This entire project isn't quite done yet but my part of is close enough that it's time to call it success.
What it is: Custom trike with a 2005 Pontaic Sunfire powertrain.
What it's got: 2.2L Ecotec engine with the factory Ion sense ignition. Being controlled with an MS3-Pro.
Hydramatic 4T40E automatic transmission. Being controlled with a V3.0 Microsquirt running James' transmission firmware.
AIM MXL Strada Dash for driver info.
All 3 units are tied together on the CAN bus. I did have to remove R18 ( CAN bus terminating resistor) from from the uS. The uS gets RPM, ECT and TPS from the 3-Pro. The 3-Pro gets VSS from the uS and the AIM gets it's data from the 3-Pro.
Custom Trike with multiple controllers and CAN Dash
Support the developers!
Re: Custom Trike with multiple controllers and CAN Dash
Some pictures.
Some notes of interest:
According to the factory service manual the alternator is PCM controlled. I set things up to have the 3-Pro do just that and used a 1K pull-up between the control and turn on wires so that I could..... And found that I didn't need to. The system charges at a very stable 14.2V just with the pull-up installed and alternator control turned off.
The Ion sense waste spark ignition works fine with the 3-Pro logic level spark drivers (going high) and standard dwell AND it provides a perfect cam signal for sequential fueling.
GM automatic transaxles have the VSS at wheel position not driveline position.
A 10K resistor is needed across VR+ and VR- on the 3-Pro to prevent sync loss above 2500 using the stock CKP and GM 7X decoder.
The 2 msqs
This is cool from the electronics side and everything you got it to do, but man alive that's the goofiest looking transportation device I have seen in a long time! Can't imagine investing the kind of money I'm sure that thing has in it!
Great Job getting everything working!
Andrew
Andrew
I have the same MXS strada. The vehicle speed is from ABS sensor, in tuner studio I can see the speed but in the dash no. In race studio appears MS3_SPPED1 (the ecu is ms3 pro ultimate) but I have not been able to see the speed in the dash.
How is the configuration of your dash?
Thanks!
Thanks!
- Attachments
- unnamed.png (448.46 KiB) Viewed 1368 times
- unnamed.jpg (86.58 KiB) Viewed 1368 times
- unnamed (1).jpg (57.38 KiB) Viewed 1368 times
