How to Install MegaTunix on Ubuntu Linux (all versions)
Moderator: djandruczyk
Did this make any sense to you?
Yes, completely, worked without a problem!
16
80%
No, not at all, what the hell is linux anyways?
1
5%
Kinda, but I got lost partway through, help me!
2
10%
My kid did it and explained it all to me...
0
No votes
I didn't even bother as it looks too hard...
1
5%
Total votes : 20
Postby djandruczyk » Tue Feb 20, 2007 3:12 pm
Here's a pretty thorough HOWTO to get megatunix installed and working on Ubuntu.
Prereq's:
1. Need an ubuntu CD (Alternate or desktop CD should work)
2. Need a broadband connection (for updates and needed packages)
3. Need a computer with a free disk partition, or enough free space to shrink an existing partition (backup first!), OR vmware-player or VirtualBox to install it into a virtual machine (allows using linux on windows), setting up vmware-player or VirtualBox (http://virtualbox.org) to do this is beyond the scope of this document but I can assist users if requested.
First, install ubuntu. (stick in CD, boot off of it, Double Click the "Install" Icon in the gui follow prompts until done, it's pretty easy that an 8-18 year old should have little trouble with that part, if you get confused, call a neighborhood kid over to help you)
Next part. Login to your ubuntu install.
Then, open a Terminal (Go to top panel, upper left, it's under the Applications menu. in the Accessories submenu)
In this terminal run
Code: Select all
sudo apt-get update
. It'll prompt you for a password, its the same one as you logged in with. This will bring your system up to date with the package repositories (known as "repos") on the internet.
Now run
Code: Select all
sudo apt-get upgrade
. This may prompt you to download a bunch of updates (all the updates since the version of ubuntu you installed was released) Hit "Y" for Yes and let it finish. Now I recommend rebooting, ONLY because the update might install a new C library(what EVERY last thing on the box depends on) and the old one is still cached in ram, so a reboot will make sure nothing breaks, so logout and reboot, via clicking on the System menu, and selecting "Quit" and then selecting "Restart Computer".
Once it comes back up, relogin and open a terminal again. (Applications->Accessories->Terminal)
Now we install all the stuff megatunix needs in one shot.
run this:
Code: Select all
sudo apt-get install pkg-config libtool intltool libgtkglext1-dev g++ gcc flex bison glade-gnome-2 libglade2-dev make git-core gdb automake1.9
NOTE: For Ubuntu 9.10 and newer, use this line instead:
Code: Select all
sudo apt-get install pkg-config libtool intltool libgtkglext1-dev g++ gcc flex bison glade libglade2-dev make git-core gdb automake1.9
It'll prompt you for download a block of stuff, hit Y and got have a cup of coffee or a beer, or a smoke, or whatever floats your boat.
OK, you've gotten everything installed needed to compile megatunix from source or Git.
Downloading and compiling a MegaTunix tarball
Run the Firefox browser and go to http://sourceforge.net/projects/megatunix scroll down and download the latest version (0.9.23 is up there now as of this writing)
Firefox will ask you if you want to open the file with an application or to Save to Disk. Select "Save to disk". Firefox by default puts everything on your desktop, so in that same terminal run
Code: Select all
cd ~/Desktop
and it'll take you there (for those who aren't unix people, "~/" or tilde-slash, means your Home directory, which for me is /home/dave in the filesystem hiearchy)
If you do an "ls" (list files, equal to "dir" on DOS/windows) you should see
Code: Select all
megatunix-0.x.y.tar.gz
(replace x.y with the version you DL'd). Run
Code: Select all
tar xvzf megatunix-x.y.z.tar.gz
*replace the x.y.z with the version number of the one you got" to untar it.
"cd" (change directory) into the megatunix dir,
Code: Select all
cd megatunix-0.<TAB> then <ENTER>
(Linux has what's known as "tabkey completion" hitting tab when typing in a long name will attempt to finish it if the name is unique, try it) and run
Code: Select all
./configure ; make
It should complete in a couple minutes. When it is cone compiling run
Code: Select all
sudo make install
followed by
Code: Select all
sudo ldconfig
and it's installed on your system and ready for use.
END of procedure for users NOT wanting to use Git
Downloading and compiling MegaTunix from Git
To get a copy from Git run these commands:
Code: Select all
cd
mkdir git
cd git
For git, what you are going to do is to "checkout" a "working copy" from the repository stored on the github.com servers. You ONLY need to check it out once, once you have it you update with a single command below. When I make a change on my main system, I commit it to the repository. Users would then be able to run one command to get all my changes and their SOURCE tree would be completely up to date. It's good for users who want to get the very latest of megatunix in between releases (bugfixes or new features)
Anonymous Git procedure below:
Code: Select all
git clone git://github.com/djandruczyk/MegaTunix.git
Compiling a Git checkout of MegaTunix
Code: Select all
cd ~/git/MegaTunix
./autogen.sh
make
If that succeeds without dying run:
Code: Select all
sudo make install
Code: Select all
sudo ldconfig
It's now READY to RUN!!!
Now, if you want to keep up to date with changes as I commit them in between releases, that's even easier..
just cd into the MegaTunix directory:
Code: Select all
cd ~/git/MegaTunix
and update your Git to current
Code: Select all
 git pull
otherwise
then rebuild;
Code: Select all
./autogen.sh ; make clean ; make ; sudo make install ; sudo ldconfig
[/b]
And you're up to date and running on the bleeding edge
To run MegaTunix, you should be able to run "megatunix" from any open terminal, or you can create a new icon (or launcher) on the desktop, though having it run from a terminal will show you output that might otherwise not be visible.
It sounds long and hard but in practice it really isn't.
NOTE about serial ports:
Under linux (and most unix's in general) all device drivers are accessed through "files" (In Unix/Linux basically EVERYTHING is a file) in a directory called /dev (or /devices on sun) Serial ports are known typically as /dev/ttySx with x being a number starting from 0 and going up. (/dev/ttyS0 = COM1 on windows, /dev/ttyS1 is COM2 and so on) For those of you with USB to serial adapters, they are usually named a little bit differently, typically /dev/ttyUSBx with x starting and 0 and going up. On MAC OS-X there tends to be multiple devices per serial port (because OS-X is based on the BSD codebase), /dev/ttyS's and /dev/cuax's. In megatunix's case you want the cua device instead of the tty one as some users have reported that the cua one worked but the tty one did NOT as the CUA one is a "raw callout device" and not just a text device (like os-X consider's some of it's tty's to be)
So, in megatunix the first thing most users need to change is the serial port, and that's on the "General" tab. The text will change from to red when you've made a change but NOT committed it (gotta hit enter to make megatunix try that device, notice the status messages below that box as it'll say if the device could be opened or not. Watch the titlebar for feedback as well. If you found an open port but no ECU, make sure that your ECU is powered up, and that you're actually using the right port (many computers have two serial ports), so try the other one just in case..
Enjoy!
David J. Andruczyk
MegaTunix Author
Updated 05/19/2012
Reason: upped default version
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby OpelCrazy » Wed Feb 21, 2007 2:13 am
d*** needed this like a week ago but managed to sort it anyway :D
OpelCrazy
Postby MegaScott » Tue Mar 06, 2007 11:29 am
First of all I would like to thank Dave for such a great program Megatunix has turned out to be, Also for taking the time to write these installation instructions. Thanks Dave!
I have been using the Windows version of Megatunix without a hitch for a little while, using MS1 and MSnS-extra 29v, I like the many different Graphical gauges that are available, among other features not available with Megatune. I really wanted to try out the *nix version of Megatunix as well.
My company has a licensing agreement with VMware which allows me to use it at home, so I have installed VMware workstation on my PC and installed many precanned VM's as well as other novelties such as Microsoft Vista and other stuff including Ubuntu Linux. I could have used Microsoft virtual PC which is now free, or Virtual box, also free. Personally I like the VMware drivers better so that's what I use.
To start I had Ubuntu 5.10 "Breezy Badger" already installed as a VM and even though the install instructions are written for Ubuntu V6.10, they worked just fine, of course with the exception of the update part which is a different update depository, no big deal even an inexperienced at unix guy like me figured that out. The rest of the Megatunix install went without a hitch.
I downloaded the 6.10 version of Ubuntu and installed that in a VM as well, the installation of Megatunix is exactly as Dave describes in the instructions, which by the way are very well written for a non-unix person like me to be able to install without a hitch. Now I can transfer the VM over to my laptop and run it on there, all setup and preconfigured with Megatunix!!
Thanks again, Dave!!
Now there's a link on the Megatunix sourceforge site directly to this tutorial!!
Cheers!
MegaScott
MS/Extra Guru
Postby jpbturbo » Sun Apr 08, 2007 12:57 pm
I just installed Megatunix on Xubuntu 6.10 and everything went great just following the instructions.
Now I have no reason to be tempted to put windoze on this laptop at all.
'84 volvo 242ti/soon to be MSnS-E
R.I.P. '83 volvo wagon/MSnS-E
jpbturbo
Postby Maglin » Mon Jul 02, 2007 10:28 pm
Well you got my Linux bug active again. I tried 7.04 but the boot loader won't install. Seems like a lot of people are having same issue. So I'm installing 6.06.1 (edgy) I think it's called. Seems like chipset issues as far as 7.04 and being able to write to the MBR. I'm going to be installing the CVS build and will be awaiting MSIIextra support. I'll definitely be the first to test it out once you have something you think works. :)
Jeremiah
93 5.8 LX Mustang - MSIIextra
92 Eagle Talon TSI AWD Turbo - MSIIextra
Maglin
Postby rb26dett » Tue Jul 03, 2007 2:48 am
ummm, kernel versions can have driver/chipset bugs(more likely that the chipset itself is flawed though), grub can have bugs, lilo can have bugs, but its not really right to say that an ubuntu meta distribution has issues in that way. pm me with the issues you were having if you like maybe it can be sorted.
fred.
ms2,v3,cop,innovate,mazda fe3/fe-dohc 2l 4cyl with stock 10:1 pistons,4 stock coils,4 stock ignitors,rx7 550cc injectors maxed@6600rpm&17psi,custom everything,holset he351cw turbo,44mm ext gate,nis gtr bovs,nis gtr intercooler,70mm lexus throttle,chinese fpr,10may v2 ms2e alpha code
rb26dett
Postby Maglin » Tue Jul 03, 2007 6:46 am
got Fiesty 7.04 installed finally. GRUB wouldn't install properly. On either Fiesty or Edgy. Their is numerous others that are having the same issues. Well I finally got it installed and now installing programs and Megatunix.
Edit: Just installed Megatunix with the CVS. Excellent program. i've seen pics of it before but it's really something. Can't wait to play with it on the MSII.
Jeremiah
Maglin
Postby kameron » Tue Nov 13, 2007 8:40 pm
i'm running gutsy and installed your latest tar.gz
my usb is working fine for other devices
tried to connect to MS today MSnSE 029yx firmware
cycled through all ttySOx and ttyUSBx from 0-10 no luck
using a serial > usb adapter
anything else i should try? i'm on a newer dual core pentium laptop.
kameron
Postby djandruczyk » Wed Nov 14, 2007 3:57 pm
kameron wrote:i'm running gutsy and installed your latest tar.gz
If you used the latest 0.9.15) it should have auto-scanned.
What does your device normally show up as ? common names are /dev/ttyUSB0
If you have an oddball name (some keyspan adapters use funky names) You can try editing megatunix's main config file ~/.MegaTunix/config and adding those potential names to the "potential_ports" line.
Also if the perms of the device don't allow you to open it for writing, it'll also fail. (ls -al /dev/ttyUSB0)
for me I see:
Code: Select all
dave@shrapnel:~/.MegaTunix$ ls -la /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 0 2007-11-14 18:47 /dev/ttyUSB0
My account is in the dialout group, hence I have RW access to the device.
dave@shrapnel:~/.MegaTunix$ id dave
uid=1000(dave) gid=1000(dave) groups=1000(dave),4(adm),20(dialout),24(cdrom),25(floppy),29(audio),30(dip),44(video),46(plugdev),100(users),104(scanner),110(lpadmin),111(admin),1001(vboxusers),122(pulse),123(pulse-access),124(pulse-rt),125(uml-net)
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby höylä » Thu Mar 13, 2008 3:29 pm
thanks for help... :RTFM:
höylä
Postby squirrelgripper » Sun Apr 13, 2008 12:07 am
Dave, I'm getting an error when I try to "make" the file per your directions (see below), I'm new to Linux (this is Ubuntu 7.10 ), I could use some coaching if you have the time.
Iain
squirrelgripper@squirrelgripper-desktop:~/Desktop/megatunix-0.9.15$ ./configure ; make
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking for C compiler default output file name...
configure: error: C compiler cannot create executables
See `config.log' for more details.
make: *** No targets specified and no makefile found. Stop.
s
squirrelgripper
Postby djandruczyk » Sun Apr 13, 2008 8:21 am
squirrelgripper wrote:Dave, I'm getting an error when I try to "make" the file per your directions (see below), I'm new to Linux (this is Ubuntu 7.10 ), I could use some coaching if you have the time.
Iain
s
Looks like you missed the all important step. NOTE: This requires an internet connection to get the required packages.
Code: Select all
sudo apt-get install libgtkglext1-dev g++ gcc flex bison glade-gnome-2 libglade2-dev make cvs gdb automake1.9
Run that , then retry with compiling megatunix.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby squirrelgripper » Sun Apr 13, 2008 12:23 pm
djandruczyk wrote:[
Code: Select all
Thanks Dave! That did it - terrific looking software!
squirrelgripper
Postby djandruczyk » Sun Apr 13, 2008 12:47 pm
djandruczyk wrote:[
Code: Select all
sure no problem. just wait till the next release (by the end of this week for the megameet 2008). which has a bunch of new gauges (two new full sets so far, one more set expected soon) and a couple more dash designs, as well as partial MS-2 (B&G) support. (dash works, VE, Spark,AFR,Warmup tables all completed and working.) I hope to have ms-2 support more complete before release though..
David J. Andruczyk
djandruczyk
MS/Extra Guru
Re: How to Install MegaTunix on Ubuntu Linux (7.x/8.x)
Postby suberimakuri » Sun Sep 14, 2008 8:57 pm
Hi Dave,
I've used your software in the past and it's worked great, thank you!
Unfortunately I'm having a couple problems here on a new Core 2 Duo laptop.. Ubuntu 8.10 amd64.. Downloaded tarball from Sourceforge
./configure is fine... but then when I try make, I get the following:
Code: Select all
 thermistor.o -MD -MP -MF ".deps/thermistor.Tpo" -c -o thermistor.o thermistor.cpp; \
   then mv -f ".deps/thermistor.Tpo" ".deps/thermistor.Po"; else rm -f ".deps/thermistor.Tpo"; exit 1; fi
thermistor.cpp: In member function ‘void thermistor::modify_s19_file(char*)’:
thermistor.cpp:160: error: ‘strlen’ was not declared in this scope
thermistor.cpp:162: error: ‘strncpy’ was not declared in this scope
thermistor.cpp:186: error: ‘exit’ was not declared in this scope
thermistor.cpp:189: error: ‘strncmp’ was not declared in this scope
make[2]: *** [thermistor.o] エラー 1
make[2]: ディレクトリ `/......../megatunix-0.9.17/src' から出ます
make[1]: *** [all-recursive] エラー 1
make[1]: ディレクトリ `/......../megatunix-0.9.17' から出ます
make: *** [all] エラー 2
So I tried the CVS version but unfortunately it was the same...
Any ideas?
Cheers
suberimakuri
Postby djandruczyk » Tue Sep 16, 2008 4:01 pm
Karl_Skewes wrote:Hi Dave,
Code: Select all
Any ideas?
Cheers
This seems to be a recent GCC issue. I found a potential fix and committed it to CVS. if you don't want (or know how) to use the latest CVS branch, change
#include <string>
to
#include <cstring>
in thermistor.cpp
and rerun make
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby suberimakuri » Tue Sep 16, 2008 8:26 pm
great, thanks for the quick reply!
will grab a new copy from cvs and try again tonight.
Cheers!
suberimakuri
Postby suberimakuri » Thu Sep 18, 2008 4:54 am
unfortunately even after grabbing new CVS it failed with the same error.
So I tried changing thermistor.cpp to <cstring> from <string>
this gave me
Code: Select all
O2 -MT thermistor.o -MD -MP -MF .deps/thermistor.Tpo -c -o thermistor.o thermistor.cpp
make[2]: ディレクトリ `/......../megasquirt/cvs/MegaTunix/src' から出ます
make[1]: ディレクトリ `/........./megasquirt/cvs/MegaTunix' から出ます
any ideas?
suberimakuri
Postby djandruczyk » Thu Sep 18, 2008 5:31 am
Karl_Skewes wrote:unfortunately even after grabbing new CVS it failed with the same error.
this gave me
Code: Select all
any ideas?
where you added "#include <cstring>"
add the following:
Code: Select all
#include <cstdlib>
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby suberimakuri » Thu Sep 18, 2008 6:22 am
sweet, that did it (cstdlib), should have thought of that one myself. :roll:
suberimakuri
Next
Return to Megatunix (obsolete)
