3D Display Edit Parameters in TPS ADC even Though Using SD
Moderator: djandruczyk
djandruczyk
MS/Extra Guru
Re: 3D Display Edit Parameters in TPS ADC even Though Using
Post by djandruczyk »
superpilun wrote:The edit point shows TPS ADC regardless of whether the fueling method is Speed Density or Alpha-N. Is this a bug? I'm running in offline mode just testing it out so I don't know if that's why.
It's because it's in offline mode. and I'll bet you didnt' load a previous ECU backup so all params are probably zero. I tested it on my dev system, and when in offlien mode the VEdisplay is zero until an ECU backup is loaded and then you can change it at will.
David J. Andruczyk
