This car has a rather long story, I bought it in 1997, built a junkyard turbo setup for 1999 (running K-jetronic from a Saab 99 turbo), then swapped to EEC-IV (Ford Sierra) around 2001 and went Megasquirt in 2004. I first ran the old Megasquirt&EDIS code or what it was called, and later went on to MS extra (using EDIS).
Around 2006-2007 I built a new engine with YB Cosworth rods and pistons (still Pinto block, head and crank), and a Holset HX35 turbo. I also added launch control and flatshift, and in 2009 it did a 11.99s / 180 km/h 1/4-mile pass. That was on around 1.4 bar of boost.
Then in October 2009 I started a body restoration, along with fitting a X-pack arch kit. Turned out pretty nice...but it took me 5 years!
It still ran on the old V2.2-based MS, but during the season I started to get some random misfires where the rpm would spike. I checked all earths but could not get rid of the issue. So in 2015 I started the migration to MS3 with MS3X. The plan was to go to sequential injection but keep the waste fire ignition. Since the swap was made in the middle of the season I kept the old wiring so no sequential injection yet. I'm using a Quadspark module to fire the EDIS coil, and I trigger from the same 36-1 trigger wheel (YB Cosworth aftermarket) using the YB crank sensor (since I now have a YB oil pan with mount for the VR sensor).
I have only made a few short test runs but all seems to work really nice. The VE Analyze autotune means it's pretty easy to get a decent tune going.
When I first went MS in 2004 I said it was the single best thing I have ever done to the car. Now the body work competes a bit with that but still I like my MS
Gustaf
1974 Ford Capri 2.0 turbo
__________________________________
Ford Capri 2.0 Turbo
Past projects:
2.8 Twin turbo & 2.9 24v Twin turbo
MS&EDIS/MS-extra
Past projects:
MS&EDIS/MS-extra
- Running MSx/Extra
Re: 1974 Ford Capri 2.0 turbo
Nice one Gustaf
John
John
Hay Gustaf
I am still trying to get my Cosworth Rally car to run on MS3 + MS3X but after 4 years still no go so have kept my P8 ECU but would love to move over to MS with all the developments
Could you send me a base map to look at?
Kevin
Kevin
Really nice Gustaf, I've always liked the Capri.
Graduate of EFI University.
