I upgraded earlier and I just had to play a bit so I dug out an extra MS and hooked it up to the stim and now Megatunix is not working it is giving me this
Initiating background ECU interrogation...
Command "C" (MS Clock), returned 2 bytes
Command "A" (Runtime Vars), returned 1 bytes
Command "a" (Runtime Vars (MS-II)), returned 1 bytes
Command "R" (Runtime Vars (MSnS-Extra)), returned 1 bytes
Command "c" (MS-II Clock), returned 1 bytes
Command "v" (MS-II VE/Constants), returned 1 bytes
Command "Q" (MS Revision), returned 1 bytes
Command "V" (VE/Constants), returned 1 bytes
Command "S" (ECU Signature), returned 1 bytes
Command "T" (Text Version), returned 1 bytes
Command "I" (Ignition Variables), returned 1 bytes
Command "F0" (Raw Memory Readback), returned 2 bytes
Firmware NOT DETECTED properly, Expect MegaTunix to NOT behave properly
Contact the author with the contents of this window
USER Initiated ECU interrogation...
I unistalled Megatunix 0.9.4 using the uninstall in the Megatunix file went to the site downloaded the latest installed it and now its being cranky.
I am running Windblows XP service pack 2 MS V3 O29t.
I went back and tried to reinstall 0.9.4 and it wont work now either.
Not sure what did wrong?
Thanks and it is awsome program!!!!
71jeep
Allen...
A little trouble/was no trouble at all fixed
Moderator: djandruczyk
Could this be due to picking up the wrong com port what I mean is an active com port that is not the MS like my wireless connection?
I always forget what com port the one MS I have picks up.
The one thing I noticed and more I thought about it was weird is everytime I went into megatunix even with the MS disconnected it was picking up the com port?
Anyway I will do some more testing tonight thanks.
71jeep
Allen....
One moree thing a suggestion maybe you should put a sticky about font size to save yourself the headache of answering the question all the time I almost asked myself till I saw your answer in a previous post.
Thanks for a great program!
71jeep
Allen....
Well I found out it was on my wireless port it kept defaulting back to that port until I hit enter then it kept the port that the MS is on.
Well if anything maybe this thread will help keep someone else from looking like jack#ss.
And everything so far looks like it is working flawlessly I was still having a problem with it reading the wideband properly LC-1 in 0.9.4 but now it is right on thanks again for your efforts I hope Megatunix becomes the prefered it is awsome .
Thanks 71jeep
Allen...
Thanks 71jeep
Allen...
