Boost tables bug?
Moderator: djandruczyk
Boost tables bug?
Using MS1 extra 029yx
The Y axis states it's values are/should be in ADC, however they are limited to 100 leading me to believe this is actually % not ADC. Megasquirt also uses % and not ADC.
- MS/Extra Guru
Re: Boost tables bug?
Cuz wrote:Using MS1 extra 029yx
thanks. Bug fixed in CVS. Will be in the 0.9.16 release.
David J. Andruczyk
- MS/Extra Guru
Cuz wrote:cheers.
do you have any notes on what else will be in the new version?
http://www.msefi.com/viewtopic.php?t=30983
David J. Andruczyk
- MS/Extra Guru
The values in the ECU are stored as TPSADC, but I have the tab configured to use TPSpercent as that's easier to wrap your head around and more intuitive to think of a range of 0-100, instead of 0-255.Cuz wrote:I was looking into this a bit more and I'm a little confused on what the TPS values in the table actually are. There is a value limit in these cells of 255, however the table label suggests the value should be in %.
Can you please confirm/discuss the logic around the TPS values for these tables?
The tab shows things and TPSADC and things are OK nad work as they should (AFAIK).
This is in 0.9.16. previous versiosn DID have a bug.
David J. Andruczyk
- MS/Extra Guru
25 to 85 is ok as long as it's smooth. just adjust the bins to suit your TPS.Cuz wrote:Ok, cheers for that
On a side note, i've often wondered what the TPC % should show when setup properly. ATM my range is from 25 when the throttle is closed to 85 when open. Should it be 0-100 or should I just adapt the values in the table to the 25-85% range i currently have?
You can check that on a meter as well. if you connect a meter between ground and signal out on your TPS with the ignition on, the value will probbaly swing from 1.25 volts to 4.25 volts in your case, which is fine.
David J. Andruczyk
