1970 boosted mustang
[/url][/img]here is my turbo charged 410 c.i. mega squirt 3 equipped 1970 mustang fastback .
Re: 1970 boosted mustang
https://www.facebook.com/aj.williams.35 ... 34/Picture taken at the Halloween classic at Norwalk, OH
I can't upload pictures. It says it's to large
detroit autorama
front view. sorry it is sideways. i tried to rotate the picture but no luck.
Nice!
http://www.buildpics.org/
the engine 410 ci windsor, dart block. eagle forged crank Olivier billet rods diamond 9.5 to 1 c.r., jon kaase p-38 heads, solid roller cam, edelbrock super victor intake,accufab 90mm throttle body, 1500 hp air to air inter cooler, 98mm G trim precision turbocharger 1.0 turbine housing, two 45 mm HKS wastgates, of course mega squirt 3 with X card, LS2 truck coil on plug, sequential injected 160 lb ev1 injectors squirting E85 gas (soon to be staged injection for methanol) close loop boost control. turbo 400 trans with 9.5 M&M converter, BTE billet aluminum trans brake..
Time slip
i have built a couple manifolds and it is a lot of work for sure!
2002 montero dakar rig
3.0L DOHC duratec / 6HP26
gt3582 boost to the moon
Ms3X soon to be running
dodge M37 look-a-like 1 ton
4.2l chevy atlas / 6R80
66mm turbocharger ~8#
Ms3X sequential finally kicking some butt
