MK2 Golf 1.8t Drag car
Postby Carlg » Mon Dec 22, 2014 6:00 am
Hi here is my mk2 20vt golf running on ms2 extra.
Below is a thread i started on our closed VWDRC Forum covering my first year, sorry if it rumbles on a bit lol......
Well now that my racing is finished for the year I suppose its time for me to start a build thread for my car, this season has been really fun and I plan to race next year too.
I started building the car two years ago mainly because I fancied building a fast car and the old commuter car was sat in a corner of a barn and i had tried to sell it but failed....
I then built the first incarnation using an AGU engine from a A3 1.8t I bought as a runner.
the first spec of the car was
Bone stock AGU
stock k03 turbo
020 td mk3 box
new stock 8v clutch - more on this in a minute
all running on megasquirt ms2 extra
using the stock 8v mounts (note don’t do this)
intercooler that i picked up new for £10 from an autojumble (bmw one)
Qpeng 2.5 inch downpipe into a reducer into the stock exhaust
everything else was stock....
I then went to big bang 2013 and did 27 runs and netted a best of 14.7 (correction found a timming slip for a 14.4 :D )which i was quite impressed with, on road tyres - only removed passenger seat and rear seat and anything that wasn’t needed....
I then drove home fine then on my way to maplins to pick up a couple of switches etc the golf spun 5th gear so the box was changed to the old 8v box (not a good choice for this conversion btw)
The next event I went to was Apex festival after putting some track tyres on (federal 595 RSR) my ronal turbos (they are silly heavy though :( )
note the black wanger in the background!!
I was having fun however the engine mounts had the cam wheel too close to the master cylinder and round left hand bends when driving enthusiastically it would hit and make a really horrid noise, I found that I could make it not hit by wheel spinning round the corner.
I did about 40 minutes of track time but had to retire due to a slipping clutch, I only just managed to drive it home (needed help and got pushed up the hill from the paddock :? ) once I took the clutch out i was greeted with this
I then decided to upgrade to a 02a box with a g60 style flywheel (vr6 clutch) this normally requires a conversion to a hydraulic clutch however certain seats used a cable mech for the clutch, I found a seat toledo TDI (mk1) for sale for scrap money so i picked that up took the gearbox flywheel clutch cable and gear linkage. i also took the front cross member (mk3 style mount)
Whist i had all of this out i also changed the subframe for a mk3 cabrio that my dad was scrapping also fitted the front brakes (256mm) and tried to fit the widetrack mk3 setup however the cabrio was a auto and I didn't have the longer mk3 manual driveshaft’s to I fitted new mk2 wishbones (the extra width is in these) I also used the mk3 power steering rack which now needed the mk2 arms fitted (width again) I used all the Toledo engine mounts
Once the car was back together I realised that I had no compression on no 4 looking at the logs I had over revved the engine to about 8k so rather than messing about I wanted more power so I found an early s3 engine (apy) without the ecu so next up was a new downpipe this time from trackslag for the K04 engine still with the reducer and the 8v exhaust, a few tweeks to the map (mostly for the bigger injectors) and she ran on the maiden test drive I found that my fuel pump was not good enough (stock digifant) and I burnt a valve changed the valve and on the first run up it dropped the new valve (apparently they can do this if fitted incorrectly :( ) this killed the S3 enigne ...
****ed off I bought another AGU engine for a couple of hundred, fitted all of the s3 parts and got her running again on a mk2 16v fuel pump
BUG JAM 2013:
I took the golf and managed a few low 14's then got a 13.5 also got this awesome pic
I was also talked into racing next year, but I was struggling to decide if to run in sportsman or pro ....
over the winter I fitted a full 2.5 inch trackslag exhaust and Rob Judge fitted my cage after I stripped the interior out, he did an awesome job with a very quick turnaround (dropped the car off and picked it up a week later) it’s also been tagged down to 10 (the tech guy said a 8.5 will be no
problem :) ) I also picked up a wizards of nos nitrous kit off an old drag car, also bought a set of 22-8-15 inch slicks used. oh and a big ish holset turbo
my dad then painted it (twice) - Thanks dad
over winter I found an issue that occurred twice if I didn't limit the boost down low on a hill the stock rods would end up like this:
I bought a set of IE Rods off the shelf and fitted them to the first engine that I bent rods in it ran fine however it smoked badly, as I had honed the bores and fitted new rings I thought I had made a mistake, so I bought a cheap (£200 delivered) set of eBay rods which arrived next day fitted them to the other engine I bent rods in and still had the same issue, turns out that the turbo was dying, sent off for a rebuild whist the K04 was off I decided to take this pic showing the new turbo next to the K04
then came Big Bang 2014....
had a rubbish time it ran ok until about mid track then would misfire badly my pb over the weekend was a 13.4 tried the gas anyway and blew my intercooler apart :(
I skipped the Easter event and ordered a new intercooler (eBay special £70) and spent the weekend trouble shooting, midday Sat I found the issue i had changed the feed line to the ECU and it was dropping voltage when load was applied reverted back to the old feed, and like magic the issue was gone....
Spring Speed
first run out netted a 12.7 without gas turned the boost down a bit (was at max boost) and still ran a 12.8 I decided to run a 50 shot dialled in 12.4 ran 12.37 with a 1.78 60ft Very happy carl :)
Apex
Went and played at apex on the Sunday had a good time car was driving well I saw off a couple of track prepped 944's and held my own with a lotus :)
Summer Nats
had a good time, tried a 100 shot of gas and managed a 12.5 @ 114mph
Bug Jam
had an awesome time, after the second run my car felt very strange on investigation the diff was locked solid, as the box wasn't leaking I decided to run as it was did a couple more runs and managed a new pb of 12.2 @115 but broke the box on the return road (how lucky) as I was coasting down the bit that had lodged in the diff came out and smashed through the diff housing :(
a quick call to my dad had him coming up early doors Sunday to bring the gearbox that I had been building up (with LSD)
box was almost out by the time my dad arrived with the box and the trailer
after a hard mornings work we had the box back in but the front was still off the car, we were called 5 minutes later they asked if i was going to run... I asked how long do i have? about 2 minutes was the lady’s reply about 4 minutes later i was staging next to Dave with most of the front on the car.... I need to say thanks to everyone that helped me with this and also to Dave for waiting till the last pair for me..
great weekend ended up getting through 2 rounds
after bug jam I had the wishbones off again to change the subframe bushes as I thought they were getting tired and upgraded them to R32 ones also took the opportunity to stich weld the wishbone halves together.
on to Open sports nationals
I had a very bad start to this event about 8 miles from Shakey on the Friday the golf dropped an exhaust valve on number 4, RAC recovered me home and I got home about 3 in the morning, spent the next day (my birthday btw) fitting the spare engine (from when the turbo got rebuilt) when I took the exhaust manifold off i was able to see the valve head, It had not gone through the turbo..... Happy days :)
I managed to get it in an running and drove upto shakey for about 8pm and had a massive welcome from everyone in the pits (Thanks guys and girls)
next day I ran another PB a massive drop to 11.62 @ 119 mph
On my way home from Shakey one of my output flanges on the box popped out, so I swapped in a spare that I had borrowed 5th from (TDI box) and ran that
VW Action
this was a testing day for me the golf ran fine (although my bottle heater broke so nos pressure was all over the shop) managed a few 12's also lent the golf to my little sisters Boyfriend as he was a massive help at bugjam fitting the box, first time on the strip 12.5 I think he might have the bug.....
National finals
I decided to end the season on a high and try a 150 shot of gas, although the engine was fine (new mph PB 121) it just span on the start line sad times so dropped back to 100 shot.
GTI Festival
I really enjoyed this event, managed a new PB of 11.57 @ 117.9 and won my class (F)
Jap Show Finale
Because i didn't want my first year drag racing to end I decided to enter the final round of the FWD series, armed with a new bottle heater, I tried my luck racing in this heads up class, Knowing that I am at least a second off the pace of the slower racers it was a good chance to see how I could do, I only managed an 11.8 as I was struggling to launch it, still the car drove there and drove home although I think a cv joint is going.
so that was my year I hope I didn't bore you too much and I hope your year was as fun as mine.... see you next year
Carlg
Re: MK2 Golf 1.8t Drag car
Postby R100RT » Mon Dec 22, 2014 8:20 am
What an adventure, excellent story and good luck next season.
Lorne.
1983 BMW R100RT Bike
Turbocharged - Water Injection
Sequential Ignition is great
"Perky Sleeper"
New toy - 1995 BMW K75 is on "The Mod Table", another V2 vintage Microsquirt kit'n caboodle ready to add, turbocharger in process, all the "usual suspects"
R100RT
Postby Carlg » Tue Dec 23, 2014 6:28 am
Thanks Lorne,
hopefully once i fit the bigger turbo and injectors i will be getting closer to those 10's also have to get my head around ms3 .... :shock:
Carlg
Postby gary_808 » Mon Dec 29, 2014 6:22 am
Seen you run at pod many times just shows what can be done with some work! Didn't realise you was still on the k04 which makes it more impressive.
I had a corsa running on squirt now gathering bit to build a 4wd mk2 golf will be on ms3x
gary_808
Postby HidRo » Mon Dec 29, 2014 8:04 am
Nice ride!!
I also have a 1.8T on a Tornado Red mk2 :)
Love it!
But my best time is 13.2, which sucks :P
What turbo is that you are running? Holset HX27?
HidRo
Postby jsmcortina » Mon Dec 29, 2014 8:16 am
Some day we will have to organise a UK mini Megameet.
Postby Carlg » Tue Dec 30, 2014 1:52 am
gary_808 wrote:Seen you run at pod many times just shows what can be done with some work! Didn't realise you was still on the k04 which makes it more impressive.
Hi Gary,
thanks the K04 will be coming off soon, but i need to first make a twin scroll manifold for the holset :? what engine are you use for the mk2? and i assume mk4 4motion drivetrain?
Cheers,
HidRo wrote:Nice ride!!
Love it!
13.2 is fine, the best i had done without slicks and gas was a 13.5, and with a 100 shot on on back to back runs i did a 13.1 on road tyres (2.6 60 ft :lol: ) and then a 11.67 on my slicks (1.69 60 ft 8) ) although i tried to launch my road tyres like slicks hence the really bad 60ft it does show what a good launch can do :D
the Holset is a HX35 with a 14cm hot side hoping with the nitrous it shouldn't be too laggy (also it was cheaper to buy new than to get the K04 rebuilt ) hoping to get it on this winter.
Red mk2's look good :)
jsmcortina wrote:Some day we will have to organise a UK mini Megameet.
sounds good James, Ps your cortina is awesome :mrgreen:
Carlg
Postby HidRo » Tue Dec 30, 2014 3:48 am
I'm using a 50trim, and last time I did a 1/4mile run was around 350hp I guess...
I have gearbox issues (can't get into 2nd and 3rd when warm).
I'm using track slicks, which are old, and should not be doing much now, but still better than street tires I guess.
So, if you are getting 13.5 with a k04, that is really good!!
HidRo
Postby gary_808 » Tue Dec 30, 2014 12:25 pm
Hi Gary,
Cheers,
I've got a syncro rear end that I've welded the conversion kit on for the haldex rear diff so now it's practically bolt on bar some chopping of body work,
Engine wise I'm undecided I have alot of 1.8t intergrated engineering goodies for my s3 begging to be used in something lighter but I think I'll go vr6 12v/2.8 24v as they are bomb proof.
Who knows
I have all these parts in the garage but haven't even found a shell that I like yet (small bumper no arch) I am swaying 5 door for sleeper effect.
I'd be up for a mini meet at pod or such like, though in the short term ill probs be on my bike or daily.
gary_808
Postby Carlg » Tue Dec 30, 2014 2:06 pm
Who knows
VR6 do sound nice and are really quite cheap (also love a whiff of the gas) but most are quite old now... have you thought about a poverty spec jetta?
as for a meetup pod or shakey would be cool....
HidRo wrote:I'm using a 50trim, and last time I did a 1/4mile run was around 350hp I guess...
i think the poor little k04 (022 btw) is well out of its efficiency range but its still working so im happy... what sort of terminal speed did you see?
Carlg
Postby HidRo » Tue Dec 30, 2014 2:47 pm
Around 174km/h (end of 3rd gear).
I'm swapping the final drive for a shorter one again (3.89 swapped for 3.68), and I hope to see the gear change issues gone.
HidRo
Postby Carlg » Tue Dec 30, 2014 5:27 pm
HidRo wrote:Around 174km/h (end of 3rd gear).
thats about 108mph :D it takes me about a 50 shot to get there
Carlg
Postby tutuur » Thu Jan 29, 2015 1:29 pm
Nice project you have there mate! Love the replacing of the gearbox on paddock :mrgreen:
As for the minimeet, how does Retro day at Pod sound? I'll be visiting pod the whole weekend (i'm from NL).
Would be great to have a chat with fellow members!
tutuur
Postby Carlg » Fri Feb 20, 2015 12:31 am
tutuur wrote:Nice project you have there mate! Love the replacing of the gearbox on paddock :mrgreen:
unfortunately I wont be at the retro show, we will be on holiday that weekend in the Netherlands (Wanroij) for an aircooled vw show.
Carlg
Postby tutuur » Sun Feb 22, 2015 1:02 pm
How funny :lol:
tutuur
Postby Carlg » Thu May 21, 2015 2:13 pm
So over winter I repainted the car, bought some new lighter wheels and gutted some spare doors and fitted polycarb windows, in total its 65 KG lighter (im also 10KG lighter :yeah!: )
first run out managed a new pb of 11.48 @ 118.8mph
so it now looks like this:
some pics from the winter
after the second event I damaged the car and ended up changing the engine (now a BAM bottom end 9:1 compression rather than 9.5:1 with uprated rods) and rebuilding the turbo
I managed to get the new engine in an running (and diy turbo rebuild) done in a week for the next event at the weekend but the engine had a funny noise and was leaking loads of oil so I dropped into VW sportsman and raced my old camper (pb of 20.9 @ 61.9 1679cc type 4 with twin 40's )
the following weekend I fixed the golf (the noise was actually the starter and the oil leak was the oil filter housing) and took it to a local vw show called APEX at lydden hill was real good fun and the engine and turbo was flawless :D
hopefully I will be racing again in a couple of weeks 8)
Carlg
Postby HidRo » Sun May 24, 2015 12:48 pm
Nice to see it back alive :D WHat happened to the engine?
HidRo
Postby Carlg » Mon May 25, 2015 1:10 am
I think two things had happened 1 the oil was almost certainly from the turbo oil seal, but when I was diagnosing it I noticed that compression on no1 was about 45 psi lower than the other three stripped it out and it had started to show marks on the bore so I built up a spare BAM engine a friend gave me (removed from a TT due to a snapped Cam belt) seems to run ok :lol:
Carlg
Postby HidRo » Mon May 25, 2015 2:56 am
Ok cool!!!
You didn't put rods in it? So it can take more torque?
Nice to see that it's always moving forward :D
HidRo
Postby Carlg » Mon May 25, 2015 12:54 pm
I put rods in......the bam ones look identical to agu ones so I don't trust them.
I wanted to lower the compression for the bigger turbo but also was the engine that I had around me :D
Carlg
Next
Return to Success stories
