Megatunix Crashing
Moderator: djandruczyk
Megatunix Crashing
I am running MegaTunix 0.9.22 on a Windows XP Professional machine connected to an MS1 running 029y4. Whenever I attempt to collect data with the data logging feature, the program crashes.
I have attached the crash report. It is not formatted very well. I am sorry for this, but this is what I got from cut and paste of the text. If there is a way to get this file to the forum in a better format, please let me know. Of course, I don't even know if this file is useful.
Any assistance would be greatly appreciated.
Thanks,
Jim
Thanks,
Jim
- MS/Extra Guru
Re: Megatunix Crashing
Windows's crash reports are useless to me. Please describe the EXACT sequence of events needed to re-create the crash.cewjim wrote:I am running MegaTunix 0.9.22 on a Windows XP Professional machine connected to an MS1 running 029y4. Whenever I attempt to collect data with the data logging feature, the program crashes.
Thanks,
Jim
David J. Andruczyk
Dave,
I thought the crash report might be useless, but I thought I would give it a shot anyhow.
Here is the sequence of events:
Boot computer
Key on vehicle
Open Megatunix and wait for "Ready ..."
Click DataLogging
Click Select Log File and click Save accepting default
***Note: Default values here were MegaSquirtnSpark-Extra_029yx-2010_09_20_0852.log in MTX_Datalogs dir
Click Start Custom Logging
Receive "Megatunix Software has encountered a problem ..." dialog
With the same process, but clicking the Write Internal Log to Disk button will produce the same result.
Also, I noted that after selecting the log file the message in the window will show messages regarding 250 samples logged, 500 samples logged, etc... It isn't until I select "Start Custom Logging" or "Write Internal Log to Disk" button that I encounter a problem.
Computer information:
Windows XP
Professional
Version 2002
Service Pack 3
Mobile Intel Pentium
4 - M CPU 1.80GHz
1.18GHz, 512 MB of RAM
I would be happy to provide any other information you might require.
Have a great day,
Jim Boughton
P.S. if you received an e-mail from me through sourceforge, I apologize. I came to this board, because when I sent the e-mail from sourceforge I selected "cc myself" but did not receive the e-mail. I wasn't sure if you received it or not, so rather than send it again, I found another avenue
Boot computer
Key on vehicle
Click DataLogging
Windows XP
Professional
Version 2002
Service Pack 3
4 - M CPU 1.80GHz
Have a great day,
Jim Boughton
- MS/Extra Guru
So far I can't duplicate this on linux, so I'll have to keep digging. does it crash with any other firmware?, how about if you de-select all logable variables and only try to log a couple of them? (odds are it's one or two bad ones causing the issue).
David J. Andruczyk
I attempted only logging RPM and received the same problem. Subsequently, I tried only logging Engine Bits and received the same problem, again.
I have not tried other firmware, but I will as soon as I have time.
Have a great day,
Jim
Have a great day,
Jim
- MS/Extra Guru
thx for testing. I'll see if I can look into this shortly. My branch i'm working on is REALLY broken right now....cewjim wrote:I attempted only logging RPM and received the same problem. Subsequently, I tried only logging Engine Bits and received the same problem, again.
Have a great day,
Jim
David J. Andruczyk
Dave,
I tried MegaTunix with the MSExtra HiRes HR_11d firmware. This brought about a new problem - MegaTunix doesn't recognize the HR_11d firmware. I saw this file:
~\MegaTunix\dist\Interrogator\Profiles\SquirtnSpark-Extra-HR-011d.prof
so I figured it should recognize it, but it gave an error regarding incompatible firmware (sorry didn't write down the error) and requested I send you this file:
~\MegaTunix\MTXlog.txt
I did not attach this file because it is empty (I had figured this file would contain the info regarding the above mentioned error that I didn't write down :-O)
Also, during the shutdown of MegaTunix there was a dialog regarding writing the internal log file to disk. I selected yes, and got the Microsoft error dialog again.
The empty MTXlog.txt file may be a clue though, since I have files in the MTX_Datalogs directory, from trying to log data, which are also empty. It seems like there is some kind of error with writing to the disk on this machine/OS (I am no expert, however).
Anyhow, sorry to bring up more problems. Maybe I will just resurrect my Linux machine for this.
Have a great day,
Jim
Have a great day,
Jim
- MS/Extra Guru
Linux makes it a LOT easier to test, as the debugging tools and such for windows are terrible.cewjim wrote:Dave,
Have a great day,
Jim
I've gotten my development tree (in git) stabilized, so if you have access to a linux box, or Linux VM it would be ideal.
David J. Andruczyk
