Code: Select all
Delivery to the following recipient failed permanently:
extace@users.sourceforge.net
Technical details of permanent failure:
Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about the cause of this error. The error that the other server returned was: 550 550 unknown user (state 14).
Code: Select all
Program received signal SIGSEGV, Segmentation fault.
0x0000000000444f07 in free_tests_array ()
(gdb) backtrace
#0 0x0000000000444f07 in free_tests_array ()
#1 0x000000000045b775 in set_offline_mode ()
#2 0x000000343783c4cb in g_timeout_dispatch (source=<value optimized out>, callback=<value optimized out>, user_data=<value optimized out>)
at gmain.c:3396
#3 0x000000343783bd02 in g_main_dispatch (context=0x7cf550) at gmain.c:1960
#4 IA__g_main_context_dispatch (context=0x7cf550) at gmain.c:2513
#5 0x000000343783fae8 in g_main_context_iterate (context=0x7cf550, block=1, dispatch=1, self=<value optimized out>) at gmain.c:2591
#6 0x000000343783fff5 in IA__g_main_loop_run (loop=0x9498d0) at gmain.c:2799
#7 0x00000034401493c7 in IA__gtk_main () at gtkmain.c:1219
#8 0x0000000000450534 in main ()
(gdb)
Andy
