Since I was curious about the improvement in the logviewer, I picked up the latest build from the CVS.
However, it won't compile on my Xubuntu 8.10 when it comes to '3d_vetable.c'
3d_vetable.c: In function ‘ve3d_draw_runtime_indicator’:
3d_vetable.c:1180: error: incompatible type for argument 2 of ‘get_fixed_pos’
3d_vetable.c:1180: error: too many arguments to function ‘get_fixed_pos’
3d_vetable.c:1181: error: incompatible type for argument 2 of ‘get_fixed_pos’
3d_vetable.c:1181: error: too many arguments to function ‘get_fixed_pos’
3d_vetable.c: In function ‘ve3d_key_press_event’:
3d_vetable.c:1454: warning: dereferencing type-punned pointer will break strict-aliasing rules
3d_vetable.c:1789: warning: dereferencing type-punned pointer will break strict-aliasing rules
3d_vetable.c:1805: warning: dereferencing type-punned pointer will break strict-aliasing rules
3d_vetable.c: At top level:
3d_vetable.c:2415: error: conflicting types for ‘get_fixed_pos’
../include/3d_vetable.h:217: error: previous declaration of ‘get_fixed_pos’ was here
make[2]: *** [3d_vetable.o] Error 1
make[2]: Leaving directory `/home/stefr95/cvs/MegaTunix/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/stefr95/cvs/MegaTunix'
make: *** [all] Error 2
The stable release compiles ok, and runs just fine (except for the Logviewer...)
I can get it to compile on ubuntu 8.04 with a scratch checkout from cvs, but get segmentation faults and other errors depending on which controller I select. Feels to me like something has changed in the realtime map, profile, or other files again.
I'm going to work backwards datewise in the CVS until I can see what changed. The dev .19 branch was working (mostly) in early january. We know Dave is changing many things, so may need to let it settle.
No problem, I can wait... I was just curious to see what the logviewer looked like.
Of course, 5 minutes after I did my post here, I went over to the msefi.com forums
just to find an identical report. (http://www.msefi.com/viewtopic.php?f=76&t=34455)
Oh well...
Frix wrote:No problem, I can wait... I was just curious to see what the logviewer looked like.
Oh well...
If you want to test CVS, you need to use the correct branch. PRE_0_9_19-branch. Right now it's very much in flux. I've broken the API for the interrogation profiles and a bunch of other things, so custom profiles will not load, and there's still a handful of instability until I get my latest set of changes completed.. Most of this is due to MS2 and the pile of "implicit rules" that it broke compared to MS-I firmwares, forcing me to make the changes.
The logviewer hasn't changed much, and is sorely in need of a rewrite, as it's pretty kludgy, that I haven't gotten around to it yet. I hope to model it based upon some of the better points from megalogviewer (which is an excellent app in most respects)
