had to upgrade glib to install 0.9.22
Moderator: djandruczyk
Just an FYI, I was installing Megatunix 0.9.22 from source on a laptop running OpenSuSE-10.3 and at the end of the compile it stopped with an error for an undefined reference to g_strcmp0. After research a while I found that this function is only available in glib from version 2.16 and up. Naturally the 10.3 version of OpenSuSE only had version 2.14. I ended up downloaded a src rpm and built it on the system. Once I did that the Megatunix compile went just fine.
Jaguar E-Types, modified Merkur XR4Ti, Jensen-Healey
Linux = no virii or spyware, EVER
- MS/Extra Guru
Re: had to upgrade glib to install 0.9.22
Which file was it blocking on? I don't necessarily want to have to force a dep on glib 2.16StevenD57 wrote:Just an FYI, I was installing Megatunix 0.9.22 from source on a laptop running OpenSuSE-10.3 and at the end of the compile it stopp with an error for an undefined reference to g_strcmp0. After research a while I found that this function is only available in glib from version 2.16 and up. Naturally the 10.3 version of OpenSuSE only had version 2.14. I ended up downloaded a src rpm and built it on the system. Once I did that the Megatunix compile went just fine.
David J. Andruczyk
