DEPRECATED ... install MegaTunix on OS-X
Moderator: djandruczyk
Did this work and was it easy to follow?
Yes and it was easy
9
56%
Yes, but it was a pain in the butt!
2
13%
No, I failed miserably and donno what to do
5
31%
I had my son/daughter do it for me
0
No votes
Total votes : 16
Re: The BEST way to install MegaTunix on OS-X
Postby Jay » Sat Jun 28, 2008 9:52 am
David, Thanks again.
I did read that, I just didn't know if I should try it. Not being very computer smart, I wanted to do exactly as directed. I'm perfectly capable of screwing things up by myself, but getting the desired result usually means I don't experiment along the way.
Thanks for walking me through it. I now have megatunix running! :yeah!:
Jay
Jay
Postby brigs » Sat Jun 28, 2008 11:41 am
i cant seem to find apple x11 just the x11sdk.pkg
brigs
Postby djandruczyk » Sat Jun 28, 2008 7:33 pm
brigs wrote:i cant seem to find apple x11 just the x11sdk.pkg
you didn't install X11 then if it's not there. reread the entire thread again and double check things.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby brigs » Sun Jun 29, 2008 9:33 pm
s.datamap'
/usr/bin/install -c -m 644 'vetable_12x12x3-029x.datamap' '/opt/local/share/MegaTunix/Gui/vetable_12x12x3-029x.datamap'
/usr/bin/install -c -m 644 'vetable_12x12x3.glade' '/opt/local/share/MegaTunix/Gui/vetable_12x12x3.glade'
/usr/bin/install -c -m 644 'vetable_12x12x2-MS-II.datamap' '/opt/local/share/MegaTunix/Gui/vetable_12x12x2-MS-II.datamap'
/usr/bin/install -c -m 644 'vetable_12x12x2.glade' '/opt/local/share/MegaTunix/Gui/vetable_12x12x2.glade'
/usr/bin/install -c -m 644 'vetable_8x8e.glade' '/opt/local/share/MegaTunix/Gui/vetable_8x8e.glade'
/usr/bin/install -c -m 644 'vetable_8x8e-BnG.datamap' '/opt/local/share/MegaTunix/Gui/vetable_8x8e-BnG.datamap'
/usr/bin/install -c -m 644 'vetable_8x8e-DT_1.datamap' '/opt/local/share/MegaTunix/Gui/vetable_8x8e-DT_1.datamap'
/usr/bin/install -c -m 644 'vetable_8x8e-DT_2.datamap' '/opt/local/share/MegaTunix/Gui/vetable_8x8e-DT_2.datamap'
/usr/bin/install -c -m 644 'warmupwizard.datamap' '/opt/local/share/MegaTunix/Gui/warmupwizard.datamap'
/usr/bin/install -c -m 644 'warmupwizard.glade' '/opt/local/share/MegaTunix/Gui/warmupwizard.glade'
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
sarah-kavalecs-computer:~/megatunix-0.9.16 sarah$
ok after battling i think i sort of get things now but not sure what to do now or if i have even done it right at all
what next i have tried to run megatunix but no go
brigs
Postby brigs » Sun Jun 29, 2008 10:17 pm
no megatunix but gauge designer works what did i miss
brigs
Postby djandruczyk » Mon Jun 30, 2008 4:23 am
brigs wrote:no megatunix but gauge designer works what did i miss
rerun make and copy any errors it had during compilation
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby brigs » Mon Jun 30, 2008 6:00 pm
Last login: Sun Jun 29 21:28:44 on ttyp2
Welcome to Darwin!
sarah-kavalecs-computer:~ sarah$ make
make: *** No targets specified and no makefile found. Stop.
sarah-kavalecs-computer:~ sarah$ cd megatunix-0.9.16
sarah-kavalecs-computer:~/megatunix-0.9.16 sarah$ ./configure--prefix=/opt/local-bash: ./configure--prefix=/opt/local: No such file or directory
sarah-kavalecs-computer:~/megatunix-0.9.16 sarah$ ./configure --prefix=/opt/local
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether ln -s works... yes
checking for gawk... (cached) awk
checking build system type... i386-apple-darwin8.11.1
checking host system type... i386-apple-darwin8.11.1
checking for a sed that does not truncate output... /usr/bin/sed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ld used by gcc... /usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld
checking if the linker (/usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld) is GNU ld... no
checking for /usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -p
checking how to recognize dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 196608
checking command to parse /usr/bin/nm -p output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fno-common
checking if gcc PIC flag -fno-common works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld) supports shared libraries... yes
checking dynamic linker characteristics... darwin8.11.1 dyld
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld
checking whether the g++ linker (/usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fno-common
checking if g++ PIC flag -fno-common works... yes
checking if g++ static flag -static works... no
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -lfl
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking whether make sets $(MAKE)... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking math.h usability... yes
checking math.h presence... yes
checking for math.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for string.h... (cached) yes
checking for strings.h... (cached) yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking for sys/stat.h... (cached) yes
checking for sys/types.h... (cached) yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking for unistd.h... (cached) yes
checking for pkg-config... /opt/local/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for GTK... yes
checking for GLEXT... yes
checking for LIBGLADE... yes
checking for LIBXML2... yes
checking whether byte ordering is bigendian... no
configure: creating ./config.status
config.status: creating megatunix.spec
config.status: creating Makefile
config.status: creating include/Makefile
config.status: creating mtxcommon/Makefile
config.status: creating mtxmatheval/Makefile
config.status: creating src/Makefile
config.status: creating gaugedesigner/resources.rc
config.status: creating gaugedesigner/Makefile
config.status: creating gaugedesigner/gauges/Makefile
config.status: creating gaugedesigner/gauges/Speco/Makefile
config.status: creating gaugedesigner/gauges/SportComp/Makefile
config.status: creating gaugedesigner/gauges/UltraLite/Makefile
config.status: creating gaugedesigner/gauges/Cobalt/Makefile
config.status: creating gaugedesigner/gauges/Impact/Makefile
config.status: creating gaugedesigner/gauges/Honda/Makefile
config.status: creating gaugedesigner/gauges/Ghost/Makefile
config.status: creating src/resources.rc
config.status: creating widgets/Makefile
config.status: creating dashdesigner/Makefile
config.status: creating dashdesigner/dashboards/Makefile
config.status: creating dashdesigner/resources.rc
config.status: creating ecu_snapshots/Makefile
config.status: creating LookupTables/Makefile
config.status: creating RealtimeMaps/Makefile
config.status: creating RuntimeSliders/Makefile
config.status: creating RuntimeStatus/Makefile
config.status: creating RuntimeText/Makefile
config.status: creating Interrogator/Makefile
config.status: creating Interrogator/Profiles/Makefile
config.status: creating Gui/Makefile
config.status: creating MegaTunix.iss
config.status: creating WIN_NOTES.txt
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
sed: 1: "s/$(DEPDIR)/${subdirs}/ ...": bad flag in substitute command: '.'
Configuration:
Install Path: /opt/local
Using Cairo: yes
General Debugging: no
Profiling: no
sarah-kavalecs-computer:~/megatunix-0.9.16 sarah$ make
make all-recursive
Making all in include
make[2]: Nothing to be done for `all'.
Making all in mtxmatheval
Making all in mtxcommon
Making all in widgets
Making all in src
Making all in gaugedesigner
Making all in gauges
Making all in Speco
make[4]: Nothing to be done for `all'.
Making all in SportComp
Making all in UltraLite
Making all in Cobalt
Making all in Impact
Making all in Honda
Making all in Ghost
make[4]: Nothing to be done for `all-am'.
make[3]: Nothing to be done for `all-am'.
Making all in dashdesigner
Making all in dashboards
make[3]: Nothing to be done for `all'.
Making all in ecu_snapshots
Making all in Interrogator
Making all in Profiles
Making all in LookupTables
Making all in RealtimeMaps
Making all in RuntimeSliders
Making all in RuntimeStatus
Making all in RuntimeText
Making all in Gui
brigs
Postby djandruczyk » Mon Jun 30, 2008 8:19 pm
ok, it looks like everything should have compiled.
just for the hell of it try "sudo make install" (if it prompts for a password, use the password u type in to login to your system) from the megatunix-0.9.16 dir again.. Also even if that doesn't work, "cd" into the "src" directory and try to run megatunix with "./megatunix" and see if it runs or errors out with a "things aren't installed correctly" warning.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby brigs » Tue Jul 01, 2008 12:58 am
i did re run the install and nothing has changed it never came up with any error's but i am also not sure what to do or what you mean cd or src or how it should be entered
brigs
Postby djandruczyk » Tue Jul 01, 2008 5:07 pm
brigs wrote:i did re run the install and nothing has changed it never came up with any error's but i am also not sure what to do or what you mean cd or src or how it should be entered
http://mally.stanford.edu/~sr/computing/basic-unix.html
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby soloracer » Mon Jul 21, 2008 10:51 am
Hello,
I have not yet attempted to install Megatunix but I'm wondering: At this point is DarwinPorts still recommended or is MacPorts the way to go? I have a G4 Powerbook with 10.4 if it matters.
soloracer
Postby djandruczyk » Mon Jul 21, 2008 5:25 pm
soloracer wrote:Hello,
Right now I'd try macports first. I don't have access to my MAC to test any longer as it's packed away for a move.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Re:
Postby Gimpster » Tue Jul 22, 2008 9:55 pm
I ran into this just now too.
For those seeing this error, it appears that Macports 1.6.0 doesnt put /opt/local/bin into your path. Use the following to fix it, and for a permanent fix ... add it to your profile, and I would recommend doing that. I added this same line to the bottom of /etc/bashrc (you'll have to be root/sudo to edit it) :
Code: Select all
PATH=$PATH:/opt/local/bin
Do in addition to this, which was already mentioned by the author:
Code: Select all
export LDFLAGS=-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
It then compiled and runs fine on an Intel 10.5.3, w/Xcode 3.1 and Macport 1.6.0 :) Hope this helps somebody....
THANKS for the great app, I was really tired of using this crappy 486 I had w/MegaTune.
MrMiracle wrote:So close, and yet so far.
I started with the original instructions, everything has seemed to work just fine so far until I get to the last two lines:
make
and I get:
make: no targets specified and no makefile found. Stop.
Last couple of lines from the previous step (if it helps) as follows:
checking for GTK... no
checking for GTK... configure: error: Package requirements (gtk+-2.0 >= 2.4.0 gthread-2.0) were not met:
No package 'gtk+-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables GTK_CFLAGS
and GTK_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
1993 Toyota MR2 - V6 Powered
Gimpster
Re: Re:
Postby krwright » Wed Jul 23, 2008 8:39 pm
Gimpster wrote:I ran into this just now too.
Code: Select all
Code: Select all
Just for reference, I just installed MegaTunix 0.9.17 on a MacBook Pro with 10.5.4, XCode 3.1, MacPorts 1.6.0. All I did was set the PATH; the LDFLAGS bit wasn't needed. I can see GaugeDesigner and MegaTunix in /opt/local/bin, and I got no errors that I could see on make,but I can't test because my X11 seems to be fouled up at the moment. It just does nothing when I double-click X11. I'll report back when I have a chance to reinstall.
FWIW, I set the path variable in bashrc before I did anything else, then followed the MacPorts Guide to install MacPorts, then followed the directions at the beginning of this thread (update, install gtk and glade, config, make, make) and that was it.
EDIT: fixing quote tags.
Kevin Wright krwright@sbcglobal.net
Dallas/Ft. Worth, TX http://www.wankel.net/~krwright/cars/cars.html
A pile of first-gen RX-7s and a '70 Cutlass Sports Coupe
krwright
Postby krwright » Fri Jul 25, 2008 3:03 pm
It worked. I installed a newer version of X-Windows from the Darwin Project while I was at it. Finally figured out how to add /opt/local/bin to the X11 terminal PATH as well. It douesn't work if you just add it to .bashrc, you have to add a line to export the added path in your .profile:
Code: Select all
export PATH=$PATH:/opt/local/bin
Now to once again get the Prolific USB-serial adapter functioning.
krwright
Postby Gimpster » Fri Jul 25, 2008 7:29 pm
I'm also running the XQuartz X11. It's usually a few steps ahead of whatever Apple has out.
Thanks for the tip on X11 path, I was getting tired of opening terminal :) I'm kinda new to OSX, and truth be told.... I'm using it on an IBM branded laptop :lol:
Gimpster
Postby damogti » Thu Nov 13, 2008 12:42 pm
Hi I've followed the steps up to downloading the Megatunix and storing it in my home directory. However when I go to do the next step I get this error in the terminal window. I have no knowledge of unix so all this is new to me and I find this a bit confusing.
Last login: Thu Nov 13 18:47:45 on ttys000
damian-packers-macbook-pro:~ damianpacker$ tar xvzf megatunix-0.9.17
tar (child): megatunix-0.9.17: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
Any help would be good.
damogti
Postby damogti » Thu Nov 13, 2008 12:45 pm
oh forgot to add i'm using a mac book pro.
damogti
Postby djandruczyk » Fri Nov 14, 2008 2:44 pm
damogti wrote:Hi I've followed the steps up to downloading the Megatunix and storing it in my home directory. However when I go to do the next step I get this error in the terminal window. I have no knowledge of unix so all this is new to me and I find this a bit confusing.
The docs said to hit the "tab" key afterwards so the shell would finish the files name..
The package name is most likely something like: megatunix-0.9.17.tar.gz, hitting tab would havethe shell finish out the rest of hte filename for you.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby damogti » Sun Nov 16, 2008 8:11 am
Hi I did hit tab and thats what it put in there I'll try manually putting the tar extension on and see what happens. In my home directory I have: Megatunix-0.9.17 2 folder and a megatunix-0.9.17.tar I'm not sure if I downloaded the right file from the two listed on the site so I'll fill in the command manually and see what happens. Also do I have to type all the commands written on the instructions in one line before hitting enter?
Damo
damogti
PreviousNext
Return to Megatunix (obsolete)
