AFR error gauge: My most important gauge
Moderator: djandruczyk
Re: AFR error gauge: My most important gauge
Please excuse the REALLY poor effort, but ive been looking into making a fuel gauge as a few others have experimented with.
http://www.msextra.com/viewtopic.php?f= ... fuel+gauge here and
http://www.msextra.com/ms2extra/MS2-Ext ... m#addgauge here.
Is it possible for this to be done ? The basic idea of the gauge is more "linear" rather than needle. as it sweeps, relating to how much fuel you have left, the more red you have, the more empty your tank is. Hope you understand my crazyness, but its a gauge i would really like to see in Tunix.
I couldnt make the needle negative either, it kept jumping to 0.000
Also, how did you get the innovate logo on there ? is it some sort of magic / slight of hand / witch craft ?.. heh ;) I mainly want mono colour images to replace the words on my gauges. Like the normal temp symbol for example..
join the (non official) Megasquirt IRC chat channel
##megasquirt @ irc.freenode.net
http://webchat.freenode.net/?channels=% ... irt&uio=d4 - click here to join live via java web-client, its instant !
http://www.msefi.com/viewtopic.php?f=92 ... de#p204682
- MS/Extra Guru
sketch out what you want as you're not making sense. MegaTunix gauges are all rotary in nature. I haven't designed a bargraph or vertical style gauge yet.
You should be able to go negative, just by setting the lower limit to some negative number.
David J. Andruczyk
