Problems with usb-serial cable
Moderator: djandruczyk
I have problems setting up my "hugepine" usb-serial cable on ubuntu. If any one did it please tell me how.
128 S.E.Turbo
- MS/Extra Guru
Re: Problems with usb-serial cable
Try these commands:oraculox wrote:I have problems setting up my "hugepine" usb-serial cable on ubuntu. If any one did it please tell me how.
first off unplug your usb to serial adapter
run "ls -al /dev/* >devices"
plug in your adapter
run "ls -al /dev/* >devices2"
then "diff devices devices2" and it should show the name of the new device if it is detected and supported (almsot all are).
you can also run "dmesg" after pluggin it in to see what the kernel detected it as.
typical names are /dev/ttyUSB0 /dev/ttyUSB1 and so on.
David J. Andruczyk
