MAF settings in MSnS-extra. Bug?
Moderator: djandruczyk
when setting the MAF on X7 to yes in megatunix shouldn't the VE tables be changed to use the voltage from the MAF sensor?
- MS/Extra Guru
Re: MAF settings in MSnS-extra. Bug?
what does megatune do?e-town wrote:when setting the MAF on X7 to yes in megatunix shouldn't the VE tables be changed to use the voltage from the MAF sensor?
David J. Andruczyk
- MS/Extra Guru
Re: switches to volts...
this is rather difficult to do in megatunix thanks to the way that the way MSnS-E variables are setup. I'll see what I can do, but as of now it's a real nightmare.e-town wrote:
David J. Andruczyk
