Looking for Intel Mac
Moderator: djandruczyk
24c
Re: Looking for Intel Mac
Post by 24c »
Actually, I just tried to boot it up with my generic charger and it failed. I plugged in the Apple one from my MacBook Pro and it started fine, I don't suppose you have access to a genuine Apple charger?
Anyway it is cleaned up already now, your name is "George Coward" and I will email you the password later. i am just booting it in Windows XP now (dual boot) and it's just crashed... :)
..it boots OK now.
I will post it Friday, good luck.
Just checked again, you will need a genuine Apple charger...looks like I have lost mine :(
Yamaha YZF1000 MSExtra 3.1
24c
Post by 24c »
24c wrote:I will post it Friday, good luck.
I have, forecast is 2-5 days to you. I have charged the batteries up for you, just remember to hold the alt key down on startup, so you can chose the OS.
Hope it works out for you.
djandruczyk
MS/Extra Guru
Post by djandruczyk »
Excellent!, thanks again!
David J. Andruczyk
24c
Post by 24c »
Dave has the MacBook been behaving itself?
Is MegaTunix any faster on a newer machine?
Just curious :)
Mike
djandruczyk
MS/Extra Guru
24c wrote:Dave has the MacBook been behaving itself?
Just curious :)
Mike
Its working quite well, it really shows the age of my primary desktop development machine. It runs significantly faster on the macbook than my desktop, though mtx works just fine (just takes a bit longer to startup) on my mobile pentium m dell D600 laptop as well. I located an external MAC battery charger on E-bay which works well to top up the extra battery you sent (thanks a LOT for that!) I've found a couple ore really major bugs in 0.9.22 that I'm currently working on, which should hopefully speed up mtx a bit more. I'm still trying to pickup objective C, but it's a tricky language and there's not a whole lot of good references books for it that I've found yet, esp with its strange syntax. (All the ones I've found have been sleepers so far, good for insomnia, not so good to learn from.)
David J. Andruczyk
