1971 Ford Bronco MSPNP 351W
General talk about successes. See older information on MSRUNS forum.
frdboy
Post by frdboy »
Did a 2 1/2 year frame off build on this guy, just got it up and running a few weeks ago. Entered it in a side by side drag race up a ski hill last weekend and finished 2nd in my class. Maybe would have had a shot a winning if I was in the other lane as the right one had a bigger jump and I almost rolled it.
So far been very happy with MS, this is my first FI build and I had no real trouble tuning it in the short amount of time I had to make it race ready.
351W, stock 1996 short block
ported junk E7 heads
Lunati Hyd. roller cam
big single plane intake with a holley 4150 TB
Running MSPNP for 87-93 mustang
30 lb injectors
no idle air control at this time, just using cold advance and idle advance to help with idle and it works really well.
Right now running a TFI dist. and coil but hoping to switch to EDIS at some point.
https://youtu.be/SfCW8kvNIBc
https://youtu.be/-VOwya90J-A
https://youtu.be/vi0U9MhyxU4
Laminar
Re: 1971 Ford Bronco MSPNP 351W
Post by Laminar »
Looks beautiful! What transmission are you running?
frdboy wrote:Right now running a TFI dist. and coil but hoping to switch to EDIS at some point.
Any reason you wouldn't go with LS coils? They give you more flexibility and control than EDIS.
dontz125
Post by dontz125 »
Gorgeous beast! (And I'm not talking about the passenger ... :lol: )
I agree with Laminar; assuming you have enough dwell time throughout the rev range, switching to direct coil control of the dizzy would give you better spark control than EDIS.
frdboy
Post by frdboy »
Thanks!
I thought about LS coils....just need to research what needs to be done to run them. I think I have to use a Hall effect sensor and then use 4 of my optional outputs to drive the coils.
dontz125
Post by dontz125 »
There are dizzy wheel mods and drop-in dizzy replacement crank angle sensors. A proper missing tooth crank wheel is the most accurate, but depending on the engine can be a real brat to install.
I believe your MSPNP is based on the Microsquirt Module, so you have two dedicated spark channels, and you'll use up the ALED and WLED option pins for the other two channels.
frdboy
Post by frdboy »
I have a 36-1 wheel and vr sensor installed already, couldn't get edis to work...keep resetting..... Seems others are having the same issue so maybe someone will figure it out.
I was told my mspnp can't take the vr signal directly without some mods and it would be easier to run a Hall effect. I am using one of my outputs to drive a cooling fan relay so I would have to figure that out also. No biggie right now...pretty happy with it as is.
dontz125
Post by dontz125 »
?! There should be a VR circuit on the board. The mods involved should just be jumpers ...
frdboy
Post by frdboy »
Laminar wrote:Looks beautiful! What transmission are you running?
4R70W controlled by a Quick 4 controller
