Hi downloaded megatunix 0.9.15 from sourceforge and tried to install it, but I just come up a little short. I untar it and that works, run ./configure and it end with what looks like a error... Saying i need the "flex" package.. and then all commands i run just wont work... ie I can't run make or make install... Annyone know whats wrong and how to correct it ? Yes, I'm new to linux so might not be the brightest of stars at installing stuff on linux. Regards ---------------------------------------- This post is at: http://www.msextra.com/viewtopic.php?p=178048#178048 ----------------------------------------
---------------------------------------- This post is at: http://www.msextra.com/viewtopic.php?p=180746#180746 ----------------------------------------
megatunix on pclinuxos ?
Moderator: djandruczyk
Hi, You probably need to get the "flex" package like it says, but telling you how to do that without knowing exactly which "Linux" you have is pretty much impossible. Ubuntu? Fedora? Slackware? etc when you have that sorted, you will probably want to do a 'make clean' before you try again, but that may not be necessary. ---------------------------------------- This post is at: http://www.msextra.com/viewtopic.php?p=178095#178095 ----------------------------------------
---------------------------------------- This post is at: http://www.msextra.com/viewtopic.php?p=180747#180747 ----------------------------------------
