MEGATUNIX not showing all parameters
Moderator: djandruczyk
i have megatunix 0.9.8 it is detecting my ms fine the problem is want to set various parameters like firmware option etc ...wanna set up 4 cylinder cop but it is not showing all the parameters as guided in the tunning manual...is it because of version or something..it is not showing spark options etc
As per your other post you have installed B&G version 3.0 code. This does not have any options for spark control, so Megatunix is showing the correct options.
- MS/Extra Guru
Re: MEGATUNIX not showing all parameters
You would need to install the MSnS-E firmware to your ECU first.lucifer wrote:i have megatunix 0.9.8 it is detecting my ms fine the problem is want to set various parameters like firmware option etc ...wanna set up 4 cylinder cop but it is not showing all the parameters as guided in the tunning manual...is it because of version or something..it is not showing spark options etc
Also use the LATEST version of megatunix (0.9.11)
David J. Andruczyk
