- Camry +1998 5S-FE (2.2L) block, crank & oil-pump
Caldina ST215 head, intake manifold, TPS & idle control servo
GSC 268 cams
CP forged pistons 10.5:1 CR
Celica ST205 exhaust manifold
Celica ST205 CT20b (CT26c2) turbo
ID1000 injectors on custom rail
PWM controlled Walbro 255lph fuel pump
Caldina ST215 COP's
MS controlled PWM CL boost valve
- Camry 5S-FE crank position VR sensor (using Caldina ST215 crank pulley/tooth-wheel)
Caldina ST215 cam position VR sensor
Caldina ST215 MAP sensor
GM intake air, coolant, oil temp sensors
Caldina ST215 TPS
GM FlexFuel sensor
Innovate LC-1 WB02
GM oil, fuel pressure sensors
Factory hall effect gearbox speed sensor
X,Y,Z accelerometers (on TinyIOx inputs)
Currently running FW 1.3.3
