It's because it's in offline mode. and I'll bet you didnt' load a previous ECU backup so all params are probably zero. I tested it on my dev system, and when in offlien mode the VEdisplay is zero until an ECU backup is loaded and then you can change it at will.superpilun wrote:The edit point shows TPS ADC regardless of whether the fueling method is Speed Density or Alpha-N. Is this a bug? I'm running in offline mode just testing it out so I don't know if that's why.
3D Display Edit Parameters in TPS ADC even Though Using SD
Moderator: djandruczyk
- MS/Extra Guru
Re: 3D Display Edit Parameters in TPS ADC even Though Using
David J. Andruczyk
