How to install new firmware from Linux/OS-X systems
Moderator: djandruczyk
Re: How to install new firmware from Linux/OS-X systems
Postby djandruczyk » Tue Aug 21, 2012 12:40 pm
jsmcortina wrote:What is locked about the MS3 bootloader?
Your loader is closed source, last I heard it wasn't going to be "open", hence it was basically blocked from use for third parties for the time being until someone reverse engineered the available loading tool.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby bi-andrea » Wed Aug 22, 2012 6:08 am
I tried everything, but I do not want to know about loading the firmware into the MS2
I can not install it and then subsequently mapping ...
megatunix firmware loader
Code: Select all
Firmware file successfully opened
Attempting Wakeup...
Serial Read failure, try unplugging
and replugging your Serial adapter/cable
ms2extra_3.2.1_release/ms2dl_linux32bit -f /home/andrea/Downloads/ms2extra_3.2.1_release/bootstrap.s19 -c /dev/ttyS0
Code: Select all
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Could not wake up processor, exiting...
msloader ms2 /dev/ttyS0 /home/andrea/Downloads/ms2extra_3.2.1_release/bootstrap.s19
Code: Select all
MegaTunix msloader 0.9.24
Port successfully opened
select() (read) timeout, attempts 0!
select() (read) timeout, attempts 1!
select() (read) timeout, attempts 2!
select() (read) timeout, attempts 3!
select() (read) timeout, attempts 4!
Error reading error/status/prompt Code
requested 3 bytes got 0
Unable to wakeup device!
Check to make sure it's present
ports
lsusb
Code: Select all
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 041: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 001 Device 040: ID 0409:0059 NEC Corp. HighSpeed Hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
dmesg | grep ttyS*
Code: Select all
[    0.004000] console [b][tty0] enabled[/b]
[    1.701978] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.702167] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    1.702925] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.703235] 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
speech same even with the adapter usb>serial
bi-andrea
Postby bi-andrea » Thu Aug 23, 2012 1:38 pm
I could not understand where the problem is, they were not well soldered circuits and therefore did not give the right contacts.
For now I have to fix the unit, after I will work on megatunix
bi-andrea
Postby djandruczyk » Thu Aug 23, 2012 2:57 pm
bi-andrea wrote:I tried everything, but I do not want to know about loading the firmware into the MS2
Code: Select all
Code: Select all
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Error code 0x00
Prompt was
Code: Select all
ports
lsusb
Code: Select all
dmesg | grep ttyS*
Code: Select all
USB serial adapters on linux are 99% ALWAYS /dev/ttyUSBn, where n starts and 0 and goes up for each adapter.
/dev/ttyS0 and /dev/ttyS1 are the ONBOARD hardware serial ports, as shown based on your dmesg output, first off they are detected withen 2 seconds of the kernel starting up (WELL BEFORE the usb interfaces are up and probed), and second they list the io port and IRQ (3f8/2f8 irq 3/4) which correspond to the hardware ports (COM1/COM2 in dos/windows or ttyS0 and ttyS1 in linux), even if you don't have a connector on the back of your computer, the motherboard might have a header thats just not connected to a DB-9 connector.
Try:
Code: Select all
 ls -l /dev/ttyUSB* ; sudo msloader /dev/ttyUSB0 /home/andrea/Downloads/ms2extra_3.2.1_release/bootstrap.s19
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby jsmcortina » Thu Aug 23, 2012 3:28 pm
Agreed on the port naming. The USB serial adapters on my Linux box are all /dev/ttyUSB....
Something that might be worth trying, try the linux loader that comes in the 3.2.4 beta firmware release. This isn't the very latest version but it does auto-scan the serial ports on your computer and might detect what's needed. See http://www.msextra.com/forums/viewtopic.php?f=101&t=45718
(Heads up to DaveA, I do plan on making this the "stable release" soon.)
Postby bi-andrea » Fri Aug 24, 2012 5:43 am
thanks for the advice guys!
I was able to load the firmware with mtxloader
Code: Select all
Cold reset detected, s=0x08
Erasing main flash!
Main Flash Erased...
Sending record 0:     0
Skipping block 0000
Sending record 10:  c050
Sending record 20:  c0f0
Sending record 30:  c190
Sending record 40:  c230
Sending record 50:  c2d0
Sending record 60:  c370
Sending record 70:  c410
Sending record 80:  c4b0
Sending record 90:  c550
Sending record 100:  c5f0
Sending record 110:  c690
Sending record 120:  c730
Sending record 130:  c7d0
Sending record 140:  c870
Sending record 150:  c910
Sending record 160:  c9b0
Sending record 170:  ca50
Sending record 180:  caf0
Sending record 190:  cb90
Sending record 200:  cc30
Sending record 210:  ffc0
Wrote 3392 bytes
Remove boot jumper if jumpered and power cycle ECU
All Done!
Erasing main flash!
Sending record 0:     0
Skipping block 0000
Wrote 3392 bytes
All Done!
Erasing main flash!
Sending record 0:     0
Skipping block 0000
Wrote 3392 bytes
All Done!
Erasing main flash!
Sending record 0:     0
Skipping block 0000
Sending record 10:  4090
Sending record 20:  4130
Sending record 30:  41d0
Sending record 40:  4270
Sending record 50:  4310
Sending record 60:  43b0
Sending record 70:  4450
Sending record 80:  44f0
Sending record 90:  4590
Sending record 100:  4630
Sending record 110:  46d0
Sending record 120:  4770
Sending record 130:  4810
Sending record 140:  48b0
Sending record 150:  4950
Sending record 160:  49f0
Sending record 170:  4a90
Sending record 180:  4b30
Sending record 190:  4bd0
Sending record 200:  4c70
Sending record 210:  4d10
Sending record 220:  4db0
Sending record 230:  4e50
Sending record 240:  4ef0
Sending record 250:  4f90
Sending record 260:  5030
Sending record 270:  50d0
Sending record 280:  5170
Sending record 290:  5210
Sending record 300:  52b0
Sending record 310:  5350
Sending record 320:  53f0
Sending record 330:  5490
Sending record 340:  5530
Sending record 350:  55d0
Sending record 360:  5670
Sending record 370:  5710
Sending record 380:  57b0
Sending record 390:  5850
Sending record 400:  58f0
Sending record 410:  5a50
Sending record 420:  c050
Sending record 430:  c0f0
Sending record 440:  c190
Sending record 450:  c230
Sending record 460:  c2d0
Sending record 470:  c370
Sending record 480:  c410
Sending record 490:  c4b0
Sending record 500:  c550
Sending record 510:  c5f0
Sending record 520:  c690
Sending record 530:  c730
Sending record 540:  c7d0
Sending record 550:  c870
Sending record 560:  c910
Sending record 570:  c9b0
Sending record 580:  ca50
Sending record 590:  caf0
Sending record 600:  cb90
Sending record 610:  cc30
Sending record 620:  ccd0
Sending record 630:  cd70
Sending record 640:  ce10
Sending record 650:  ceb0
Sending record 660:  cf50
Sending record 670:  cff0
Sending record 680:  d090
Sending record 690:  d130
Sending record 700:  d1d0
Sending record 710:  d270
Sending record 720:  d310
Sending record 730:  d3b0
Sending record 740:  d450
Sending record 750:  d4f0
Sending record 760:  d590
Sending record 770:  d630
Sending record 780:  d6d0
Sending record 790:  d770
Sending record 800:  d810
Sending record 810:  d8b0
Sending record 820:  d950
Sending record 830:  d9f0
Sending record 840:  da90
Sending record 850:  db30
Sending record 860:  dbd0
Sending record 870:  dc70
Sending record 880:  dd10
Sending record 890:  ddb0
Sending record 900:  de50
Sending record 910:  def0
Sending record 920:  df90
Sending record 930:  e030
Sending record 940:  e0d0
Sending record 950:  e170
Sending record 960:  e210
Sending record 970:  e2b0
Sending record 980:  e350
Sending record 990:  e3f0
Sending record 1000:  e490
Sending record 1010:  e530
Sending record 1020:  e5d0
Sending record 1030:  e670
Sending record 1040:  e710
Sending record 1050:  e7b0
Sending record 1060:  e850
Sending record 1070:  e8f0
Sending record 1080:  e990
Sending record 1090:  ea30
Sending record 1100:  ead0
Sending record 1110:  eb70
Sending record 1120:  ec10
Sending record 1130:  ecb0
Sending record 1140:  ed50
Sending record 1150:  edf0
Sending record 1160:  ee90
Sending record 1170:  ef30
Sending record 1180:  efd0
Sending record 1190:  f070
Sending record 1200:  f110
Sending record 1210:  f1b0
Sending record 1220:  f250
Sending record 1230:  f2f0
Sending record 1240:  f390
Sending record 1250:  f430
Sending record 1260:  f4d0
Sending record 1270:  f570
Sending record 1280:  f610
Sending record 1290:  f6b0
Sending record 1300:  ff80
Setting page to 0x38:
Erasing page 0x38:
Page 0x38 erased...
Sending record 1310:388020
Sending record 1320:3880c0
Sending record 1330:388160
Sending record 1340:388200
Sending record 1350:3882a0
Sending record 1360:388340
Sending record 1370:3883e0
Sending record 1380:388480
Sending record 1390:388520
Sending record 1400:3885c0
Sending record 1410:388660
Sending record 1420:388700
Sending record 1430:3887a0
Sending record 1440:388840
Sending record 1450:3888e0
Sending record 1460:388980
Sending record 1470:388a20
Sending record 1480:388ac0
Sending record 1490:388b60
Sending record 1500:388c00
Sending record 1510:388ca0
Sending record 1520:388d40
Sending record 1530:388de0
Sending record 1540:388e80
Sending record 1550:388f20
Sending record 1560:388fc0
Sending record 1570:389060
Sending record 1580:389100
Sending record 1590:3891a0
Sending record 1600:389240
Sending record 1610:3892e0
Sending record 1620:389380
Sending record 1630:389420
Sending record 1640:3894c0
Sending record 1650:389560
Sending record 1660:389600
Sending record 1670:3896a0
Sending record 1680:389740
Sending record 1690:3897e0
Sending record 1700:389880
Sending record 1710:389920
Sending record 1720:3899c0
Sending record 1730:389a60
Sending record 1740:389b00
Sending record 1750:389ba0
Sending record 1760:389c40
Sending record 1770:389ce0
Sending record 1780:389d80
Sending record 1790:389e20
Sending record 1800:389ec0
Sending record 1810:389f60
Sending record 1820:38a000
Sending record 1830:38a0a0
Sending record 1840:38a140
Sending record 1850:38a1e0
Sending record 1860:38a280
Sending record 1870:38a320
Sending record 1880:38a3c0
Sending record 1890:38a460
Sending record 1900:38a500
Sending record 1910:38a5a0
Sending record 1920:38a640
Sending record 1930:38a6e0
Sending record 1940:38a780
Sending record 1950:38a820
Sending record 1960:38a8c0
Sending record 1970:38a960
Sending record 1980:38aa00
Sending record 1990:38aaa0
Sending record 2000:38ab40
Sending record 2010:38abe0
Sending record 2020:38ac80
Sending record 2030:38ad20
Sending record 2040:38adc0
Sending record 2050:38ae60
Sending record 2060:38af00
Sending record 2070:38afa0
Sending record 2080:38b040
Sending record 2090:38b0e0
Sending record 2100:38b180
Sending record 2110:38b220
Sending record 2120:38b2c0
Sending record 2130:38b360
Sending record 2140:38b400
Sending record 2150:38b4a0
Sending record 2160:38b540
Sending record 2170:38b5e0
Sending record 2180:38b680
Sending record 2190:38b720
Sending record 2200:38b7c0
Sending record 2210:38b860
Sending record 2220:38b900
Sending record 2230:38b9a0
Sending record 2240:38ba40
Sending record 2250:38bae0
Sending record 2260:38bb80
Sending record 2270:38bc20
Sending record 2280:38bcc0
Setting page to 0x39:
Erasing page 0x39:
Page 0x39 erased...
Sending record 2290:398040
Sending record 2300:3980e0
Sending record 2310:398180
Sending record 2320:398220
Sending record 2330:3982c0
Sending record 2340:398360
Sending record 2350:398400
Sending record 2360:3984a0
Sending record 2370:398540
Sending record 2380:3985e0
Sending record 2390:398680
Sending record 2400:398720
Sending record 2410:3987c0
Sending record 2420:398860
Sending record 2430:398900
Sending record 2440:3989a0
Sending record 2450:398a40
Sending record 2460:398ae0
Sending record 2470:398b80
Sending record 2480:398c20
Sending record 2490:398cc0
Sending record 2500:398d60
Sending record 2510:398e00
Sending record 2520:398ea0
Sending record 2530:398f40
Sending record 2540:398fe0
Sending record 2550:399080
Sending record 2560:399120
Sending record 2570:3991c0
Sending record 2580:399260
Sending record 2590:399300
Sending record 2600:3993a0
Sending record 2610:399440
Sending record 2620:3994e0
Sending record 2630:399580
Sending record 2640:399620
Sending record 2650:3996c0
Sending record 2660:399760
Sending record 2670:399800
Sending record 2680:3998a0
Sending record 2690:399940
Sending record 2700:3999e0
Sending record 2710:399a80
Sending record 2720:399b20
Sending record 2730:399bc0
Sending record 2740:399c60
Sending record 2750:399d00
Sending record 2760:399da0
Sending record 2770:399e40
Sending record 2780:399ee0
Sending record 2790:399f80
Sending record 2800:39a020
Sending record 2810:39a0c0
Setting page to 0x3a:
Erasing page 0x3a:
Page 0x3a erased...
Sending record 2820:3a8070
Sending record 2830:3a8110
Sending record 2840:3a81b0
Sending record 2850:3a8250
Sending record 2860:3a82f0
Sending record 2870:3a8390
Sending record 2880:3a8430
Sending record 2890:3a84d0
Sending record 2900:3a8570
Sending record 2910:3a8610
Sending record 2920:3a86b0
Sending record 2930:3a8750
Sending record 2940:3a87f0
Sending record 2950:3a8890
Sending record 2960:3a8930
Sending record 2970:3a89d0
Sending record 2980:3a8a70
Sending record 2990:3a8b10
Sending record 3000:3a8bb0
Sending record 3010:3a8c50
Sending record 3020:3a8cf0
Sending record 3030:3a8d90
Sending record 3040:3a8e30
Sending record 3050:3a8ed0
Sending record 3060:3a8f70
Sending record 3070:3a9010
Sending record 3080:3a90b0
Sending record 3090:3a9150
Sending record 3100:3a91f0
Sending record 3110:3a9290
Sending record 3120:3a9330
Sending record 3130:3a93d0
Sending record 3140:3a9470
Sending record 3150:3a9510
Sending record 3160:3a95b0
Sending record 3170:3a9650
Sending record 3180:3a96f0
Sending record 3190:3a9790
Sending record 3200:3a9830
Sending record 3210:3a98d0
Sending record 3220:3a9970
Sending record 3230:3a9a10
Sending record 3240:3a9ab0
Sending record 3250:3a9b50
Sending record 3260:3a9bf0
Sending record 3270:3a9c90
Sending record 3280:3a9d30
Sending record 3290:3a9dd0
Sending record 3300:3a9e70
Sending record 3310:3a9f10
Sending record 3320:3a9fb0
Sending record 3330:3aa050
Sending record 3340:3aa0f0
Sending record 3350:3aa190
Sending record 3360:3aa230
Sending record 3370:3aa2d0
Sending record 3380:3aa370
Sending record 3390:3aa410
Sending record 3400:3aa4b0
Sending record 3410:3aa550
Sending record 3420:3aa5f0
Sending record 3430:3aa690
Sending record 3440:3aa730
Sending record 3450:3aa7d0
Sending record 3460:3aa870
Sending record 3470:3aa910
Sending record 3480:3aa9b0
Sending record 3490:3aaa50
Sending record 3500:3aaaf0
Sending record 3510:3aab90
Sending record 3520:3aac30
Sending record 3530:3aacd0
Sending record 3540:3aad70
Sending record 3550:3aae10
Sending record 3560:3aaeb0
Sending record 3570:3aaf50
Sending record 3580:3aaff0
Sending record 3590:3ab090
Sending record 3600:3ab130
Sending record 3610:3ab1d0
Sending record 3620:3ab270
Sending record 3630:3ab310
Sending record 3640:3ab3b0
Sending record 3650:3ab450
Sending record 3660:3ab4f0
Sending record 3670:3ab590
Sending record 3680:3ab630
Sending record 3690:3ab6d0
Sending record 3700:3ab770
Sending record 3710:3ab810
Sending record 3720:3ab8b0
Sending record 3730:3ab950
Sending record 3740:3ab9f0
Sending record 3750:3aba90
Sending record 3760:3abb30
Sending record 3770:3abbd0
Sending record 3780:3abc70
Sending record 3790:3abd10
Sending record 3800:3abdb0
Sending record 3810:3abe50
Setting page to 0x3b:
Erasing page 0x3b:
Page 0x3b erased...
Sending record 3820:3b8030
Sending record 3830:3b80d0
Sending record 3840:3b8170
Sending record 3850:3b8210
Sending record 3860:3b82b0
Sending record 3870:3b8350
Sending record 3880:3b83f0
Sending record 3890:3b8490
Sending record 3900:3b8530
Sending record 3910:3b85d0
Sending record 3920:3b8670
Sending record 3930:3b8710
Sending record 3940:3b87b0
Sending record 3950:3b8850
Sending record 3960:3b88f0
Sending record 3970:3b8990
Sending record 3980:3b8a30
Sending record 3990:3b8ad0
Sending record 4000:3b8b70
Sending record 4010:3b8c10
Sending record 4020:3b8cb0
Sending record 4030:3b8d50
Sending record 4040:3b8df0
Sending record 4050:3b8e90
Sending record 4060:3b8f30
Sending record 4070:3b8fd0
Sending record 4080:3b9070
Sending record 4090:3b9110
Sending record 4100:3b91b0
Sending record 4110:3b9250
Sending record 4120:3b92f0
Sending record 4130:3b9390
Sending record 4140:3b9430
Sending record 4150:3b94d0
Sending record 4160:3b9570
Sending record 4170:3b9610
Sending record 4180:3b96b0
Sending record 4190:3b9750
Sending record 4200:3b97f0
Sending record 4210:3b9890
Sending record 4220:3b9930
Sending record 4230:3b99d0
Sending record 4240:3b9a70
Sending record 4250:3b9b10
Sending record 4260:3b9bb0
Sending record 4270:3b9c50
Sending record 4280:3b9cf0
Sending record 4290:3b9d90
Sending record 4300:3b9e30
Sending record 4310:3b9ed0
Sending record 4320:3b9f70
Sending record 4330:3ba010
Sending record 4340:3ba0b0
Sending record 4350:3ba150
Sending record 4360:3ba1f0
Sending record 4370:3ba290
Sending record 4380:3ba330
Sending record 4390:3ba3d0
Sending record 4400:3ba470
Sending record 4410:3ba510
Sending record 4420:3ba5b0
Sending record 4430:3ba650
Sending record 4440:3ba6f0
Sending record 4450:3ba790
Sending record 4460:3ba830
Sending record 4470:3ba8d0
Sending record 4480:3ba970
Sending record 4490:3baa10
Sending record 4500:3baab0
Sending record 4510:3bab50
Sending record 4520:3babf0
Sending record 4530:3bac90
Sending record 4540:3bad30
Sending record 4550:3badd0
Sending record 4560:3bae70
Sending record 4570:3baf10
Sending record 4580:3bafb0
Sending record 4590:3bb050
Sending record 4600:3bb0f0
Sending record 4610:3bb190
Sending record 4620:3bb230
Sending record 4630:3bb2d0
Sending record 4640:3bb370
Sending record 4650:3bb410
Sending record 4660:3bb4b0
Sending record 4670:3bb550
Setting page to 0x3c:
Erasing page 0x3c:
Page 0x3c erased...
Sending record 4680:3c8010
Sending record 4690:3c80b0
Sending record 4700:3c8150
Sending record 4710:3c81f0
Sending record 4720:3c8290
Sending record 4730:3c8330
Sending record 4740:3c83d0
Sending record 4750:3c8470
Sending record 4760:3c8510
Sending record 4770:3c85b0
Sending record 4780:3c8650
Sending record 4790:3c86f0
Sending record 4800:3c8790
Sending record 4810:3c8830
Sending record 4820:3c88d0
Sending record 4830:3c8970
Sending record 4840:3c8a10
Sending record 4850:3c8ab0
Sending record 4860:3c8b50
Sending record 4870:3c8bf0
Sending record 4880:3c8c90
Sending record 4890:3c8d30
Sending record 4900:3c8dd0
Sending record 4910:3c8e70
Sending record 4920:3c8f10
Sending record 4930:3c8fb0
Sending record 4940:3c9050
Sending record 4950:3c90f0
Sending record 4960:3c9190
Sending record 4970:3c9230
Sending record 4980:3c92d0
Sending record 4990:3c9370
Sending record 5000:3c9410
Sending record 5010:3c94b0
Sending record 5020:3c9550
Sending record 5030:3c95f0
Sending record 5040:3c9690
Sending record 5050:3c9730
Sending record 5060:3c97d0
Sending record 5070:3c9870
Sending record 5080:3c9910
Sending record 5090:3c99b0
Sending record 5100:3c9a50
Sending record 5110:3c9af0
Sending record 5120:3c9b90
Sending record 5130:3ca480
Sending record 5140:3ca520
Sending record 5150:3ca5c0
Sending record 5160:3ca660
Sending record 5170:3ca700
Sending record 5180:3ca7a0
Sending record 5190:3ca840
Sending record 5200:3ca8e0
Sending record 5210:3ca980
Sending record 5220:3caa20
Sending record 5230:3caac0
Sending record 5240:3cab60
Sending record 5250:3cac00
Sending record 5260:3caca0
Sending record 5270:3cad40
Sending record 5280:3cade0
Sending record 5290:3cae80
Sending record 5300:3caf20
Sending record 5310:3cafc0
Sending record 5320:3cb060
Sending record 5330:3cb100
Sending record 5340:3cb1a0
Sending record 5350:3cb240
Sending record 5360:3cb2e0
Sending record 5370:3cb380
Sending record 5380:3cb420
Sending record 5390:3cb4c0
Sending record 5400:3cb560
Sending record 5410:3cb600
Sending record 5420:3cb6a0
Sending record 5430:3cb740
Sending record 5440:3cb7e0
Sending record 5450:3cb880
Sending record 5460:3cb920
Sending record 5470:3cb9c0
Sending record 5480:3cba60
Sending record 5490:3cbb00
Sending record 5500:3cbba0
Sending record 5510:3cbc40
Sending record 5520:3cbce0
Sending record 5530:3cbd80
Sending record 5540:3cbe20
Sending record 5550:3cbec0
Sending record 5560:3cbf60
Sending record 5570:3d8000
Setting page to 0x3d:
Erasing page 0x3d:
Page 0x3d erased...
Sending record 5580:3d80a0
Sending record 5590:3d8140
Sending record 5600:3d81e0
Sending record 5610:3d8280
Sending record 5620:3d8320
Sending record 5630:3d83c0
Sending record 5640:3d8460
Sending record 5650:3d8500
Sending record 5660:3d85a0
Sending record 5670:3d8640
Sending record 5680:3d86e0
Sending record 5690:3d8780
Sending record 5700:3d8820
Sending record 5710:3d88c0
Sending record 5720:3d8960
Sending record 5730:3d8a00
Sending record 5740:3d8aa0
Sending record 5750:3d8b40
Sending record 5760:3d8be0
Sending record 5770:3d8c80
Sending record 5780:3d8d20
Sending record 5790:3d8dc0
Sending record 5800:3d8e60
Sending record 5810:3d8f00
Sending record 5820:3d8fa0
Sending record 5830:3d9040
Sending record 5840:3d90e0
Sending record 5850:3d9180
Sending record 5860:3d9220
Sending record 5870:3d92c0
Sending record 5880:3d9360
Sending record 5890:3d9400
Sending record 5900:3d94a0
Sending record 5910:3d9540
Sending record 5920:3d95e0
Sending record 5930:3d9680
Sending record 5940:3d9720
Sending record 5950:3d97c0
Sending record 5960:3d9860
Sending record 5970:3d9900
Sending record 5980:3d99a0
Sending record 5990:3d9a40
Sending record 6000:3d9ae0
Sending record 6010:3d9b80
Sending record 6020:3d9c20
Sending record 6030:3d9cc0
Sending record 6040:3d9d60
Sending record 6050:3d9e00
Sending record 6060:3d9ea0
Sending record 6070:3d9f40
Sending record 6080:3d9fe0
Sending record 6090:3da080
Sending record 6100:3da120
Sending record 6110:3da1c0
Sending record 6120:3da260
Sending record 6130:3da300
Sending record 6140:3da3a0
Sending record 6150:3da440
Sending record 6160:3da4e0
Sending record 6170:3da580
Sending record 6180:3da620
Sending record 6190:3da6c0
Sending record 6200:3da760
Sending record 6210:3da800
Sending record 6220:3da8a0
Sending record 6230:3da940
Sending record 6240:3da9e0
Sending record 6250:3daa80
Sending record 6260:3dab20
Sending record 6270:3dabc0
Sending record 6280:3dac60
Sending record 6290:3dad00
Sending record 6300:3dada0
Sending record 6310:3dae40
Sending record 6320:3daee0
Sending record 6330:3daf80
Sending record 6340:3db020
Sending record 6350:3db0c0
Sending record 6360:3db160
Sending record 6370:3db200
Sending record 6380:3db2a0
Sending record 6390:3db340
Sending record 6400:3db3e0
Sending record 6410:3db480
Sending record 6420:3db520
Sending record 6430:3db5c0
Sending record 6440:3db660
Sending record 6450:3db700
Sending record 6460:3db7a0
Sending record 6470:3db840
Sending record 6480:3db8e0
Sending record 6490:3db980
Sending record 6500:3dba20
Sending record 6510:3dbac0
Sending record 6520:3dbb60
Sending record 6530:3dbc00
Sending record 6540:3dbca0
Sending record 6550:3dbd40
Wrote 104815 bytes
All Done!
:yeah!:
the door is / dev/ttyUSB0 Firmware 3.2.1
Translate text or webpage
Did you mean: now I have to work with tunerstudio, megatunix supports up to 3.0.x
Type text or a website address or translate a document.
Now I have to work with tunerstudio, megatunix supports up to 3.0.x
I was on pins 1, 2, 12, 13 is not connected to the ECU, it is now in order
bi-andrea
Previous
Return to Megatunix (obsolete)
