can any one suggest a good cheep itx setup that will be a good system for megatunix for a mounted tuning solution?
after trying megatunix i think it would be sick to run a box in the dash for music and tuning im also looking at a 8 inch touch screen
not sure if im going xp or linux just yet
itx computer
Moderator: djandruczyk
- MS/Extra Guru
Re: itx computer
jacobrussell wrote:can any one suggest a good cheep itx setup that will be a good system for megatunix for a mounted tuning solution?
itx and cheap don't necessarily go together..
try here to start:
http://www.mini-box.com/s.nl/sc.8/category.101/.f
use google ("itx motherboards" as a search string)
you'll want at least a 1024 x768 screen res however. 800.600 will work , but it requires scrolling which is a PITA.
David J. Andruczyk
