Page 7 of 7
Re: The BEST way to install MegaTunix on OS-X
Posted: Thu Dec 31, 2009 10:05 am
by Valentinik
Hi, im trying to install megatunix on my imac running snow leopard. Im quite new to macs and this is my 1st attempt at using terminal.
Ive followed all of the steps, downloaded the megatunix tar file and put it in the home directory. For some reason when i come to untar the file i get and error:
Last login: Thu Dec 31 16:48:48 on ttys000
Mikes-iMac:~ Valentinik$ tar xvzf megatunix-<TAB>
-bash: syntax error near unexpected token `newline'
However, i can untar the file by double clicking on it in finder windows and then run the next part of the code.
I then go to configure it and get this:
Configuration:
Install Path: /opt/local
General Debugging: no
Profiling: no
when i try and make the file though i get this error:
loader_common.c:87: error: ‘B115200’ undeclared (first use in this function)
loader_common.c:87: error: (Each undeclared identifier is reported only once
loader_common.c:87: error: for each function it appears in.)
loader_common.c: In function ‘detect_firmware’:
loader_common.c:257: warning: passing argument 3 of ‘g_io_channel_read_line’ from incompatible pointer type
make[2]: *** [loader_common.o] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
Is there something ive done incorrectly previously, and is the error coming up because i couldnt untar the file in terminal and did it in finder?
Mike
Posted: Fri Jan 01, 2010 11:46 am
by djandruczyk
Valentinik wrote:Hi, im trying to install megatunix on my imac running snow leopard. Im quite new to macs and this is my 1st attempt at using terminal.
Configuration:
Profiling: no
Mike
MegaTunix for OS-X is likely to only compile from CVS, so you'd need to install CVS (via macports/darwinports), checkout a working copy, update to the correct branch and then compile/install.
I don't have access to any OS-X hardware to test megatunix, hence why that platform isn't well supported.
Posted: Wed Jan 20, 2010 7:37 am
by Chico335i
Hi, i'm need heeelllppppp!!! i'm doing all the steps buy the mac put this..
Last login: Wed Jan 20 08:19:20 on ttys000
Chico:~ mauricioalvaradovalverde$ sudo port -d selfupdate
Password:
dlopen(/opt/local/share/darwinports/Tcl/pextlib1.0/Pextlib.dylib, 10): no suitable image found. Did find:
/opt/local/share/darwinports/Tcl/pextlib1.0/Pextlib.dylib: no matching architecture in universal wrapper
while executing
"load /opt/local/share/darwinports/Tcl/pextlib1.0/Pextlib.dylib"
("package ifneeded Pextlib 1.0" script)
invoked from within
"package require Pextlib 1.0"
(procedure "dportinit" line 310)
invoked from within
"dportinit ui_options global_options global_variations"
Error: /opt/local/bin/port: Failed to initialize ports system, dlopen(/opt/local/share/darwinports/Tcl/pextlib1.0/Pextlib.dylib, 10): no suitable image found. Did find:
what can i do???
Posted: Sat Jan 23, 2010 11:05 pm
by djandruczyk
Chico335i wrote:Hi, i'm need heeelllppppp!!! i'm doing all the steps buy the mac put this..
Password:
while executing
invoked from within
invoked from within
what can i do???
check the docs for darwinports/macports, that's an issue with those. Odds are you didn't install the pre-requisites it needed to function.
