tooth logger RESOLVED!!!!!!
Moderator: djandruczyk
I-w
Post by I-w »
where does it grab the signal from?
it works great but no trigger.
ms-1 extra dual wheel setup.
MS-1 3.0 ~ MapDaddy ~ Fan mod ~ Boost mod ~ 4G63 wiring issues Resolved!!! tuning Head Aches
djandruczyk
MS/Extra Guru
Re: tooth logger
Post by djandruczyk »
I-w wrote:where does it grab the signal from?
The data comes from the ECU itself..
If using dual wheel, I believe you should see somethign on the tooth logger tab . Tooth logger is for multi-toothed wheels, trigger logger is for the simpler, one pulse per cylinder sort of input, i.e. a distributor, or points style input). jsmcortina would know more for sure, as he write that code in the ECU. All megatunix does is ask the ECU for the data, and plots it.
David J. Andruczyk
I-w
Re: tooth logger UPDATE
Post by I-w »
figured it out. my cam signal was not droping low enough. it would
fluctuate from 5.xx volts down to 3.4x volts. it needed to go below
1.00 volts or lower. i changed the 470 ohm resister for a 800. now
it is perfect.
thanks for your support.
djandruczyk
MS/Extra Guru
I-w wrote:figured it out. my cam signal was not droping low enough. it would
it is perfect.
cool, glad to hear your solved your issue.
David J. Andruczyk
