DEPRECATED ... install MegaTunix on OS-X
Moderator: djandruczyk
I wanted to say too, that this write up was extremely helpful. I bought a 17" MacBook Pro two weeks ago and was originally thinking of putting Windows XP on it for the purpose of running MegaTune.
The only thing I had an issue with editing the .profile so that I could type 'megatunix' directly without having to type /opt/local/bin/megatunix everytime. But it is not an issue.
My .profile has this:
export PATH=/opt/local/bin:/opt/local/sbin:$PATH
What do I add to that?
Thanks. Again thumbs up on the how-to.
D. Tsang
SGT/USMC
1999 Eclipse - 2.4EDZ Squirtin & Boostin
MSII 3.0, 4 bar, seq, p&h. 406 whp/393wtq
SGT/USMC
Megatunix with OSX10.3.9
Won't let me use the XCode 2.4 Will MegaTunix work with an earlier version?
Joe
Joe
Joe
Warner, NH
Subaru Impreza w/EG33
Squirt in Process
Warner, NH
Squirt in Process
- MS/Extra Guru
Re: Megatunix with OSX10.3.9
I have no way of knowing, Xcode was a free download for me, once I created a FREE apple dev account.rs3pt3 wrote:Won't let me use the XCode 2.4 Will MegaTunix work with an earlier version?
Joe
AFAIK when i wrote the howto macports/darwinports's requirement was for Xcode 2.4.
David J. Andruczyk
success re-nstalling first go.
already had Xcode after earlier install (at version 0.8.5) using Fink to get required libraries (also worked).
i copy/pasted the instructions from Dave's 1st post and it installed with no errors at all.
modded the applications menu to easy launch all the apps, plus cairo antialiasing works quite well despite the age of the CPU
G4 (733 mhz)
OSX 10.4.10
1G RAM
Xcode v2.3
X11 1.1.3 XFree86 4.4.0
I had installed X11 previously to run Open Office (NeoOffice was too slow to use productively).
G4 (733 mhz)
OSX 10.4.10
1G RAM
Xcode v2.3
RA40 + 18R + Turbo
MZ10 + 7MGE = track barge!
- MS/Extra Guru
Perhaps, but the linux people will have an easier time of it than OS-X users, because most linux boxes come with most of the needed pre-reqs installed, and it's easier to get them if they don't have them (unlike OS-X which requires downloading Xcode (hefty 800+ megs), and getting macports/darwinports setup)UnaClocker wrote:hehe, almost seems like there are more people running Megatunix on Mac OS X than on Linux.. ;)
Usually it's only the ones who have issues who post to the forums, those who get it going with no issue, don't bother. According to sourceforge.net download stats, megatunix had about 3:1 downloads (450:150) in favor of windows over the source release (which covers linux and OS-X) for the past release with significant stats (0.9.12 in july).
I'd take a guess that the source release split between linux and OS-X is about 1-2:1 in favor of OS-X, only because OS-X has more market share than linux (depending on who you ask),
If you look at all the stats for all releases, it's about 3-4:1 for windows users to unix users.
megatune (windows only) prolly has 10-20x as many users or more, but it has been entrenched for a far longer period of time and many people don't even know about megatunix as the megamanuals don't barely make a mention of it.
Both are excellent peices of software, but come from very different design points. MegaTune has the advantage as a rapid prototyping environment making it easy for devs to get new firmware setup on it, but making the user UI a little cumbersome and confusing, esp to noobs. (how the hell does on use mtconfig anyways?). MegaTunix is developed with more focus for the end user, attempting to make it more intuitive and friendlier, at the expense of being more laborious for the developer (me) to support new firmwares. Megatunix has kickass photorealistic gauges, and tools to let users build more, megatune has configurable gauges, but well, they ain't as pretty. or intuitive. Megatune hassupport for firmwares that megatunix doesn't like MS2 and MS2 extra. So each software has it's place and BOTH are very valuable to the end user..
such is life.
David J. Andruczyk
- MS/Extra Guru
Looks like it had a timeout downloading a package. retry.stereophile33 wrote:I have a new Core 2 duo that I am having trouble getting to run this.
after I command
sudo port install gtkglext libglade2
I get teh following error.
anyone have any ideas as to where I need to back up and try differently?
Jonathan
u can also try "sudo port selfupdate" to get it to update itself and get the latests lists of packages.mirrors..
David J. Andruczyk
latest error from Xterm is:
kathryn-myers-computer:~ jonathan$ sudo port -vc upgrade installed
Password:
sudo: port: command not found
kathryn-myers-computer:~ jonathan$ /opt/local/bin/megatunix
dyld: Library not loaded: /usr/X11R6/lib/libXt.6.dylib
Referenced from: /opt/local/bin/megatunix
Reason: Incompatible library version: megatunix requires version 6.1.0 or later, but libXt.6.dylib provides version 6.0.0
Trace/BPT trap
kathryn-myers-computer:~ jonathan$ sudo /opt/local/bin/megatunix
Password:
Trace/BPT trap
Password:
Trace/BPT trap
Password:
Trace/BPT trap
- MS/Extra Guru
runstereophile33 wrote:kathryn-myers-computer:~/megatunix-0.9.14 jonathan$ sudo port -vc upgrade installed
kathryn-myers-computer:~/megatunix-0.9.14 jonathan$ sudo port search libxt
No match for libxt found
Code: Select all
David J. Andruczyk
- MS/Extra Guru
I need more info. I'm (unfortunately) not a mind reader or remote viewer, so I have no idea what sort of error that YOU saw, so I have no way to help u until you provide some more usefull information.stereophile33 wrote:all ports are updated....still won't open.
Jonathan
David J. Andruczyk
sorry, wasnt meaning to be frustrating. So when I try and run megatunix, I get this error.
Trace/BPT trap
but as you can see I have 6.1 installed
/opt/local/var/macports/software/XFree86/4.7.0_0+macosx/usr/X11R6/lib/libXtst.dy
lib
/usr/X11R6/lib/libXt.6.0.dylib
/usr/X11R6/lib/libXt.6.1.dylib
/usr/X11R6/lib/libXt.a
/usr/X11R6/lib/libXt.dylib
/usr/X11R6/lib/libXtst.6.1.dylib
/usr/X11R6/lib/libXtst.6.dylib
/usr/X11R6/lib/libXtst.a
/usr/X11R6/lib/libXtst.dylib
so why is it trying to read 6.0 when 6.1 is present....
Any thoughts or suggestions would be appreciated.
Thanks for the help.
Jonathan
Trace/BPT trap
lib
Jonathan
- MS/Extra Guru
stereophile33 wrote:sorry, wasnt meaning to be frustrating. So when I try and run megatunix, I get this error.
Trace/BPT trap
lib
Jonathan
looks like you have two versions installed. You can try running "ldconfig" (not sure if that exists on OS-X or not, don't have a mac handy), or use the Macport manuals to figure out WHAT package owns /usr/X11R6/lib/libXt.6.0.dylib and uninstall it.
David J. Andruczyk
Any updates for 10.5? I tried using both the darwin port and the macports with no luck, this was the final error i got.
DEBUG: Setting ownership to root
selfupdate done!
patrick-sachs-computer:~ Patrick$ sudo port install gtkglext libglade2
Skipping org.macports.activate (gtkglext ) since this port is already active
---> Cleaning gtkglext
---> Building libglade2 with target all
Error: Target org.macports.build returned: shell command " cd "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_gnome_libglade2/work/libglade-2.6.2" && make all " returned error 2
Command output: make all-recursive
Making all in glade
/bin/sh ../libtool --tag=CC --mode=link gcc -O2 -Wall -std=c9x -version-info 0:7:0 -export-symbols-regex "^[^_].*" -no-undefined -L/opt/local/lib -o libglade-2.0.la -rpath /opt/local/lib glade-init.lo glade-xml.lo glade-parser.lo glade-gtk.lo -L/opt/local/lib -L/usr/X11R6/lib -lxml2 -lpthread -lgtk-x11-2.0 -lgdk-x11-2.0 -latk-1.0 -lgdk_pixbuf-2.0 -ltiff -ljpeg -lm -lpangocairo-1.0 -lpango-1.0 -lcairo -lSM -lICE -lgobject-2.0 -lgmodule-2.0 -lfreetype -lz -lfontconfig -lexpat -lpng12 -lXrender -lX11 -lglib-2.0 -lintl -liconv
rm -fr .libs/libglade-2.0.exp
generating symbol list for `libglade-2.0.la'
/usr/bin/nm -p .libs/glade-init.o .libs/glade-xml.o .libs/glade-parser.o .libs/glade-gtk.o | sed -n -e 's/^.*[ ]\([BCDEGRST][BCDEGRST]*\)[ ][ ]*_\([_A-Za-z][_A-Za-z0-9]*\)$/\1 _\2 \2/p' | /usr/bin/sed 's/.* //' | sort | uniq > .libs/libglade-2.0.exp
/usr/bin/grep -E -e "^[^_].*" ".libs/libglade-2.0.exp" > ".libs/libglade-2.0.expT"
mv -f ".libs/libglade-2.0.expT" ".libs/libglade-2.0.exp"
sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < .libs/libglade-2.0.exp > .libs/libglade-2.0-symbols.expsym
gcc -dynamiclib -o .libs/libglade-2.0.0.0.7.dylib .libs/glade-init.o .libs/glade-xml.o .libs/glade-parser.o .libs/glade-gtk.o -L/opt/local/lib -L/usr/X11R6/lib /opt/local/lib/libxml2.dylib /opt/local/lib/libz.dylib -lpthread /opt/local/lib/libgtk-x11-2.0.dylib /opt/local/lib/libgdk-x11-2.0.dylib /opt/local/lib/libatk-1.0.dylib /opt/local/lib/libgdk_pixbuf-2.0.dylib /opt/local/lib/libtiff.dylib /opt/local/lib/libjpeg.dylib -lm /opt/local/lib/libpangocairo-1.0.dylib /usr/X11R6/lib/libSM.dylib /usr/X11R6/lib/libICE.dylib /usr/X11R6/lib/libX11.dylib /opt/local/lib/libpangoft2-1.0.dylib /opt/local/lib/libpango-1.0.dylib /opt/local/lib/libcairo.dylib /usr/X11/lib/libSM.6.0.0.dylib -L/usr/X11/lib /usr/X11/lib/libICE.6.3.0.dylib /opt/local/lib/libgobject-2.0.dylib /opt/local/lib/libgmodule-2.0.dylib /opt/local/lib/libfreetype.dylib -lz /opt/local/lib/libfontconfig.dylib /opt/local/lib/libexpat.dylib /opt/local/lib/libpng12.dylib /opt/local/lib/libXrender.dylib /usr/X11/lib/libX11.6.2.0.dylib /usr/X11/lib/libXau.6.0.0.dylib /usr/X11/lib/libXdmcp.6.0.0.dylib /opt/local/lib/libglib-2.0.dylib /opt/local/lib/libintl.dylib /opt/local/lib/libiconv.dylib -install_name /opt/local/lib/libglade-2.0.0.dylib -Wl,-compatibility_version -Wl,1 -Wl,-current_version -Wl,1.7
ld: duplicate symbol _g_bit_nth_lsf in .libs/glade-xml.o and .libs/glade-init.o
collect2: ld returned 1 exit status
make[2]: *** [libglade-2.0.la] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
Error: Status 1 encountered during processing.
I attempted to go ahead with the install to only get this error
patrick-sachs-computer:~ Patrick$ cd megatunix-0.9.15
patrick-sachs-computer:megatunix-0.9.15 Patrick$ make
make: *** No targets specified and no makefile found. Stop.
I have previously gotten this to work on my computer previous to this install (10.4), but only to mess around with it.
Any help much appreciated.
selfupdate done!
Making all in glade
- MS/Extra Guru
No update on OS-X 10.5 as I don't have 10.5. That problem you're having however is NOT related to megatunix. I suggest checking the macports/darwinports site as they prolly have a new release that it tested for 10.5, or at least a way to submit reports of issues like what you're having.bohalrantipol wrote:Any updates for 10.5? I tried using both the darwin port and the macports with no luck, this was the final error i got.
selfupdate done!
Making all in glade
in the megatunix dir you need to follow the instructions and run
./configure
make
sudo make install
David J. Andruczyk
