this is an old italian car,born in 1972,engine is 700cc updated,dual intake head,but, the most difficult job was the intake manifold, made of cast aluminum and connected with two 36mm bing butterflys.
megasquirt2 v3 ,wiring loom and more myself assembled.
I hope you enjoy this fantastic little car
fiat 500
Re: fiat 500
details
Re: fiat 500
Nice Pitures !!
Could you also post a picture of the whole car ?
And does it run well, or stil tuning ?
Was there a special reason to mount the injectors this way ?
You could have used a (bike) throttle body whit the injector already in it.
Re: fiat 500
I did the work in this way to find a perfect symmetry between the cylinders.
I made the aspiration manifold by following the radiusing between the intake valve and inlet of the cylinder head.
throttle bodyes cames from a bmw k100,injectors from a fiat punto,fuel rail is inox steel homemade and coil is from a suzuki bike.
here the car!
here the car!
Re: fiat 500
and here some details
