Release Announcements
Note that Megatunix is obsolete.
Moderator: djandruczyk
Re: Release Announcements
Postby djandruczyk » Tue Jan 25, 2011 1:06 pm
StevenD57 wrote:
StevenD57 wrote:Before I started this process I created a new git directory and cd'ed into it. As I quoted I did my checkout and then cd'ed into the Megatunix dir and tried the checkout modular_4.0
I just tried it again and it gave me the same error.
I will try on a completely different machine.
That is very strange. I just tried it on a different machine and it worked fine.
Same exact steps. Weird
It's modular _0.4 NOT modular_4.0
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby djandruczyk » Tue Jan 25, 2011 1:17 pm
StevenD57 wrote:
djandruczyk wrote:There is no 4.0 code
In any version control system, there is usually the concept of "branches" (think of a tree), where development is isolated from the "trunk". branches have names, I'm currently working on hte modular_0.4 branch, and will shortly be merging that back to the master (trunk), and splitting off to a new branch mainly that I've accomplished my goals for the modular_0.4 branch.
What were your goals for the modular_4.0 or the modular_3.0 code branches? Just curious to see what might have changed.
It was done to support more than just megasquirt devices, and to cleanup the codebase somewhat. IMHO the leaders of the MS community seem to act as if they would prefer if people just used tunerstudio, so I decided to support more than just MS stuff, as I felt my efforts were largely ignored and unwanted by some of the powers that be. (my posts and forum on msefi was erased by the forum managers if that gives you any idea). I also wanted to attract more users and more feedback, and by adding support for other devices, that helps.
Currently in modular_0.4 I support all current MS-1, MS-2, MS2-Extra firmware's, as well as support for the JimStim 2.x stims (need the FTDI USB-TTL RS-232 cable), PIS 1.0 (performance injection system, a hacked firmware for GM ALDL CPU's, though the author of it seems to be too busy to post much about it) And preliminary support for some additional devices including a very interesting clean-slate in-development FOSS software/hardware design, and a FOSS russian ignition only control unit. I also hope to add support for ELM-32x devices eventually, more so as a logger/dash setup, since info on how to CHANGE stuff via OBD-II only appears to be available by only an extremely expensive/un-affordable licensing, and there may be legal issues with that, that I'm not yet aware of.
I just received a MS3/MS3x donation yesterday from an extremely generous user, so support for that will be coming soon. I also have an IO-X from Jean that I need to add support for. (current development needs to finish up before i can do his and MS-3 however).
As part of this effort, a huge focus was done on debugging the codebase, which mean many many many hours with valgrind, teasing out subtle coding bugs, which has helped immensely.
Reason: Forgot part about debugging/leak checking.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby StevenD57 » Tue Jan 25, 2011 1:30 pm
Wow, that is pretty low and despicable to erase the Megatunix forum. I did not know that happened.
What cars use this PIS stuff for the GM ALDL ECU? I just bought a 1990 Lotus Esprit and I believe it has ALDL cables that are used to communicate with a GM based ECU that Lotus sourced when they were owned by GM.
Jaguar E-Types, modified Merkur XR4Ti, Jensen-Healey
Linux = no virii or spyware, EVER
StevenD57
Postby djandruczyk » Tue Jan 25, 2011 1:52 pm
StevenD57 wrote:Wow, that is pretty low and despicable to erase the Megatunix forum. I did not know that happened.
I'm not entirely sure, I think is was late 80's to early 90's. The author of it hacked mtx to work with it and setup glade files and gui config's to suit it, I don't have any of his hardware so I could never verify how good/functional it was. I incorporated his changes, and then he pretty much disappeared for 6 months. I heard he was back , but haven't heard much else. I'd suggest googling for it. I think he's an OZ'lander.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby VolvoGuy50 » Tue Mar 08, 2011 3:19 pm
How's the MS3 additions going? I wanna try this program out! Maybe it'll be better on my tuning laptop, which seems to fail epically at running TunerStudio under Ubuntu. :lol:
1992 Volvo 740 Wagon - Beater Car...CAI, 16T, catback, MS3/MS3X, & HID's
1996 Eagle Talon TSi AWD - Daily Driver...RAI, Big 16g, 3" TBE, HID's, etc.
VolvoGuy50
Postby djandruczyk » Tue Mar 08, 2011 4:55 pm
VolvoGuy50 wrote:How's the MS3 additions going? I wanna try this program out! Maybe it'll be better on my tuning laptop, which seems to fail epically at running TunerStudio under Ubuntu. :lol:
MS3 is going slowly as I've have other more pressing work to attend to. It'll get there eventually.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby 24c » Sun Mar 20, 2011 1:36 am
VolvoGuy50 wrote:... I wanna try this program out! Maybe it'll be better on my tuning laptop, which seems to fail epically at running TunerStudio under Ubuntu.
I've used MegaTunix & TunerStudio with MS2Extra3.1 on OSX 10.6 & Linux Mint 10. If anything TunerStudio is slightly faster on Linux Mint 10 than the Apple OS 10.6, and MegaTunix offers a different point of view, and which ever tuning software I use with my cased MicroSquirts neither is any the wiser. There have been flaky times with both, but I am not using a majority platform, so you learn to become tolerant of any foibles.
I think we should consider ourselves lucky to have a choice, so thanks to both parties for all their good work.
Yamaha YZF1000 MSExtra 3.1
24c
Postby m3ltd0wn » Mon Jun 20, 2011 12:41 am
any chance that it will support 3.1.1 firmware with ALS made by baldur?
m3ltd0wn
Postby djandruczyk » Mon Jun 20, 2011 10:51 am
m3ltd0wn wrote:any chance that it will support 3.1.1 firmware with ALS made by baldur?
Where's his code and INI's? If I have those I can easily support it as I already have support for MS2-E 3.1.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby Gokart » Mon Jun 20, 2011 5:54 pm
(4G63T - MSIIextra) (4G13 - MS3-beta testing)
Gokart
Postby djandruczyk » Mon Jun 20, 2011 7:09 pm
I have committed to Git support for Baldur's 3.1.1+ALS firmware. You should be able to do the usual steps
Code: Select all
git pull
./autogen.sh  ; make ; sudo make install ; sudo ldconfig
and run it and it should detect his firmware and load that Antilag tab.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby m3ltd0wn » Mon Jun 20, 2011 11:36 pm
thank you !
m3ltd0wn
Postby djandruczyk » Tue Jun 21, 2011 6:34 am
Just beware this is still a pre-release edition (git/development), so it may have quirks , but please report back any issues in a NEW thread.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby m3ltd0wn » Mon Jun 27, 2011 9:07 am
the als menu works ok.
could you plese integrate 3.1.1_als firmware in a windows release as well ?
10x for your great support and product!
m3ltd0wn
Postby djandruczyk » Mon Jun 27, 2011 1:31 pm
m3ltd0wn wrote:the als menu works ok.
The windows edition is still somewhat flakey ,so I'm still working on ironing out the bugs. Windows is an absolutely awful environment to debug on which makes the process very slow going./
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby m3ltd0wn » Mon Jun 27, 2011 3:01 pm
yes I know :)
m3ltd0wn
Postby Sid Nethery » Fri Jul 01, 2011 7:20 pm
Is there a Debian AMD64 binary?
Sid Nethery
Postby djandruczyk » Sat Jul 02, 2011 5:12 pm
Sid Nethery wrote:Is there a Debian AMD64 binary?
Not right now, When this dev version is released, there should be. For now you can build and install a development version from source.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Previous
Return to Megatunix (obsolete)
