When i enter values such as 1, 2, and 5 for ignition retard, max retard, etc. the values are converted to .35 1.7 and other odd numbers.
I'm using winxp and msns w/ high res code.
Thanks.
knock / boost values
Moderator: djandruczyk
90 VW 16v Jetta - MSnS-Extra, current msq, setup, and pics http://www.msruns.com/viewtopic.php?t=22406
- MS/Extra Guru
Re: knock / boost values
This is normal. MegaTunix allows FULL resolution of the values, megatune truncates them. the resolution of most angle related controls is 0.352 degrees. +/- or q/w will allow you to move them by their normal increments, as if you type in value it will try and pick the closest (and it sometimes does a weird job).chadr wrote:When i enter values such as 1, 2, and 5 for ignition retard, max retard, etc. the values are converted to .35 1.7 and other odd numbers.
Thanks.
David J. Andruczyk
