When dash has focus
- Q/q quits
F/f fullscreens the dash
R/s hides/shows the runtime text window (textual list of rt vars)
S/s hides/shows the runtime status window (CONNECTED,CRANKING,etc..)
M/m hides/shows the main megatunix window
- q/+ increments
PgUp increments by a larger amount
w/- decrements
PgDn dcrements by a larger amount
You can alwasy highlight and type over
Arrows (up/dn) change change the settings, you can also TYPE in a portion of it and it'll show completions, if you get enough of the match it'll auto-select it.
3D display
- Arrows navigate
q/w+/-/Pgup/Pgdn alter individual vertexes
Holding Control while hittign an increment or decrement char (i.e Ctrl Pgup) raises an ENTIRE ROW by the incrementation value (i.e. q/w/+/- is usually 1, Pgup/Dn is usually 10x that.
Holding Alt likewise does the same thing but for a COLUMN
Ctrl/ALT + edit is useful to change a large number of values at once
1) What does "When dash has focus" mean?
2) How can I make the dash appear / disappear? (Like m makes MTx appear/disappear. )
3) Can I do this while dash is in full screen mode? (this would be nice if I quickly want to change something but want to come right back to full screen dash after having done so. Basically I want m to bring the main MTx window in front of the dash which is already in full screen mode)
4) When the dash is active (with MTx "behind" it) hitting m makes MTx appear and disappear but MTx stays behind the dash where its of no use to me. Can I make it appear in front of the dash (or hide the dash while MTx is in front)?
5) Can I change values of the focus (ie tune) while in 3D wireframe mode (as can be done in MT)?
More to come as I become familiar with MTx...
