looking for ipod touch, iphone or ipad
Moderator: djandruczyk
Re: looking for ipod touch, iphone or ipad
Postby Turboswede » Thu Mar 31, 2011 7:45 pm
djandruczyk wrote:
UnaClocker wrote:Make any progress with the iPhone I sent you?
I did a little, but then got blocked due to apple making it next to impossible to use any external devices with it unless either "approved by apple (big money, lots of time) or if it's WIFI, and so far I haven't located an affordable wifi/rs232 ready made device. I could make it work with a hacker board, but it requires jailbreaking the end user's phone and I don't know how many people are willing to do that.
I think most of the 'Squirt-heads here wouldn't have a problem Jailbreaking their phones/devices if it meant you could tune your car with your iPhone/iPad, etc.
With the proper 'break, an iOS device still works just fine and it opens up a world of apps you didn't have before. Basically it makes the device more like an Android, for good and bad reasons.
If you'd like to play with a iPhone 3G, let me know I have one available. I'd love to be able to Datalog the MegaSquirt and use the sensors in the phone to collect vehicle performance data.
Using something like RaceRender to combine the data with video content would make for some wicked cool videos to show friends and family.
BTW, I think you can hack a factory iPhone cable to get around the hardware handshake a little by using the dock connector with the proprietary chip built into it. I'll have to find some links to how to do this.
Really appreciate the work you're doing on this, it really helps make using MegaSquirt that much easier.
Turboswede
Postby 24c » Fri Apr 01, 2011 1:10 pm
Turboswede wrote:BTW, I think you can hack a factory iPhone cable to get around the hardware handshake a little by using the dock connector with the proprietary chip built into it.
This is for Cisco boxes, a serial cable to RJ45, pinouts on the net, and about $70.
They also do an evaluation board, but they have not responded to the webmail yet, keeps kicking back an error on me though.
Yamaha YZF1000 MSExtra 3.1
24c
Postby 68pishta » Fri Aug 16, 2013 12:03 pm
The bluetooth to ttl boards are 7 bucks now shipped from china. Im getting one shipped for testing. My issue is the 3.3v they quote (up to 7 tolerated But they have 5v models for $4 more?) but my question is can i just pin it'S Tx/Rx (Ttl) through to the MS bypassing (removing) the max232 chip i socketed? Does the max232 chip output ttl on pins 11,12? I can get the vcc to the board via pin 16's stable 5v. Looks like RS232 specs show a ttl output of 3-35v anyway.
68pishta
Postby piledriver » Sat Nov 30, 2013 3:04 am
68pishta wrote:The bluetooth to ttl boards are 7 bucks now shipped from china. Im getting one shipped for testing. My issue is the 3.3v they quote (up to 7 tolerated But they have 5v models for $4 more?) but my question is can i just pin it'S Tx/Rx (Ttl) through to the MS bypassing (removing) the max232 chip i socketed? Does the max232 chip output ttl on pins 11,12? I can get the vcc to the board via pin 16's stable 5v. Looks like RS232 specs show a ttl output of 3-35v anyway.
The issue is IOS will not work with any BT device that has not been "blessed" by Apple (bring your wallet) I don't think the BTserial support even exists.
Forget serial via BT. Wifi will probably be faster/more reliable anyway.
OTOH I run Android-x86 on my laptop and plug a USB cable into my MS3, picks up and uses the FTDI driver or BT without any fuss.
With class1 BT devices at both ends I get a true 300' range outdoors.
piledriver
Postby 24c » Sun Dec 08, 2013 11:22 am
I have just ordered a RedBear Mini, and it uses Bluetooth 4 or BLE, so the wallet squeezing MFI related comment isn't relevant anymore,
BLE (Bluetooth Low Energy) allows devices to talk to iOS and vice versa without having to sign up to anything. The RedBear unit has a Github and a few examples, which might interest tinkerers out there.
Out of curiosity, any news on the iOS projects that have been started? Jay Coggin & Dave W?
24c
Previous
Return to Megatunix (obsolete)
