MegaTunix on OS-X (revised)
Moderator: djandruczyk
Did this work for you?
Yes
4
67%
No
1
17%
It had a problem somewhere, I posted a question in this thread.
1
17%
Total votes : 6
Re: MegaTunix on OS-X (revised)
Postby djandruczyk » Sun Feb 20, 2011 1:44 pm
Can you please try it after ERASING ~/.MegaTunix/config? Each one of your screenshots tells me you HAVE NOT as its showing old information that was deprecated a long time ago.
i.e. megatunix will startup and popup the personalities, select the one that matters to you, then it'll timeout in a few seconds about not locating and give the option to exit or offline, MOVE THAT WINDOW oout of hte way, goto the comms tab and click on "locate port", pick the appropriate device (it should NOT list a tty.xxxx device, only a cu.xxx one), once you click apply/ok it should then detect the ecu, interrrogate and work normally, and the remaining windows should close.
Please see if it does that or not.
It worked perfectly for me on my macbook. I plan on detecting the lack of a config file (first time run wizard) to run through things like the port locator and default temp scale and anything else i think may possible be applicable. Which should ease things for new users.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby 24c » Sun Feb 20, 2011 2:39 pm
djandruczyk wrote:Can you please try it after ERASING ~/.MegaTunix/config? Each one of your screenshots tells me you HAVE NOT as its showing old information that was deprecated a long time ago.
I thought I did everything you asked...
djandruczyk wrote:Give it a try (git pull origin master ; make ; sudo make install ; mv ~/.MegaTunix/config ~/.MegaTunix/config.old ; ./src/megatunix)
So I'll try again. :?
Code: Select all
Last login: Sun Feb 20 13:43:44 on ttys000
Mike-Cranes-iMac27:~ mikecrane$ cd git/MegaTunix
Mike-Cranes-iMac27:MegaTunix mikecrane$ git pull origin master
From git://github.com/djandruczyk/MegaTunix
 * branch            master     -> FETCH_HEAD
Already up-to-date.
Mike-Cranes-iMac27:MegaTunix mikecrane$ make
make  all-recursive
Making all in include
make[2]: Nothing to be done for `all'.
Making all in mtxmatheval
Making all in mtxcommon
Making all in widgets
Making all in msloader
Making all in src
Making all in plugins
Making all in jimstim
make[4]: Nothing to be done for `all'.
Making all in mscommon
Making all in ms1
Making all in ms2
Making all in ms3
Making all in freeems
Making all in secu3
Making all in pis
Making all in null
make[4]: Nothing to be done for `all-am'.
make[3]: Nothing to be done for `all-am'.
Making all in gaugedesigner
Making all in gauges
Making all in AutoGauge
Making all in Speco
Making all in SportComp
Making all in UltraLite
Making all in Cobalt
Making all in Impact
Making all in Honda
Making all in Ghost
Making all in MegaTune
Making all in dashdesigner
Making all in dashboards
make[3]: Nothing to be done for `all'.
Making all in ecu_snapshots
Making all in Interrogator
Making all in Profiles
Making all in MS-1
Making all in MS-2
Making all in PIS
Making all in SECU-3
Making all in FreeEMS
Making all in JimStim
Making all in LookupTables
Making all in RealtimeMaps
Making all in RuntimeSliders
Making all in RuntimeStatus
Making all in RuntimeText
Making all in Gui
Making all in menu
Making all in category
Making all in icons
Making all in desktop
Making all in po
Mike-Cranes-iMac27:MegaTunix mikecrane$ sudo make install
Password:
Making install in include
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
Making install in mtxmatheval
Making install in mtxcommon
test -z "/usr/local/lib" || .././install-sh -c -d "/usr/local/lib"
 /bin/sh ../libtool   --mode=install /usr/bin/install -c   libmtxcommon.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libmtxcommon.0.dylib /usr/local/lib/libmtxcommon.0.dylib
libtool: install: (cd /usr/local/lib && { ln -s -f libmtxcommon.0.dylib libmtxcommon.dylib || { rm -f libmtxcommon.dylib && ln -s libmtxcommon.0.dylib libmtxcommon.dylib; }; })
libtool: install: /usr/bin/install -c .libs/libmtxcommon.lai /usr/local/lib/libmtxcommon.la
Libraries have been installed in:
   /usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `DYLD_LIBRARY_PATH' environment variable
     during execution
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
Making install in widgets
 /bin/sh ../libtool   --mode=install /usr/bin/install -c   libmtxgauge.la libmtxcurve.la libmtxpie.la libmtxprogress.la libmtxstripchart.la libmtxcombo_mask.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libmtxgauge.0.dylib /usr/local/lib/libmtxgauge.0.dylib
libtool: install: (cd /usr/local/lib && { ln -s -f libmtxgauge.0.dylib libmtxgauge.dylib || { rm -f libmtxgauge.dylib && ln -s libmtxgauge.0.dylib libmtxgauge.dylib; }; })
libtool: install: /usr/bin/install -c .libs/libmtxgauge.lai /usr/local/lib/libmtxgauge.la
libtool: install: /usr/bin/install -c .libs/libmtxcurve.0.dylib /usr/local/lib/libmtxcurve.0.dylib
libtool: install: (cd /usr/local/lib && { ln -s -f libmtxcurve.0.dylib libmtxcurve.dylib || { rm -f libmtxcurve.dylib && ln -s libmtxcurve.0.dylib libmtxcurve.dylib; }; })
libtool: install: /usr/bin/install -c .libs/libmtxcurve.lai /usr/local/lib/libmtxcurve.la
libtool: install: /usr/bin/install -c .libs/libmtxpie.0.dylib /usr/local/lib/libmtxpie.0.dylib
libtool: install: (cd /usr/local/lib && { ln -s -f libmtxpie.0.dylib libmtxpie.dylib || { rm -f libmtxpie.dylib && ln -s libmtxpie.0.dylib libmtxpie.dylib; }; })
libtool: install: /usr/bin/install -c .libs/libmtxpie.lai /usr/local/lib/libmtxpie.la
libtool: install: /usr/bin/install -c .libs/libmtxprogress.0.dylib /usr/local/lib/libmtxprogress.0.dylib
libtool: install: (cd /usr/local/lib && { ln -s -f libmtxprogress.0.dylib libmtxprogress.dylib || { rm -f libmtxprogress.dylib && ln -s libmtxprogress.0.dylib libmtxprogress.dylib; }; })
libtool: install: /usr/bin/install -c .libs/libmtxprogress.lai /usr/local/lib/libmtxprogress.la
libtool: install: /usr/bin/install -c .libs/libmtxstripchart.0.dylib /usr/local/lib/libmtxstripchart.0.dylib
libtool: install: (cd /usr/local/lib && { ln -s -f libmtxstripchart.0.dylib libmtxstripchart.dylib || { rm -f libmtxstripchart.dylib && ln -s libmtxstripchart.0.dylib libmtxstripchart.dylib; }; })
libtool: install: /usr/bin/install -c .libs/libmtxstripchart.lai /usr/local/lib/libmtxstripchart.la
libtool: install: /usr/bin/install -c .libs/libmtxcombo_mask.0.dylib /usr/local/lib/libmtxcombo_mask.0.dylib
libtool: install: (cd /usr/local/lib && { ln -s -f libmtxcombo_mask.0.dylib libmtxcombo_mask.dylib || { rm -f libmtxcombo_mask.dylib && ln -s libmtxcombo_mask.0.dylib libmtxcombo_mask.dylib; }; })
libtool: install: /usr/bin/install -c .libs/libmtxcombo_mask.lai /usr/local/lib/libmtxcombo_mask.la
   /usr/local/lib
     during execution
Making install in msloader
test -z "/usr/local/bin" || .././install-sh -c -d "/usr/local/bin"
  /bin/sh ../libtool   --mode=install /usr/bin/install -c msloader mtxloader '/usr/local/bin'
libtool: install: /usr/bin/install -c .libs/msloader /usr/local/bin/msloader
libtool: install: /usr/bin/install -c .libs/mtxloader /usr/local/bin/mtxloader
Making install in src
Making install in plugins
Making install in jimstim
make[4]: Nothing to be done for `install-exec-am'.
test -z "/usr/local/share/MegaTunix/plugins" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/plugins"
 /bin/sh ../../../libtool   --mode=install /usr/bin/install -c   libjimstim.la '/usr/local/share/MegaTunix/plugins'
libtool: install: /usr/bin/install -c .libs/libjimstim.0.so /usr/local/share/MegaTunix/plugins/libjimstim.0.so
libtool: install: (cd /usr/local/share/MegaTunix/plugins && { ln -s -f libjimstim.0.so libjimstim.so || { rm -f libjimstim.so && ln -s libjimstim.0.so libjimstim.so; }; })
libtool: install: /usr/bin/install -c .libs/libjimstim.lai /usr/local/share/MegaTunix/plugins/libjimstim.la
     during execution
Making install in mscommon
 /bin/sh ../../../libtool   --mode=install /usr/bin/install -c   libmscommon.la '/usr/local/share/MegaTunix/plugins'
libtool: install: /usr/bin/install -c .libs/libmscommon.0.so /usr/local/share/MegaTunix/plugins/libmscommon.0.so
libtool: install: (cd /usr/local/share/MegaTunix/plugins && { ln -s -f libmscommon.0.so libmscommon.so || { rm -f libmscommon.so && ln -s libmscommon.0.so libmscommon.so; }; })
libtool: install: /usr/bin/install -c .libs/libmscommon.lai /usr/local/share/MegaTunix/plugins/libmscommon.la
     during execution
Making install in ms1
 /bin/sh ../../../libtool   --mode=install /usr/bin/install -c   libms1.la '/usr/local/share/MegaTunix/plugins'
libtool: install: /usr/bin/install -c .libs/libms1.0.so /usr/local/share/MegaTunix/plugins/libms1.0.so
libtool: install: (cd /usr/local/share/MegaTunix/plugins && { ln -s -f libms1.0.so libms1.so || { rm -f libms1.so && ln -s libms1.0.so libms1.so; }; })
libtool: install: /usr/bin/install -c .libs/libms1.lai /usr/local/share/MegaTunix/plugins/libms1.la
     during execution
Making install in ms2
 /bin/sh ../../../libtool   --mode=install /usr/bin/install -c   libms2.la '/usr/local/share/MegaTunix/plugins'
libtool: install: /usr/bin/install -c .libs/libms2.0.so /usr/local/share/MegaTunix/plugins/libms2.0.so
libtool: install: (cd /usr/local/share/MegaTunix/plugins && { ln -s -f libms2.0.so libms2.so || { rm -f libms2.so && ln -s libms2.0.so libms2.so; }; })
libtool: install: /usr/bin/install -c .libs/libms2.lai /usr/local/share/MegaTunix/plugins/libms2.la
     during execution
Making install in ms3
 /bin/sh ../../../libtool   --mode=install /usr/bin/install -c   libnull.la '/usr/local/share/MegaTunix/plugins'
libtool: install: /usr/bin/install -c .libs/libnull.0.so /usr/local/share/MegaTunix/plugins/libnull.0.so
libtool: install: (cd /usr/local/share/MegaTunix/plugins && { ln -s -f libnull.0.so libnull.so || { rm -f libnull.so && ln -s libnull.0.so libnull.so; }; })
libtool: install: /usr/bin/install -c .libs/libnull.lai /usr/local/share/MegaTunix/plugins/libnull.la
     during execution
Making install in freeems
 /bin/sh ../../../libtool   --mode=install /usr/bin/install -c   libfreeems.la '/usr/local/share/MegaTunix/plugins'
libtool: install: /usr/bin/install -c .libs/libfreeems.0.so /usr/local/share/MegaTunix/plugins/libfreeems.0.so
libtool: install: (cd /usr/local/share/MegaTunix/plugins && { ln -s -f libfreeems.0.so libfreeems.so || { rm -f libfreeems.so && ln -s libfreeems.0.so libfreeems.so; }; })
libtool: install: /usr/bin/install -c .libs/libfreeems.lai /usr/local/share/MegaTunix/plugins/libfreeems.la
     during execution
Making install in secu3
 /bin/sh ../../../libtool   --mode=install /usr/bin/install -c   libsecu3.la '/usr/local/share/MegaTunix/plugins'
libtool: install: /usr/bin/install -c .libs/libsecu3.0.so /usr/local/share/MegaTunix/plugins/libsecu3.0.so
libtool: install: (cd /usr/local/share/MegaTunix/plugins && { ln -s -f libsecu3.0.so libsecu3.so || { rm -f libsecu3.so && ln -s libsecu3.0.so libsecu3.so; }; })
libtool: install: /usr/bin/install -c .libs/libsecu3.lai /usr/local/share/MegaTunix/plugins/libsecu3.la
     during execution
Making install in pis
 /bin/sh ../../../libtool   --mode=install /usr/bin/install -c   libpis.la '/usr/local/share/MegaTunix/plugins'
libtool: install: /usr/bin/install -c .libs/libpis.0.so /usr/local/share/MegaTunix/plugins/libpis.0.so
libtool: install: (cd /usr/local/share/MegaTunix/plugins && { ln -s -f libpis.0.so libpis.so || { rm -f libpis.so && ln -s libpis.0.so libpis.so; }; })
libtool: install: /usr/bin/install -c .libs/libpis.lai /usr/local/share/MegaTunix/plugins/libpis.la
     during execution
Making install in null
     during execution
make[4]: Nothing to be done for `install-data-am'.
  /bin/sh ../libtool   --mode=install /usr/bin/install -c megatunix '/usr/local/bin'
libtool: install: /usr/bin/install -c .libs/megatunix /usr/local/bin/megatunix
make[3]: Nothing to be done for `install-data-am'.
Making install in gaugedesigner
Making install in gauges
Making install in AutoGauge
test -z "/usr/local/share/MegaTunix/Gauges/AutoGauge" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Gauges/AutoGauge"
 /usr/bin/install -c -m 644 AutoGauge_Template.xml Boost_Vac_20psi.xml Vac_0-30InHg.xml '/usr/local/share/MegaTunix/Gauges/AutoGauge'
Making install in Speco
test -z "/usr/local/share/MegaTunix/Gauges/Speco" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Gauges/Speco"
 /usr/bin/install -c -m 644 Gemini_TPS_percentage.xml Gemini_Advance_Gauge.xml Gemini_AFR_Lambda2.xml Gemini_AFR_Lambda.xml Gemini_CLT_Gauge.xml Gemini_CLT_degC_Gauge.xml Gemini_MAP_Gauge.xml Gemini_MAT_Gauge.xml Gemini_MAT_degC_Gauge.xml Gemini_BoostDC.xml Gemini_EGOcorr.xml Gemini_IdleDC.xml Gemini_AFR.xml Gemini_RPM.xml Gemini_TPS.xml Gemini_Volts.xml '/usr/local/share/MegaTunix/Gauges/Speco'
Making install in SportComp
test -z "/usr/local/share/MegaTunix/Gauges/SportComp" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Gauges/SportComp"
 /usr/bin/install -c -m 644 AM_SportComp_AFR_Gauge.xml AM_SportComp_Advance_Gauge.xml AM_SportComp_Boost_Gauge.xml AM_SportComp_CLT_Gauge.xml AM_SportComp_DC_Gauge.xml AM_SportComp_EGOcorr_Gauge.xml AM_SportComp_Fuel_Gauge.xml AM_SportComp_FuelLoad_Gauge.xml AM_SportComp_FuelLoad2_Gauge.xml AM_SportComp_IgnLoad_Gauge.xml AM_SportComp_IgnLoad2_Gauge.xml AM_SportComp_MAP_Gauge.xml AM_SportComp_MAT_Gauge.xml AM_SportComp_O2Volt_Gauge.xml AM_SportComp_PW_Gauge.xml AM_SportComp_RPM_Gauge.xml AM_SportComp_TPSADC_Gauge.xml AM_SportComp_TPSpercent_Gauge.xml AM_SportComp_CLT_degC_Gauge.xml AM_SportComp_MAT_degC_Gauge.xml AM_SportComp_VE_Gauge.xml AM_SportComp_Volts.xml AM_SportComp_O2Lambda_Gauge.xml AM_SportComp_MAP_Limit_Gauge.xml '/usr/local/share/MegaTunix/Gauges/SportComp'
Making install in UltraLite
test -z "/usr/local/share/MegaTunix/Gauges/UltraLite" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Gauges/UltraLite"
 /usr/bin/install -c -m 644 ultralite_autometer_AE_Gauge.xml ultralite_autometer_map_Gauge.xml ultralite_autometer_MAT_Gauge.xml ultralite_autometer_rpm_Gauge.xml ultralite_autometer_PWM_Gauge.xml ultralite_autometer_PWM2_Gauge.xml ultralite_autometer_temp_Gauge.xml ultralite_autometer_afr_Gauge.xml ultralite_autometer_volts_Gauge.xml ultralite_autometer_MAT_degC_Gauge.xml ultralite_autometer_temp_degC_Gauge.xml ultralite_autometer_dc_Gauge.xml ultralite_autometer_dc2_Gauge.xml '/usr/local/share/MegaTunix/Gauges/UltraLite'
Making install in Cobalt
test -z "/usr/local/share/MegaTunix/Gauges/Cobalt" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Gauges/Cobalt"
 /usr/bin/install -c -m 644 Cobalt_AFR.xml Cobalt_CLT.xml Cobalt_MAT.xml Cobalt_VE.xml Cobalt_Advance.xml Cobalt_DC.xml Cobalt_PW.xml Cobalt_Volts.xml Cobalt_Boost.xml Cobalt_MAP.xml Cobalt_CLT_degC.xml Cobalt_MAT_degC.xml Cobalt_RPM.xml '/usr/local/share/MegaTunix/Gauges/Cobalt'
Making install in Impact
test -z "/usr/local/share/MegaTunix/Gauges/Impact" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Gauges/Impact"
 /usr/bin/install -c -m 644 Impact_AFR_Gauge.xml Impact_Advance_Gauge.xml Impact_Boost_Gauge.xml Impact_CLT_Gauge.xml Impact_DC_Gauge.xml Impact_Fuel_Gauge.xml Impact_MAP_Gauge.xml Impact_MAT_Gauge.xml Impact_PW_Gauge.xml Impact_VE_Gauge.xml Impact_CLT_degC_Gauge.xml Impact_MAT_degC_Gauge.xml Impact_Volts_Gauge.xml Impact_rpm_Gauge.xml '/usr/local/share/MegaTunix/Gauges/Impact'
Making install in Honda
test -z "/usr/local/share/MegaTunix/Gauges/Honda" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Gauges/Honda"
 /usr/bin/install -c -m 644 Honda_AFR_Gauge.xml Honda_BatteryVolt_Gauge.xml Honda_Fuel_Gauge.xml Honda_MAP_Gauge.xml Honda_MAT_Gauge.xml Honda_MAT_degC_Gauge.xml Honda_Oil_Pressurel_Gauge.xml Honda_Oil_Temp_Gauge.xml Honda_Oil_Temp_degC_Gauge.xml Honda_RPM_Gauge.xml Honda_Water_Temp_Gauge.xml Honda_Water_Temp_degC_Gauge.xml '/usr/local/share/MegaTunix/Gauges/Honda'
Making install in Ghost
test -z "/usr/local/share/MegaTunix/Gauges/Ghost" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Gauges/Ghost"
 /usr/bin/install -c -m 644 Ghost_TPSpercent_Gauge.xml Ghost_Background_Gauge.xml Ghost_CLT_degC_Gauge.xml Ghost_MAT_degC_Gauge.xml Ghost_EGOcorr_Gauge.xml Ghost_O2Volt_Gauge.xml Ghost_TPSADC_Gauge.xml Ghost_Boost_Gauge.xml Ghost_Fuel_Gauge.xml Ghost_MAP_Gauge.xml Ghost_MAT_Gauge.xml Ghost_CLT_Gauge.xml Ghost_RPM_Gauge.xml Ghost_AFR_Gauge.xml Ghost_DC_Gauge.xml Ghost_PW_Gauge.xml Ghost_Advance.xml Ghost_Volts.xml Ghost_VE.xml '/usr/local/share/MegaTunix/Gauges/Ghost'
Making install in MegaTune
test -z "/usr/local/share/MegaTunix/Gauges/MegaTune" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Gauges/MegaTune"
 /usr/bin/install -c -m 644 Accel-Enrich-Gauge.xml AFR1-Gauge.xml AFR2-Gauge.xml Barometer-Gauge.xml Batt-Gauge.xml Coolant-Temp_degC-Gauge.xml Coolant-Temp_degF-Gauge.xml Coolant-Temp_Universal-Gauge.xml Dutycycle1-Gauge.xml Dutycycle2-Gauge.xml Dwell-Gauge.xml EAE-FuelCorr1-Gauge.xml EAE-FuelCorr2-Gauge.xml E85-Fuel-Correction-Gauge.xml EGO-Correction-Gauge.xml EGO-Gauge.xml Ethanol-Percentage-Gauge.xml Fuel-Load-Gauge.xml Gamma-Enrichment-Gauge.xml IAC-Position-Gauge.xml Idle-PWM-Gauge.xml Ign-Advance-Gauge.xml Intake-Air-Temp_degC-Gauge.xml Intake-Air-Temp_degF-Gauge.xml Lambda1-Gauge.xml Lambda2-Gauge.xml MAF-Gauge.xml MAP_baro-Gauge.xml MAP-Gauge.xml PW1-Gauge.xml PW2-Gauge.xml RPM-Gauge.xml Template-Gauge.xml Timing-Delta-Gauge.xml Timing-Error-Gauge.xml TPS-Gauge.xml VE-Current-Gauge.xml VE-Value-Gauge.xml Warmup-Enrichment-Gauge.xml Xtau-Corr1-Gauge.xml '/usr/local/share/MegaTunix/Gauges/MegaTune'
 /usr/bin/install -c -m 644 Xtau-Corr2-Gauge.xml '/usr/local/share/MegaTunix/Gauges/MegaTune'
  /bin/sh ../libtool   --mode=install /usr/bin/install -c gaugedesigner '/usr/local/bin'
libtool: install: /usr/bin/install -c .libs/gaugedesigner /usr/local/bin/gaugedesigner
test -z "/usr/local/share/MegaTunix/gaugedesigner" || .././install-sh -c -d "/usr/local/share/MegaTunix/gaugedesigner"
 /usr/bin/install -c -m 644 main.ui a_range.ui polygon.ui tblock.ui tgroup.ui w_range.ui '/usr/local/share/MegaTunix/gaugedesigner'
Making install in dashdesigner
Making install in dashboards
make[3]: Nothing to be done for `install-exec-am'.
test -z "/usr/local/share/MegaTunix/Dashboards" || ../.././install-sh -c -d "/usr/local/share/MegaTunix/Dashboards"
 /usr/bin/install -c -m 644 Default_Dash.xml Default_Dash_degC.xml Default_Dash_MS2.xml Default_Dash_MS2_degC.xml Autometer-ultralight.xml Autometer-ultralight-degC.xml Cobalt_Dash.xml Cobalt_Dash_degC.xml Impact_Dash.xml Impact_Dash_degC.xml Gemini_Dash.xml Gemini_Dash_degC.xml Ghost-Basic-Dash_degC.xml Ghost-Basic-Dash.xml Ghost-Dash_degC.xml Ghost-Dash.xml Honda_Dash.xml Honda_Dash_degC.xml MegaTune-Classic.xml MegaTune-MS1-Classic.xml MegaTune-MS2-Classic.xml MegaTune-MS2-Extra.xml '/usr/local/share/MegaTunix/Dashboards'
  /bin/sh ../libtool   --mode=install /usr/bin/install -c dashdesigner '/usr/local/bin'
libtool: install: /usr/bin/install -c .libs/dashdesigner /usr/local/bin/dashdesigner
test -z "/usr/local/share/MegaTunix/dashdesigner" || .././install-sh -c -d "/usr/local/share/MegaTunix/dashdesigner"
 /usr/bin/install -c -m 644 main.ui preview.ui propeditor.ui '/usr/local/share/MegaTunix/dashdesigner'
Making install in ecu_snapshots
test -z "/usr/local/share/MegaTunix/ecu_snapshots" || .././install-sh -c -d "/usr/local/share/MegaTunix/ecu_snapshots"
 /usr/bin/install -c -m 644 MS1-DT-Std.ecu MS1-BnG-V1.x.ecu MS1-BnG-V3.x.ecu JimStim_v0.x.ecu JimStim_v2.x.ecu MS1-Extra_029-series.ecu MS1-Extra_029y-series.ecu MS1-Extra_Highres_011[ab]-series.ecu MS1-Extra_Highres_011d-series.ecu MS1-Extra_Highres_010x-series.ecu MS1-Extra_Highres_0[89]x-series.ecu MS2_V2.8x-series.ecu MS2-Extra_V2.1.0-series.ecu MS2-Extra_V2.1.0e-series.ecu MS2-Extra_V3.0.x-series.ecu MS2-Extra_V3.0.3w_series.ecu MS2-Extra_V3.1.0_series.ecu '/usr/local/share/MegaTunix/ecu_snapshots'
Making install in Interrogator
Making install in Profiles
Making install in MS-1
test -z "/usr/local/share/MegaTunix/Interrogator/Profiles/MS-1" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Interrogator/Profiles/MS-1"
 /usr/bin/install -c -m 644 details.cfg tests.cfg comm.xml MS1-BnG_1.x.prof MS1-BnG_3.x.prof MS1-DT-1.02.prof MS1-Extra-HR-08x.prof MS1-Extra-HR-010x.prof MS1-Extra-HR-011x.prof MS1-Extra-HR-011d.prof MS1-Extra-029x.prof MS1-Extra-029yx.prof '/usr/local/share/MegaTunix/Interrogator/Profiles/MS-1'
Making install in MS-2
test -z "/usr/local/share/MegaTunix/Interrogator/Profiles/MS-2" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Interrogator/Profiles/MS-2"
 /usr/bin/install -c -m 644 details.cfg tests.cfg comm.xml MS2-Extra_2.1.0.prof MS2-Extra_2.1.0e.prof MS2-Extra_3.0.x.prof MS2-Extra_3.0.3w.prof MS2-Extra_3.0.3y.prof MS2-Extra_3.1.0.prof MS2.prof '/usr/local/share/MegaTunix/Interrogator/Profiles/MS-2'
Making install in PIS
test -z "/usr/local/share/MegaTunix/Interrogator/Profiles/PIS" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Interrogator/Profiles/PIS"
 /usr/bin/install -c -m 644 details.cfg tests.cfg comm.xml PIS_V1_00.prof '/usr/local/share/MegaTunix/Interrogator/Profiles/PIS'
Making install in SECU-3
test -z "/usr/local/share/MegaTunix/Interrogator/Profiles/SECU-3" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Interrogator/Profiles/SECU-3"
 /usr/bin/install -c -m 644 details.cfg tests.cfg comm.xml '/usr/local/share/MegaTunix/Interrogator/Profiles/SECU-3'
Making install in FreeEMS
test -z "/usr/local/share/MegaTunix/Interrogator/Profiles/FreeEMS" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Interrogator/Profiles/FreeEMS"
 /usr/bin/install -c -m 644 details.cfg tests.cfg comm.xml FreeEMS_0.0.0.prof '/usr/local/share/MegaTunix/Interrogator/Profiles/FreeEMS'
Making install in JimStim
test -z "/usr/local/share/MegaTunix/Interrogator/Profiles/JimStim" || ../../.././install-sh -c -d "/usr/local/share/MegaTunix/Interrogator/Profiles/JimStim"
 /usr/bin/install -c -m 644 details.cfg tests.cfg comm.xml JimStim-0.x.prof JimStim-2.x.prof '/usr/local/share/MegaTunix/Interrogator/Profiles/JimStim'
test -z "/usr/local/share/MegaTunix/Interrogator" || .././install-sh -c -d "/usr/local/share/MegaTunix/Interrogator"
 /usr/bin/install -c -m 644 README '/usr/local/share/MegaTunix/Interrogator'
Making install in LookupTables
test -z "/usr/local/share/MegaTunix/LookupTables" || .././install-sh -c -d "/usr/local/share/MegaTunix/LookupTables"
 /usr/bin/install -c -m 644 cltfactor.inc gm3800clt.inc matfactor.inc gm3800mat.inc kpafactor.inc kpafactor4250.inc kpafactor4115.inc kpafactorMPXH6400A.inc barofactor4115.inc barofactor4250.inc InnoLC1_0_5V.inc InnoLM1_0_5V.inc InnoLM1_1_2V.inc TEWBLin.inc DIYWB.inc AEMWB.inc CustomWB.inc NBafr100.inc Uego1000WB.inc '/usr/local/share/MegaTunix/LookupTables'
Making install in RealtimeMaps
test -z "/usr/local/share/MegaTunix/RealtimeMaps" || .././install-sh -c -d "/usr/local/share/MegaTunix/RealtimeMaps"
 /usr/bin/install -c -m 644 FreeEMS.rtv_map JimStim-2.x.rtv_map MS1-BnG-Std.rtv_map MS1-DT-Std.rtv_map MS1-Extra-HR-08x.rtv_map MS1-Extra-HR-011d.rtv_map MS1-Extra-029x.rtv_map MS2-Std.rtv_map MS2-Extra-2.1.0.rtv_map MS2-Extra-3.0.x.rtv_map MS2-Extra-3.0.3w.rtv_map MS2-Extra-3.0.3y.rtv_map PIS_V1_00-firmware.rtv_map '/usr/local/share/MegaTunix/RealtimeMaps'
Making install in RuntimeSliders
test -z "/usr/local/share/MegaTunix/RuntimeSliders" || .././install-sh -c -d "/usr/local/share/MegaTunix/RuntimeSliders"
 /usr/bin/install -c -m 644 README FreeEMS.xml JimStim-2.x.xml MS1-DT.xml MS1-Extra.xml MS1-Std.xml MS2-Extra.xml MS2-Std.xml PIS_V1_00.xml '/usr/local/share/MegaTunix/RuntimeSliders'
Making install in RuntimeStatus
test -z "/usr/local/share/MegaTunix/RuntimeStatus" || .././install-sh -c -d "/usr/local/share/MegaTunix/RuntimeStatus"
 /usr/bin/install -c -m 644 FreeEMS.xml JimStim-2.x.xml MS1-Extra.xml MS1-Std.xml MS2-Extra.xml MS2-Std.xml PIS_V1_00.xml '/usr/local/share/MegaTunix/RuntimeStatus'
Making install in RuntimeText
test -z "/usr/local/share/MegaTunix/RuntimeText" || .././install-sh -c -d "/usr/local/share/MegaTunix/RuntimeText"
 /usr/bin/install -c -m 644 FreeEMS.xml JimStim-2.x.xml MS1-DT.xml MS1-Extra.xml MS1-Std.xml MS2-Std.xml MS2-Extra.xml PIS_V1_00.xml '/usr/local/share/MegaTunix/RuntimeText'
Making install in Gui
test -z "/usr/local/share/MegaTunix/Gui" || .././install-sh -c -d "/usr/local/share/MegaTunix/Gui"
 /usr/bin/install -c -m 644 B_n_G_constants.datamap Dualtable-constants.datamap JimStim-0.x.datamap JimStim-2.x.datamap PIS-alpha_biar_16x10.datamap PIS-alpha_bpw_16x10.datamap PIS-biar_16x16.datamap PIS-boost_16x10.datamap PIS-bpw_16x16.datamap PIS-corrections.datamap PIS-ego_16x16.datamap PIS-runtime.datamap PIS-settings.datamap afrtable_8x8x2-029x.datamap afrtable_12x12x2-MS2.datamap afrtable_12x12x2-MS2-Extra.datamap boost_6x6x3-029x.datamap datalogging.datamap dt-params.datamap enrichments_BnG.datamap error_status.datamap freeems-debug.datamap jimstim-runtime.datamap logviewer.datamap memviewer.datamap ms2-accel.datamap ms2-alpha-n_6x6x1.datamap ms2-e-3.x-accel.datamap ms2-e-3.x-boost_knock_launch.datamap ms2-e-3.x-can.datamap ms2-e-3.x-corrections_misc.datamap ms2-e-3.x-crank_idle_warmup.datamap ms2-e-3.1.x-crank_idle_warmup.datamap ms2-e-3.x-debugging.datamap ms2-e-3.x-ego_rev.datamap ms2-e-3.0.3v-ego_rev.datamap ms2-e-3.x-globals.datamap ms2-e-3.x-ignition.datamap ms2-e-3.0.3v-ignition.datamap ms2-e-3.x-inj_timing_6x6x3.datamap '/usr/local/share/MegaTunix/Gui'
 /usr/bin/install -c -m 644 ms2-e-3.0.3v-inj_timing_6x6x3.datamap ms2-e-3.x-local_outputs.datamap ms2-e-3.x-nitrous_staging_orfc.datamap ms2-e-3.x-noise_lag.datamap ms2-e-3.x-remote_outputs.datamap ms2-e-3.x-sequential.datamap ms2-e-accel.datamap ms2-e-boost_knock_launch.datamap ms2-e-boost_8x8x2.datamap ms2-e-corrections_misc.datamap ms2-e-crank_idle_warmup.datamap ms2-e-debugging.datamap ms2-e-ego_rev.datamap ms2-e-globals.datamap ms2-e-ignition.datamap ms2-e-nitrous_staging_orfc.datamap ms2-e-noise_lag.datamap ms2-e-rotary-split.datamap ms2-e-runtime.datamap ms2-e-toothtrigger-2.1.x.datamap ms2-e-toothtrigger-3.x.datamap ms2-globals.datamap ms2-idle_ego_rev.datamap ms2-ignition.datamap ms2-knock_dwell.datamap ms2-misc-fuel.datamap ms2-runtime.datamap ms2-user_outputs.datamap ms2-warmup.datamap msns-e-accelwizard-029x.datamap msns-e-advanced-029x.datamap msns-e-boost-knock-029x.datamap msns-e-crank-ase-029x.datamap msns-e-ego-029x.datamap msns-e-features-029x.datamap msns-e-fuelconstants-hr.datamap msns-e-fuelconstants-029x.datamap msns-e-idle-029x.datamap msns-e-idle-hr.datamap msns-e-output-pins-029x.datamap '/usr/local/share/MegaTunix/Gui'
 /usr/bin/install -c -m 644 msns-e-output-pins-hr-011x.datamap msns-e-outputs-sel-029x.datamap msns-e-toothtrigger-029x.datamap msns-e-traction-029x.datamap msns-e-water-nos-launch-029x.datamap msns-e-wheeldecode-029x.datamap msns-e-wheeldecode-hr_10x.datamap msns-e-wheeldecode-hr_11d.datamap raweditor.datamap rotary-trail-029x.datamap runtime.datamap sparktable_12x12x1-MS2.datamap sparktable_12x12x2-029x.datamap sparktable_12x12x3-MS2-Extra.datamap sparktable_8x8e-EDIS.datamap sparktable_8x8e-Std.datamap template.datamap test.datamap tools.datamap vetable_12x12x2-MS2.datamap vetable_12x12x3-029x.datamap vetable_12x12x3-MS2-Extra.datamap vetable_16x16x3-FreeEMS.datamap vetable_16x16x3-MS2-Extra.datamap vetable_8x8e-BnG.datamap vetable_8x8e-DT_1.datamap vetable_8x8e-DT_2.datamap vetrim_16x16x4-MS2-Extra-3.x.datamap warmupwizard.datamap B_n_G_constants.glade Dualtable-constants.glade JimStim-0.x.glade JimStim-2.x.glade PIS-alpha_biar_16x10.glade PIS-alpha_bpw_16x10.glade PIS-biar_16x16.glade PIS-boost_16x10.glade PIS-bpw_16x16.glade PIS-corrections.glade PIS-ego_16x16.glade '/usr/local/share/MegaTunix/Gui'
 /usr/bin/install -c -m 644 PIS-runtime.glade PIS-settings.glade afrtable_8x8x2.glade afrtable_12x12x2.glade boost_6x6x3.glade datalogging.glade dt-params.glade enrichments.glade error_status.glade freeems-debug.glade inj_timing_6x6x3.glade jimstim-runtime.glade logviewer.glade main_win32.glade main.glade memviewer.glade ms2-accel.glade ms2-alpha-n_6x6x1.glade ms2-e-3.x-boost_knock_launch.glade ms2-e-3.x-can.glade ms2-e-3.x-corrections_misc.glade ms2-e-3.x-crank_idle_warmup.glade ms2-e-3.1.x-crank_idle_warmup.glade ms2-e-3.x-debugging.glade ms2-e-3.0.3v-ego_rev.glade ms2-e-3.x-globals.glade ms2-e-3.x-ignition.glade ms2-e-3.0.3y-ignition.glade ms2-e-3.x-nitrous_staging_orfc.glade ms2-e-3.0.3v-nitrous_staging_orfc.glade ms2-e-3.0.3y-noise_lag.glade ms2-e-3.x-noise_lag.glade ms2-e-3.x-remote_outputs.glade ms2-e-3.x-sequential.glade ms2-e-accel.glade ms2-e-boost_knock_launch.glade ms2-e-boost_8x8x2.glade ms2-e-corrections_misc.glade ms2-e-crank_idle_warmup.glade ms2-e-debugging.glade '/usr/local/share/MegaTunix/Gui'
 /usr/bin/install -c -m 644 ms2-e-ego_rev.glade ms2-e-globals.glade ms2-e-ignition.glade ms2-e-nitrous_staging_orfc.glade ms2-e-noise_lag.glade ms2-e-runtime.glade ms2-e-toothtrigger.glade ms2-globals.glade ms2-idle_ego_rev.glade ms2-ignition.glade ms2-knock_dwell.glade ms2-misc-fuel.glade ms2-e-rotary-split.glade ms2-runtime.glade ms2-user_outputs.glade ms2-warmup.glade msns-e-accelwizard.glade msns-e-advanced.glade msns-e-boost-knock.glade msns-e-crank-ase.glade msns-e-ego.glade msns-e-features.glade msns-e-fuelconstants.glade msns-e-idle.glade msns-e-output-pins.glade msns-e-output-pins-hr-011x.glade msns-e-outputs-sel.glade msns-e-toothtrigger.glade msns-e-traction.glade msns-e-water-nos-launch.glade msns-e-wheeldecode.glade msns-e-wheeldecode-029yx.glade msns-e-wheeldecode-hr-11d.glade mtxloader.glade raweditor.glade rotary-trail.glade runtime.glade sparktable_12x12x1.glade sparktable_12x12x2.glade sparktable_12x12x3.glade '/usr/local/share/MegaTunix/Gui'
 /usr/bin/install -c -m 644 sparktable_8x8e.glade template.glade test.glade tools.glade vetable_12x12x2.glade vetable_12x12x3.glade vetable_16x16x3.glade vetable_8x8e.glade vetrim_16x16x4.glade warmupwizard.glade '/usr/local/share/MegaTunix/Gui'
Making install in menu
test -z "/usr/local/share/applications/" || .././install-sh -c -d "/usr/local/share/applications/"
 /usr/bin/install -c -m 644 megatunix.desktop dashdesigner.desktop gaugedesigner.desktop mtxloader.desktop '/usr/local/share/applications/'
Making install in category
test -z "/usr/local/etc/xdg/menus/applications-merged/" || .././install-sh -c -d "/usr/local/etc/xdg/menus/applications-merged/"
 /usr/bin/install -c -m 644 automotive.menu '/usr/local/etc/xdg/menus/applications-merged/'
Making install in icons
test -z "/usr/local/share/icons/" || .././install-sh -c -d "/usr/local/share/icons/"
 /usr/bin/install -c -m 644 megatunix.xpm automotive.xpm dashdesigner.xpm gaugedesigner.xpm mtxloader.xpm '/usr/local/share/icons/'
Making install in desktop
test -z "/usr/local/share/desktop-directories/" || .././install-sh -c -d "/usr/local/share/desktop-directories/"
 /usr/bin/install -c -m 644 Automotive.directory '/usr/local/share/desktop-directories/'
Making install in po
if test -r ".././mkinstalldirs"; then \
     .././mkinstalldirs /usr/local/share/MegaTunix; \
   else \
     /bin/sh ../mkinstalldirs /usr/local/share/MegaTunix; \
   fi
if test "megatunix" = "glib"; then \
       .././mkinstalldirs /usr/local/share/MegaTunix/glib-2.0/gettext/po; \
     else \
       /bin/sh ../mkinstalldirs /usr/local/share/MegaTunix/glib-2.0/gettext/po; \
     fi; \
     /usr/bin/install -c -m 644 ./Makefile.in.in \
           /usr/local/share/MegaTunix/glib-2.0/gettext/po/Makefile.in.in; \
   else \
   fi
Mike-Cranes-iMac27:MegaTunix mikecrane$ mv ~/.MegaTunix/config ~/.MegaTunix/config.oldMike-Cranes-iMac27:MegaTunix mikecrane$ ./src/megatunix
Xlib:  extension "RANDR" missing on display "/tmp/launch-1Z1iRW/:0".
Yamaha YZF1000 MSExtra 3.1
24c
Postby djandruczyk » Sun Feb 20, 2011 2:55 pm
your screenshots had "baud_rate" in them (for some of hte shots) which is a deprecated key and current version will NOT create that, that's how I know it wasn't a "fresh start" for all the tests.
A major bugfix went in a couple minutes ago (4:50 PM EST) which fixes a bug regarding reqfuel, num cyls, num injectors num squirts controls that you may wish to pull.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby 24c » Sun Feb 20, 2011 3:00 pm
OK, Dave posted (originally above your last response, was editing and adding the screenshot)... I tried git pull rather than git pull origin master and it wasn't "already upto date" this time, like it was when you made the suggestion to upgrade yesterday, so I did a make etc.
Code: Select all
Last login: Sun Feb 20 21:46:52 on ttys000
Mike-Cranes-iMac27:~ mikecrane$ open .MegaTunix/config
The file /Users/mikecrane/.MegaTunix/config does not exist.
remote: Counting objects: 128, done.
remote: Compressing objects: 100% (91/91), done.
remote: Total 91 (delta 78), reused 0 (delta 0)
Unpacking objects: 100% (91/91), done.
   3f34fc2..7147eb6  modular_0.4 -> origin/modular_0.4
Updating 3f34fc2..7147eb6
Fast-forward
 .../Profiles/FreeEMS/FreeEMS_0.0.0.prof.in         |    4 +-
 Interrogator/Profiles/FreeEMS/comm.xml             |   21 +-
 include/3d_vetable.h                               |    6 +
 include/timeout_handlers.h                         |    1 +
 src/3d_vetable.c                                   |  126 ++++---
 src/comms.c                                        |   54 +++-
 src/conversions.c                                  |   28 +-
 src/debugging.c                                    |    5 +-
 src/init.c                                         |    3 +
 src/keybinder.c                                    |    2 +-
 src/main.c                                         |    6 +-
 src/notifications.c                                |   29 +-
 src/plugins/freeems/datamgmt.c                     |   16 +-
 src/plugins/freeems/datamgmt.h                     |   12 +-
 src/plugins/freeems/freeems_comms.c                |   25 +-
 src/plugins/freeems/freeems_comms.h                |    2 +-
 src/plugins/freeems/freeems_helpers.c              |   35 ++-
 src/plugins/freeems/freeems_helpers.h              |    5 +-
 src/plugins/freeems/freeems_plugin.c               |   42 ++-
 src/plugins/freeems/interrogate.c                  |   15 +
 src/plugins/freeems/packet_handlers.c              |   11 +-
 src/plugins/freeems/vetable_gui.c                  |  424 +++++++++++++++++++-
 src/plugins/mscommon/2d_table_editor.c             |    4 +
 src/plugins/mscommon/mscommon_gui_handlers.c       |   28 +-
 src/plugins/mscommon/mscommon_rtv_processor.c      |    7 +-
 src/rtv_processor.c                                |   10 +-
 src/timeout_handlers.c                             |   13 +-
 27 files changed, 772 insertions(+), 162 deletions(-)
Code: Select all
Mike-Cranes-iMac27:MegaTunix mikecrane$ mv ~/.MegaTunix/config ~/.MegaTunix/config.oldmv: /Users/mikecrane/.MegaTunix/config: No such file or directory
Mike-Cranes-iMac27:MegaTunix mikecrane$ ./src/Megatunix
should run first_time_wizard
**Success**
It connects again now Dave, just a perceived lag, from clicking on Find my ECU to actually connecting. Seemed quicker previously FWIW.
24c
Postby djandruczyk » Sun Feb 20, 2011 3:24 pm
24c wrote:It connects again now Dave, just a perceived lag, from clicking on Find my ECU to actually connecting. Seemed quicker previously FWIW.
If you have less ports in the potential ports list than it WILL appear to connect quicker. It goes through the list in linear order, so if you have 50 ports that DON'T work and the one that works at the end, it'll take a bit to test all of them until it finds the one that works. I'll tweak that so that it sticks the new device at the BEGINNING of the list which should make it "feel" faster.
Pushed up that change, all newly detected ports go the the beginning of the potential ports list. This should make detection come very quickly on future mtx startup, it MAY NOT do that however during the first run of the locate port wizard, becasue during that time megatunix is still looping through the ports list trying to find the device, and that list doesn't change until after you select the new port and apply, and there's no telling where mtx is within that list, so sometimes it may be very fast, if it happens to time things right where on the next comms test it reads the new entry, or it could take longer, but future megatunix loads should be consistently fast.
Reason: added the fix he seems to want....
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby 24c » Sun Feb 20, 2011 3:28 pm
djandruczyk wrote: I'll tweak that so that it sticks the new device at the BEGINNING of the list which should make it "feel" faster.
OK, anyway, thanks for sorting it out, even though I had a workaround. I'll update the MacBook now, and do a fresh git pull on Linux Mint and see what happens there... :)
24c
Postby djandruczyk » Sun Feb 20, 2011 3:32 pm
Actually that fix is already pushed up...
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby 24c » Sun Feb 20, 2011 3:49 pm
djandruczyk wrote:Actually that fix is already pushed up...
Got it, thanks again.
Code: Select all
Mike-Cranes-iMac27:~ mikecrane$ cd git/megaTunix
Mike-Cranes-iMac27:megaTunix mikecrane$ git pull
remote: Counting objects: 12, done.
remote: Compressing objects: 100% (8/8), done.
remote: Total 8 (delta 6), reused 0 (delta 0)
Unpacking objects: 100% (8/8), done.
   7147eb6..3d3afef  modular_0.4 -> origin/modular_0.4
Updating 7147eb6..3d3afef
Fast-forward
 src/3d_vetable.c |    4 ----
 src/comms.c      |   16 +++-------------
 2 files changed, 3 insertions(+), 17 deletions(-)
Mike-Cranes-iMac27:megaTunix mikecrane$ make
Mike-Cranes-iMac27:megaTunix mikecrane$ sudo rm -rf /usr/local/share/MegaTunix
Password:
Mike-Cranes-iMac27:megaTunix mikecrane$ sudo make install
I think I'll try this version on my bike Wednesday.
24c
Postby 24c » Sun Feb 20, 2011 4:36 pm
OK updated the MacBook Pro just now, couple of things as I am a numpty, I'll just explain what I did, it might help somebody, or let Dave know where I am going wrong. :)
These are the sequential instructions I placed in Terminal, I was already running the modular_0.4 branch, and just upgrading a working version.
Code: Select all
cd git/MegaTunix
git pull
make
password
sudo make install
Now when I ran MegaTunix it still had the old config file in, and although it loaded fine, because I had the correct port name in the config file, I needed to remove it, so MegaTunix will generate a new one...
Code: Select all
cd
sudo rm -rf .MegaTunix/config
password
megatunix
Now MegaTunix opens the splash or About screen, and you click on Find my ECU
then click on the Communications tab and then Locate Port following the dialog instructions.
Obviously you have a powered MegaSquirt unit, and a connection via USB to the serial port.
After a while, the port is detected, you click on the one you want to use, and after a short stall, MegaTunix will communicate, and the other dialog box will go away.
Before I Quit/Exit MegaTunix, I save all, and the next time I open from the same USB port, MegaTunix just kicks in, as it remembers the last known configuration etc 8)
PS You will still have to ask it to Find my ECU each time.
24c
Postby 24c » Wed Feb 23, 2011 1:45 pm
Hmmm, tried to get things running on the bike, started with TunerStudio, and got a config error, that wouldn't disappear. Nothing else had been altered, but fuel pump was chucking fuel into engine, so I unplugged the MicroSquirt.
Looked at things in MegaTunix, and I had all zeros in the tables, and then had total comms breakdown.
I had to reload the firmware and restore each MicroSquirt, and although the were loaded with MSExtra 3.0.3* they still need the boot loader jumper switched in to make good, and bring them all up to MSExtra 3.1.0.
In the process of restoring the MicroSquirts with a last known ECU setting, I used a combination of TunerStudio & MegaTunix, as TunerStudio was having Project errors. I imported the Tables from my last good TunerStudio msq, and switched this using MegaTunix to the other MicroSquirts (all running 3.1.0), via the import & export function. One time I get a seg fault, but couldn't repeat using gdb, however after I had updated a MicroSquirt with a 3.1.0 msq, and tried to Find my ECU on opening MegaTunix, I got this error. Does it mean anything?
Code: Select all
Last login: Wed Feb 23 20:22:11 on ttys000
Mike-Cranes-iMac27:~ mikecrane$ megatunix
Xlib:  extension "RANDR" missing on display "/tmp/launch-5ZV4dh/:0".
(megatunix:74534): Gtk-CRITICAL **: gtk_text_buffer_emit_insert: assertion `g_utf8_validate (text, len, NULL)' failed
^C
Mike-Cranes-iMac27:~ mikecrane$ gdb
GNU gdb 6.3.50-20050815 (Apple version gdb-1510) (Wed Sep 22 02:45:02 UTC 2010)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB.  Type "show warranty" for details.
This GDB was configured as "x86_64-apple-darwin".
(gdb) file megatunix
Reading symbols for shared libraries ...warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libutil/error.o" - no debug information available for "libutil/error.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libutil/glue.o" - no debug information available for "libutil/glue.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libutil/mipmap.o" - no debug information available for "libutil/mipmap.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libutil/project.o" - no debug information available for "libutil/project.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libutil/quad.o" - no debug information available for "libutil/quad.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libutil/registry.o" - no debug information available for "libutil/registry.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libtess/dict.o" - no debug information available for "libtess/dict.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libtess/geom.o" - no debug information available for "libtess/geom.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libtess/memalloc.o" - no debug information available for "libtess/memalloc.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libtess/mesh.o" - no debug information available for "libtess/mesh.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libtess/normal.o" - no debug information available for "libtess/normal.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libtess/priorityq.o" - no debug information available for "libtess/priorityq.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libtess/render.o" - no debug information available for "libtess/render.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libtess/sweep.o" - no debug information available for "libtess/sweep.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libtess/tess.o" - no debug information available for "libtess/tess.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libtess/tessmono.o" - no debug information available for "libtess/tessmono.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/interface/bezierEval.o" - no debug information available for "libnurbs/interface/bezierEval.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/interface/bezierPatch.o" - no debug information available for "libnurbs/interface/bezierPatch.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/interface/bezierPatchMesh.o" - no debug information available for "libnurbs/interface/bezierPatchMesh.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/interface/glcurveval.o" - no debug information available for "libnurbs/interface/glcurveval.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/interface/glinterface.o" - no debug information available for "libnurbs/interface/glinterface.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/interface/glrenderer.o" - no debug information available for "libnurbs/interface/glrenderer.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/interface/glsurfeval.o" - no debug information available for "libnurbs/interface/glsurfeval.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/interface/incurveeval.o" - no debug information available for "libnurbs/interface/incurveeval.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/interface/insurfeval.o" - no debug information available for "libnurbs/interface/insurfeval.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/arc.o" - no debug information available for "libnurbs/internals/arc.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/arcsorter.o" - no debug information available for "libnurbs/internals/arcsorter.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/arctess.o" - no debug information available for "libnurbs/internals/arctess.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/backend.o" - no debug information available for "libnurbs/internals/backend.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/basiccrveval.o" - no debug information available for "libnurbs/internals/basiccrveval.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/basicsurfeval.o" - no debug information available for "libnurbs/internals/basicsurfeval.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/bin.o" - no debug information available for "libnurbs/internals/bin.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/bufpool.o" - no debug information available for "libnurbs/internals/bufpool.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/cachingeval.o" - no debug information available for "libnurbs/internals/cachingeval.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/ccw.o" - no debug information available for "libnurbs/internals/ccw.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/coveandtiler.o" - no debug information available for "libnurbs/internals/coveandtiler.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/curve.o" - no debug information available for "libnurbs/internals/curve.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/curvelist.o" - no debug information available for "libnurbs/internals/curvelist.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/curvesub.o" - no debug information available for "libnurbs/internals/curvesub.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/dataTransform.o" - no debug information available for "libnurbs/internals/dataTransform.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/displaylist.o" - no debug information available for "libnurbs/internals/displaylist.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/flist.o" - no debug information available for "libnurbs/internals/flist.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/flistsorter.o" - no debug information available for "libnurbs/internals/flistsorter.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/hull.o" - no debug information available for "libnurbs/internals/hull.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/intersect.o" - no debug information available for "libnurbs/internals/intersect.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/knotvector.o" - no debug information available for "libnurbs/internals/knotvector.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/mapdesc.o" - no debug information available for "libnurbs/internals/mapdesc.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/mapdescv.o" - no debug information available for "libnurbs/internals/mapdescv.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/maplist.o" - no debug information available for "libnurbs/internals/maplist.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/mesher.o" - no debug information available for "libnurbs/internals/mesher.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/monoTriangulationBackend.o" - no debug information available for "libnurbs/internals/monoTriangulationBackend.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/monotonizer.o" - no debug information available for "libnurbs/internals/monotonizer.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/nurbsinterfac.o" - no debug information available for "libnurbs/internals/nurbsinterfac.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/nurbstess.o" - no debug information available for "libnurbs/internals/nurbstess.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/patch.o" - no debug information available for "libnurbs/internals/patch.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/patchlist.o" - no debug information available for "libnurbs/internals/patchlist.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/quilt.o" - no debug information available for "libnurbs/internals/quilt.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/reader.o" - no debug information available for "libnurbs/internals/reader.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/renderhints.o" - no debug information available for "libnurbs/internals/renderhints.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/slicer.o" - no debug information available for "libnurbs/internals/slicer.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/sorter.o" - no debug information available for "libnurbs/internals/sorter.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/splitarcs.o" - no debug information available for "libnurbs/internals/splitarcs.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/subdivider.o" - no debug information available for "libnurbs/internals/subdivider.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/tobezier.o" - no debug information available for "libnurbs/internals/tobezier.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/trimline.o" - no debug information available for "libnurbs/internals/trimline.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/trimregion.o" - no debug information available for "libnurbs/internals/trimregion.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/trimvertpool.o" - no debug information available for "libnurbs/internals/trimvertpool.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/uarray.o" - no debug information available for "libnurbs/internals/uarray.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/internals/varray.o" - no debug information available for "libnurbs/internals/varray.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/directedLine.o" - no debug information available for "libnurbs/nurbtess/directedLine.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/gridWrap.o" - no debug information available for "libnurbs/nurbtess/gridWrap.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/monoChain.o" - no debug information available for "libnurbs/nurbtess/monoChain.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/monoPolyPart.o" - no debug information available for "libnurbs/nurbtess/monoPolyPart.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/monoTriangulation.o" - no debug information available for "libnurbs/nurbtess/monoTriangulation.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/partitionX.o" - no debug information available for "libnurbs/nurbtess/partitionX.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/partitionY.o" - no debug information available for "libnurbs/nurbtess/partitionY.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/polyDBG.o" - no debug information available for "libnurbs/nurbtess/polyDBG.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/polyUtil.o" - no debug information available for "libnurbs/nurbtess/polyUtil.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/primitiveStream.o" - no debug information available for "libnurbs/nurbtess/primitiveStream.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/quicksort.o" - no debug information available for "libnurbs/nurbtess/quicksort.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/rectBlock.o" - no debug information available for "libnurbs/nurbtess/rectBlock.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/sampleComp.o" - no debug information available for "libnurbs/nurbtess/sampleComp.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/sampleCompBot.o" - no debug information available for "libnurbs/nurbtess/sampleCompBot.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/sampleCompRight.o" - no debug information available for "libnurbs/nurbtess/sampleCompRight.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/sampleCompTop.o" - no debug information available for "libnurbs/nurbtess/sampleCompTop.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/sampleMonoPoly.o" - no debug information available for "libnurbs/nurbtess/sampleMonoPoly.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/sampledLine.o" - no debug information available for "libnurbs/nurbtess/sampledLine.cc".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glu/sgi/libnurbs/nurbtess/searchTree.o" - no debug information available for "libnurbs/nurbtess/searchTree.cc".
.warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_cgl.o" - no debug information available for "apple_cgl.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_glx.o" - no debug information available for "apple_glx.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_glx_context.o" - no debug information available for "apple_glx_context.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_glx_drawable.o" - no debug information available for "apple_glx_drawable.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_glx_pbuffer.o" - no debug information available for "apple_glx_pbuffer.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_glx_pixmap.o" - no debug information available for "apple_glx_pixmap.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_glx_surface.o" - no debug information available for "apple_glx_surface.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_visual.o" - no debug information available for "apple_visual.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_xgl_api.o" - no debug information available for "apple_xgl_api.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_xgl_api_additional.o" - no debug information available for "apple_xgl_api_additional.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_xgl_api_read.o" - no debug information available for "apple_xgl_api_read.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_xgl_api_stereo.o" - no debug information available for "apple_xgl_api_stereo.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/apple_xgl_api_viewport.o" - no debug information available for "apple_xgl_api_viewport.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/appledri.o" - no debug information available for "appledri.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../clientattrib.o" - no debug information available for "../clientattrib.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../compsize.o" - no debug information available for "../compsize.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../glcontextmodes.o" - no debug information available for "../glcontextmodes.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/glx_empty.o" - no debug information available for "glx_empty.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/glx_error.o" - no debug information available for "glx_error.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../glx_pbuffer.o" - no debug information available for "../glx_pbuffer.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../glx_query.o" - no debug information available for "../glx_query.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../glxcmds.o" - no debug information available for "../glxcmds.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../glxcurrent.o" - no debug information available for "../glxcurrent.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../glxext.o" - no debug information available for "../glxext.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../glxextensions.o" - no debug information available for "../glxextensions.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/glxreply.o" - no debug information available for "glxreply.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../pixel.o" - no debug information available for "../pixel.c".
warning: Could not find object file "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_x11_mesa/work/Mesa-7.8.2/src/glx/apple/../xfont.o" - no debug information available for "../xfont.c".
.................................................. done
Reading symbols from /usr/local/bin/megatunix...done.
(gdb) run
Starting program: /usr/local/bin/megatunix
Reading symbols for shared libraries .+++++++++++++++++++++++++++++++++++++++++++++++++++++.......................................................................................... done
Reading symbols for shared libraries . done
Reading symbols for shared libraries .. done
(megatunix:74567): Gtk-CRITICAL **: gtk_text_buffer_emit_insert: assertion `g_utf8_validate (text, len, NULL)' failed
^C
Program received signal SIGINT, Interrupt.
0x00007fff869eae92 in select$DARWIN_EXTSN ()
(gdb) backtrace
#0  0x00007fff869eae92 in select$DARWIN_EXTSN ()
#1  0x00000001010677a2 in g_poll ()
#2  0x000000010105a508 in g_main_context_iterate ()
#3  0x000000010105a805 in g_main_loop_run ()
#4  0x00000001005ebc70 in gtk_main ()
#5  0x00000001000322b0 in main (argc=1, argv=0x7fff5fbffa00) at main.c:164
(gdb)
24c
Re: MegaTunix on OS-X (revised)
Postby djandruczyk » Wed Feb 23, 2011 4:08 pm
24c wrote:Hmmm, tried to get things running on the bike, started with TunerStudio, and got a config error, that wouldn't disappear. Nothing else had been altered, but fuel pump was chucking fuel into engine, so I unplugged the MicroSquirt.
Code: Select all
^C
(gdb) run
^C
(gdb) backtrace
(gdb)
When you get a "Gtk-CRITICAL" Error it's one of GTK+'s internal assertion checks, which usually means I fed bad data to a GTK+ call. To see wht caused it under gdb, use "run --g-fatal-warnings" and it'll stop when it does that instead of just warning about it and continuing on and thus backtrace will give useful information.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby 24c » Fri Feb 25, 2011 8:52 am
djandruczyk wrote: To see what caused it under gdb, use "run --g-fatal-warnings" and it'll stop when it does that instead of just warning about it and continuing on and thus backtrace will give useful information.
OK, thanks for that...first session FYI. IIRC I was trying to load the Dashboard, when it started to fail.
Code: Select all
Last login: Fri Feb 25 12:47:43 on console
Macintosh-6:~ Macbook$ gdb
....trimmed for brevity
(gdb) run --g-fatal-warnings
Starting program: /usr/local/bin/megatunix --g-fatal-warnings
Xlib:  extension "RANDR" missing on display "/tmp/launch-FFxm2Z/:0".
Gtk-WARNING **: Could not find the icon 'application-xml'. The 'hicolor' theme
was not found either, perhaps you need to install it.
You can get a copy from:
   http://icon-theme.freedesktop.org/releases
aborting...
Program received signal SIGABRT, Aborted.
0x00007fff84b2b616 in __kill ()
The program being debugged has been started already.
Start it from the beginning? (y or n) n
Program not restarted.
(gdb) continue
Continuing.
Program terminated with signal SIGABRT, Aborted.
The program no longer exists.
(gdb) run
aborting...
(gdb) run
(gdb) run
Start it from the beginning? (y or n) y
Gtk-WARNING **: Unable to find default local directory monitor type
aborting...
(gdb) backtrace
#0  0x00007fff84b2b616 in __kill ()
#1  0x00007fff84bcbcca in abort ()
#2  0x00000001010714f4 in g_logv ()
#3  0x0000000101071814 in g_log ()
#4  0x00000001005b7444 in gtk_folder_constructed ()
#5  0x0000000100ff49bb in g_object_newv ()
#6  0x0000000100ff51a2 in g_object_new_valist ()
#7  0x0000000100ff53ea in g_object_new ()
#8  0x00000001005b7a24 in enumerate_children_callback ()
#9  0x0000000100b72c5a in complete_in_idle_cb_for_thread ()
#10 0x0000000101067f19 in g_main_context_dispatch ()
#11 0x000000010106b4f1 in g_main_context_iterate ()
#12 0x000000010106b805 in g_main_loop_run ()
#13 0x000000010058196d in gtk_dialog_run ()
#14 0x000000010039f576 in choose_file (data=0x107ef6640) at getfiles.c:508
#15 0x00000001016b8388 in select_file_for_ecu_backup (widget=0x102b713c0, data=0x0) at fileio.c:69
#16 0x0000000100fee0d2 in g_closure_invoke ()
#17 0x0000000101001c9b in signal_emit_unlocked_R ()
#18 0x00000001010036c4 in g_signal_emit_valist ()
#19 0x0000000101003a94 in g_signal_emit ()
#20 0x0000000100555f25 in gtk_real_button_released ()
#21 0x0000000100fee0d2 in g_closure_invoke ()
#22 0x000000010100196d in signal_emit_unlocked_R ()
#23 0x00000001010036c4 in g_signal_emit_valist ()
#24 0x0000000101003a94 in g_signal_emit ()
#25 0x0000000100554235 in gtk_button_button_release ()
#26 0x0000000100602a5f in _gtk_marshal_BOOLEAN__BOXED ()
#27 0x0000000100fee0d2 in g_closure_invoke ()
#28 0x0000000101001e1c in signal_emit_unlocked_R ()
#29 0x0000000101003396 in g_signal_emit_valist ()
#30 0x0000000101003a94 in g_signal_emit ()
#31 0x0000000100718d4e in gtk_widget_event_internal ()
#32 0x00000001005fb5d7 in gtk_propagate_event ()
#33 0x00000001005fc886 in gtk_main_do_event ()
#34 0x0000000100a0e934 in gdk_event_dispatch ()
#35 0x0000000101067f19 in g_main_context_dispatch ()
#36 0x000000010106b4f1 in g_main_context_iterate ()
#37 0x000000010106b805 in g_main_loop_run ()
#38 0x00000001005fcc60 in gtk_main ()
#39 0x0000000100032478 in main (argc=1, argv=0x7fff5fbffa20) at main.c:164
(gdb) run
aborting...
(gdb) backtrace
#14 0x000000010039f576 in choose_file (data=0x106cabb70) at getfiles.c:508
#15 0x000000010001be21 in select_datalog_for_export (widget=0x10192c640, data=0x0) at datalogging_gui.c:502
#37 0x000000010106b9e3 in g_main_context_iteration ()
#38 0x00000001005fcaf1 in gtk_main_iteration ()
#39 0x000000010001d596 in pf_dispatcher (data=0x0) at dispatcher.c:132
#40 0x000000010106868d in g_timeout_dispatch ()
#41 0x0000000101067f19 in g_main_context_dispatch ()
#42 0x000000010106b4f1 in g_main_context_iterate ()
#43 0x000000010106b805 in g_main_loop_run ()
#44 0x00000001005fcc60 in gtk_main ()
#45 0x0000000100032478 in main (argc=1, argv=0x7fff5fbffa20) at main.c:164
(gdb) Quit
(gdb) bash
Undefined command: "bash".  Try "help".
(gdb) kill
Kill the program being debugged? (y or n) y
(gdb)
and the second session, again FYI. I was running the bike up & connected to the laptop, running MegaTunix in X11 via USBSerial & a MicroSquirt using MSExtra3.1.0 firmware.
Code: Select all
Last login: Fri Feb 25 13:44:24 on ttys000
Macintosh-6:~ Macbook$ megatunix
(megatunix:2101): Gtk-WARNING **: Could not find the icon 'application-xml'. The 'hicolor' theme
MS1 Reset detected!, lastcount 4, current 0
(megatunix:2101): Gtk-WARNING **: Unable to find default local directory monitor type
aborting...
(gdb) backtrace
#14 0x000000010039f576 in choose_file (data=0x106b1c790) at getfiles.c:508
#15 0x000000010001c28b in internal_datalog_dump (widget=0x0, data=0x0) at datalogging_gui.c:576
#16 0x0000000100022296 in prompt_to_save () at gui_handlers.c:1499
#17 0x000000010001e0e3 in leave (widget=0x10192c040, data=0x0) at gui_handlers.c:120
#18 0x0000000100fee0d2 in g_closure_invoke ()
#19 0x0000000101001c9b in signal_emit_unlocked_R ()
#20 0x00000001010036c4 in g_signal_emit_valist ()
#21 0x0000000101003a94 in g_signal_emit ()
#22 0x00000001005561a9 in gtk_button_button_press ()
#23 0x0000000100602a5f in _gtk_marshal_BOOLEAN__BOXED ()
#24 0x0000000100fee0d2 in g_closure_invoke ()
#25 0x0000000101001e1c in signal_emit_unlocked_R ()
#26 0x0000000101003396 in g_signal_emit_valist ()
#27 0x0000000101003a94 in g_signal_emit ()
#28 0x0000000100718d4e in gtk_widget_event_internal ()
#29 0x00000001005fb5d7 in gtk_propagate_event ()
#30 0x00000001005fc886 in gtk_main_do_event ()
#31 0x0000000100a0e934 in gdk_event_dispatch ()
#32 0x0000000101067f19 in g_main_context_dispatch ()
#33 0x000000010106b4f1 in g_main_context_iterate ()
#34 0x000000010106b805 in g_main_loop_run ()
#35 0x00000001005fcc60 in gtk_main ()
#36 0x0000000100032478 in main (argc=1, argv=0x7fff5fbffa20) at main.c:164
(gdb) continue
Continuing.
(gdb)
Hopefully there is something useful there.
24c
Postby djandruczyk » Fri Feb 25, 2011 12:51 pm
Unfortunately no, as it's crapping on the "Gtk-WARNING **: Unable to find default local directory monitor " warning, not the REAL problem. That issue is an OS-X/GTK+ problem that I don't know the solution to.
And as far as I know I'm not sure how to get it NOT to trap on that error with run with --g-fatal-errors as the docs indicate that that'll abort on ANY error.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby 24c » Fri Feb 25, 2011 4:46 pm
I googled "Gtk-WARNING **: Unable to find default local directory monitor" and this snippet caught my eye
browsing through the gtk and glib code makes me believe that it is
caused by the gtk_file_chooser* code in gtkoptions.c. Probably a
missing directory that the gtk code expects to be there. You can try
to edit out the gtk_file_chooser* code to check if my idea is right...
and this
...you are correct. The warning disappears when I comment out the
gtk_file_chooser* code related to SGF, import and export.....
...I believe this problem is specific to OS/X. Likely file system related. I believe that if you get
this warning, the one thing that will be disabled is the notification to the
chooser of files updates/deletions/creation. Things still work, but a
feature is turned off on the directories for getting such notifications....
...we've established that this is a symptom of a more general GTK issue, not a bug
in gnubg. The warnings do not appear with GTK+-2.12.9, so the problem was
introduced after that version.
24c
Postby viking_oz » Tue Dec 02, 2014 5:41 am
Hi all,
I've been trying to get MegaTunix compiled on my Mac. I've had the following problem for a while, and don't really know how to fix it.
When compiling MegaTunix, it all proceeds happily until it gets to the final stage (linking all hte libraries together) and then bails out with the following error message:
Code: Select all
Undefined symbols for architecture x86_64:
  "_gluOrtho2D", referenced from:
      _drawOrthoText in 3d_vetable.o
  "_gluPerspective", referenced from:
      _ve3d_expose_event in 3d_vetable.o
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
System specs:
Macbook Pro 8,1 (early 2011), OSX 10.10.1, Xcode 6.1, MacPorts 2.3.2
"which gcc" returns: /usr/bin/gcc
"gcc --version" returns:
Code: Select all
Configured with: --prefix=/Applications/Xcode.app/Contents/Developer/usr --with-gxx-include-dir=/usr/include/c++/4.2.1
Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn)
Target: x86_64-apple-darwin14.0.0
Thread model: posix
Is it because I am using a 64bit OS and the GTK stuff is only 32bit? If so, how do I fix it?
Many thanks,
Steve
viking_oz
Postby djandruczyk » Tue Dec 02, 2014 8:49 am
viking_oz wrote:Hi all,
Code: Select all
System specs:
Code: Select all
Thread model: posix
Many thanks,
Steve
Googling seems to indicate these functions are deprecated in OpenGL 3.0 and removed in OpenGL 3.1 though there may be alternatives, try the suggestions below
Edit 3d_vetable.c and change
gluOrtho2D(0.0,1.0,0.0,1.0);
to
glOrtho(0.0,1.0,0.0,1.0,-1,1);
Then replace:
gluPerspective(65.0, 1.0, 0.1, 4);
with
glMultMatrix(GLKMatrix4MakePerspective(65.0, 1.0, 0.1, 4).m);
and see if that works.
I don't have any new enough MAC HW to test with anything past 10.7.5 so I unfortunately cannot test it here.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby viking_oz » Tue Dec 02, 2014 4:52 pm
Hi Dave,
Thanks for the quick response!
djandruczyk wrote:Googling seems to indicate these functions are deprecated in OpenGL 3.0 and removed in OpenGL 3.1 though there may be alternatives, try the suggestions below
to
OK, that seems to work OK. Well, it seems to pass the compiler without errors.
djandruczyk wrote:Then replace:
with
Now this one chucks up an error:
Code: Select all
3d_vetable.c:969:60: error: member reference base type 'int' is not a structure
      or union
Doing some reading gives me the information that "m" should be the GLFloat* we are accessing. So where do we get that from?
djandruczyk wrote:I don't have any new enough MAC HW to test with anything past 10.7.5 so I unfortunately cannot test it here.
Bummer. Given the huge gap between posts here, I might be the only OSX user poking away at this. I'll do as much as I can to help - but the only OpenGL stuff I did was at Uni about 20 years ago.
viking_oz
Postby viking_oz » Wed Dec 03, 2014 3:22 am
I wrote:Doing some reading gives me the information that "m" should be the GLFloat* we are accessing. So where do we get that from?
Hopefully answering my own question - 'm' is the matrix that you are multiplying your matrix with. In this case, we multiply the output of GLKMatrix4MakePerspective() with 'm'.
I tried setting 'm' to be a 4x4 Identity matrix, defined a few lines higher up in the code. Without this, gcc / clang will throw up an error on 'm' not being defined.
Code: Select all
GLfloat m[16] = {1,0,0,0, 0,1,0,0, 0,0,1,0, 0,0,0,1};
Unfortunately, this gave the following compiler error:
Code: Select all
3d_vetable.c:972:61: error: member reference base type 'int' is not a structure or union
        glMultMatrixf(GLKMatrix4MakePerspective(65.0, 1.0, 0.1, 4).m);
Note: I'm using glMultMatrixf to match the floating point values used in the arrays. Not that it makes any difference whether I tried glMultMatrix, glMultMatrixf, or glMultMatrixd.
viking_oz
Postby djandruczyk » Wed Dec 10, 2014 6:24 am
Without physical access to a macbook capable of running 10.10 I don't see how I can solve this one without throwing a lot of darts around. OpenGL 3.2 and higher dropped all the old matrix functions an the fixed pipeline, so it broke this code as well..
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby djandruczyk » Fri Dec 12, 2014 6:55 pm
Good news, I got access to a 10.10 mac and megatunix now compiles and runs there. Current GIT has the fixes to compile and run with no more problems about GLU (it was a missing lib actually)
10.10 with macports for yosemite and xcode + cli tools installed and XQuartz (formerly X11.app)
David J. Andruczyk
djandruczyk
MS/Extra Guru
PreviousNext
Return to Megatunix (obsolete)
