- TCP/IP socket access, current API is ascii based, usefull for debugging from telnet, working in on binary API spec.
- Graphical firmware loading tool. (done, functional for MS-I firmware only). uses the CLI tool I wrote for loading ms-i firmware, called "msloader", which is out in the 0.9.18 release.
- logviewer minor fixes (to prevent crashes)
what's coming in 0.9.19
Moderator: djandruczyk
- MS/Extra Guru
David J. Andruczyk
Re: what's coming in 0.9.19
can i request a thermo calibration tool ? yes its MS2, ms1 has the "easytherm" addon. Any ideas about this ?
I have to keep changing between MT and tunix for my purposes makes life annoying.
join the (non official) Megasquirt IRC chat channel
##megasquirt @ irc.freenode.net
http://webchat.freenode.net/?channels=% ... irt&uio=d4 - click here to join live via java web-client, its instant !
http://www.msefi.com/viewtopic.php?f=92 ... de#p204682
- MS/Extra Guru
Quan-Time wrote:can i request a thermo calibration tool ? yes its MS2, ms1 has the "easytherm" addon. Any ideas about this ?
be more descriptive as to what exactly that you want. Easytherm is an external tool, which modifies firmware and creates new lookuptables. megatunix 0.9.19 includes a firmware loading tool that can load MS1 or MS2 firmware. as for the lookuptables copy them to the correct places and tell megatunix to use them (See Tools->Lookuptables in the menu). (C:\program files\megatunix\.megatunix\lookuptables (windoze), or ~/.MegaTunix/LookupTables (linux/OS-X/Unix OS's))
David J. Andruczyk
what i ment to say was table creation. because i use a MS2, MT can do it from within the prog itself, no need for easytherm addon. I couldnt find a way to create a table in tunix, so i had to do it with MT first, but tunix seemed to read / work with it just fine.
ms2v3 MSX 2.0.1
ms2v3 MSX 2.0.1
- MS/Extra Guru
Be more specific, what kind of table? VE, Spark, AFR, Boost? temp? what do you want EXACTLY?Quan-Time wrote:what i ment to say was table creation. because i use a MS2, MT can do it from within the prog itself, no need for easytherm addon. I couldnt find a way to create a table in tunix, so i had to do it with MT first, but tunix seemed to read / work with it just fine.
ms2v3 MSX 2.0.1
I don't use megatune hardly at all and when I do I get frustrated quickly trying to find the appropriate "hidden menu".
David J. Andruczyk
Sounds like hes talking about the thermistor tables.
In MegaTune, its under the Tools menu.
1986 Porsche 944 Turbo
2.7 liter MID sleeved big bore, Wossner pistons, Vitesse Stage 2 turbo, coilovers, various weight deletes, and loads of other stuff.
