.au/forum/inde ... 2034;image
550cc MR2 3SGTE injectors, sequential.
suberimakuri
Re: Toyota AE70 Corolla - 4AGE 20V - MS3X
First circuit day out, engine flawless all day.
Short video of one run.
https://www.youtube.com/watch?v=gwOxhslZmZU
BigLou240sx
Post by BigLou240sx »
Very cool! Just about to kick off my season as well.
ae86drftr
Post by ae86drftr »
HELL YEA!!!!!!! Nice vid man! I am just about to start my build hopefully this weekend if it gets here by then! SO EXCITED to get this running again!
Wubba Lubba Dub Dub!!! oh. yea...
1985 Toyota Corolla 20V 4AGE MS3X Seq. Fuel/Spark...
1990 Eagle Talon TSi AWD 4G63 MS3X Seq. Fuel, Batch Spark...
