I download and install version 0.9.9 on Windows XP. Default port in Megatunix is COM1 but I have MS on COM2. i tried to change COM1 to COM2 but with no success. Whenever I do change to Com port field, letters are red. Everytime when I click on Test ECU communication button, Megatunix checking COM1.
Please help
COM issue
Moderator: djandruczyk
- MS/Extra Guru
Re: COM issue
For one, MegaTunix does NOT YET support MS-2. and for two when you type in com2, you MUST HIT ENTER to commit it and then it'll change ports.Mickey038 wrote:Hi,
Please help
About the only thing MegaTunix as of 0.9.9 will be able to do is do a comms test and tell you if the ecu is there or not (don't forget to set the baud correctly)
David J. Andruczyk
