8.53@167.6 1973 240Z, LS3 and 4L80e
nathaninwa
Post by nathaninwa »
Been working on this 73 Z since febuary. Car is back halfed with 4 link and a 9 inch, 4L80e transmission with a brake and 3600 triple disc converter, and engine is a 2010 LS3 with custom cam, ported heads, my own tuned intake and 12.5-1 compression. It running on MS3pro and microsquirt, along with egtcan setup
Vid is from breaking the rings in, car runs very well at this point, and had zero issues while running. Tranny needs some tuning but all in all very responsive. Car is getting an alignemt next Saturday and wheel balanced, then Ill head back to the 1/8th mile from some shake down runs then hit up PIR the weekend after
Things went well yesterday
https://youtu.be/pdIPYyndMik
And the best part
nathaninwa
Re: 73 240Z, LS3 and 4L80e
Got closed loop idle under control pretty quickly. I used a ford pwm motor
http://youtu.be/eeBNSxxbJN0
nathaninwa
Got to shake the car down yesterday Very pleased with the results and how the car ran
https://youtu.be/-M2gClYq7Ik
https://youtu.be/m1YjkAruifs
nathaninwa
Ill see about getting some video from my son tomorrow. Was able to make 6 passes down the 1/4 at Portland international raceway tonight. It gets dark so early I made no chassis adjustments, just air pressure. Car needs more converter for sure, I stall out on the brake at 3100 and car runs a 1.6/1.7 sixty but falls on its on the launch, then comes to life. I'm crossing the finish about 6000rpm so I can go a little deeper with the gears, to maybe a 4.30 with a 29 inch slick and run the 28 inch et streets at the 1/8th mile and just run that gear as an all setup
Off the trailer the car made a 10.8 pass at like 132, then ran a best of 10.7 at 132, then more 10.8 passes till I started running out of fuel in the race tank. Burnt up 2 gallons of 116 in 6 passes which means I also burnt 2 gallons of 92 for a total of 4 gallons in 1.5 miles!!!!
All in all I'm 110% happy with how this car is feeling right now and can't wait to get the converter restalled
nathaninwa
matthunter1448
Post by matthunter1448 »
where you dynoing at i've been looking around for when i get my car done and nobody wants to touch megasquirt
nathaninwa
Call up English Racing and talk with Aaron. There down in Vancouver
matthunter1448
i talked to them at pacific raceways they said they love megasquirt but didn't want anything to do to it if somebody else set it up maybe you got the hookups lol idk
but glad to see your 240z is doing good looks like a fun little car. Wish i still had my old z
nathaninwa
I'm very good friends with the dyno operator down there. it is true they don't like to take on any projects that others have started, just not megasquirt. Al my stuff had a god street tune and we're just fine tuning. If you can get to that point in sure they would be happy to help. It's the gremlins in a fresh install that can make a dyno day go bad!
gearhead
Post by gearhead »
Congratulations, very cool project.
nathaninwa
Over the spring time I added an S480 to this car and some other internal goodies and finally was able to get it to the track to only need to make licensing passes. This is my final license run and excited to get back after getting it to work on launches and turn the wick up
https://youtu.be/kGe9LJkop-k 9.46@148 another pass was 9.50@152
nathaninwa
Went to Portland oregons 1/4 mile track. Super slick for the first half. Wouldn't hold 7psi without pedaling, but then held 18psi on the back half.
Ran a 9.74 at 161.5mph. Car is making some power out the back door
Earlier in the day, I was testing at an 1/8 mile asphalt track and went 6.15 at 127. Portland was running 6.50's at 118 ish
matthunter1448
d***. That's awesomeness hoping to finish my ls build here soon
Sent from my SM-N920T using Tapatalk
nathaninwa
Here is my 1/8 mile
https://youtu.be/boSAvBVCs2Q
nathaninwa
Re: 73 240Z, LS3 and 4L80e 8.53@167.6
Was able to make a pass in the 1/4 mile in the Super Pro class to get my test hit in today. Car ran an 8.53@167.6 All the data collection and changes Ive made all year was in this one pass. Datalog isn't the prettiest but very happy with the results
Enjoy
https://youtu.be/m6_jfZbFEm8
nathaninwa
Re: 8.53@167.6 1973 240Z, LS3 and 4L80e
Here is an in car video
https://youtu.be/PK1JneyaPe4
Raymond_B
Post by Raymond_B »
Nice!
http://www.buildpics.org/
turbo conversion
Post by turbo conversion »
I'm assuming your build started out n/a and then you added the turbo correct?
Holly Guacamole Bat Man, that is impressive. :P
David
nathaninwa
Yes, I should have turbod it in the beginning! I swapped pistons which required a rebalance, which meant my 34 mile motor needed to come all the way apart again! Glad I did though, the power this car has is pheniminal
