Nissan Micra 2001 K11 1.4
Posted: Mon Oct 16, 2017 7:49 am
So after one year of buying, building, and then fitting, I've finally got my MS3X running the car.
I've used all the original sensors apart from the maf and oxygen sensor. I managed to tap into the maf temp sensor and make a 3 point table for it. I also fitted a wideband so I can tune it.
It uses a 60-2 configuration that is machined as part of the oem flywheel with a bosch vr sensor, and a single tooth hall effect cam sensor. I'm running it in full sequential mode as that's how it was from the factory.
Couldn't get it to idle below 1050rpm at first, but then found out I'd wired the vr sensor backwards. Bosch have mine as black vr+ and white vr- who'd have thought it!
It runs the oem coil on plug setup using four bip373's that I've fitted into a small weatherproof metal box in the engine bay to keep any noise away from the main ecu.
I'm now into the home tuning stage.
I know nothing about tuning I might add, so it'll be a fun learning curve.
Overkill you might say for an 85bhp car, but that's hobbies for you.
Sent from my WAS-LX1A using Tapatalk
