segmentation fault
Moderator: djandruczyk
segmentation fault
Just installed megatunix and keep getting a segmentation fault
Starting program: /Users/mattjohnson/Documents/megatunix-0.9.22/src/megatunix --g-fatal-warnings
Reading symbols for shared libraries .. done
Xlib: extension "RANDR" missing on display "/tmp/launch-BCsCjg/:0".
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_INVALID_ADDRESS at address: 0x0000000001ebb8a0
0x00000001008bb2e7 in gdk_gc_set_colormap ()
(gdb) backtrace
#0 0x00000001008bb2e7 in gdk_gc_set_colormap ()
#1 0x000000010009848f in mtx_gauge_face_configure (widget=0x101ed0140, event=0x101f28910) at gauge-private.c:633
#2 0x00000001004dfb2f in _gtk_marshal_BOOLEAN__BOXED ()
#3 0x0000000100f8d8d2 in g_closure_invoke ()
#4 0x0000000100fa33bc in signal_emit_unlocked_R ()
#5 0x0000000100fa4936 in g_signal_emit_valist ()
#6 0x0000000100fa5034 in g_signal_emit ()
#7 0x00000001005f71ae in gtk_widget_event_internal ()
#8 0x000000010045f904 in gtk_drawing_area_send_configure ()
#9 0x000000010045fa1d in gtk_drawing_area_realize ()
#10 0x0000000100f8d8d2 in g_closure_invoke ()
#11 0x0000000100fa2f0e in signal_emit_unlocked_R ()
#12 0x0000000100fa4c64 in g_signal_emit_valist ()
#13 0x0000000100fa5034 in g_signal_emit ()
#14 0x00000001005fd6e7 in gtk_widget_realize ()
#15 0x00000001005fdf48 in gtk_widget_map ()
#16 0x0000000100f8d8d2 in g_closure_invoke ()
#17 0x0000000100fa2f0e in signal_emit_unlocked_R ()
#18 0x0000000100fa4c64 in g_signal_emit_valist ()
#19 0x0000000100fa5034 in g_signal_emit ()
#20 0x00000001005fe6c6 in gtk_widget_show ()
#21 0x000000010049c77b in gtk_frame_forall ()
#22 0x000000010045b4e3 in gtk_container_show_all ()
#23 0x00000001004290bb in gtk_box_forall ()
#24 0x000000010045b4e3 in gtk_container_show_all ()
#25 0x00000001004290bb in gtk_box_forall ()
#26 0x000000010045b4e3 in gtk_container_show_all ()
#27 0x00000001004fba46 in gtk_notebook_forall ()
#28 0x000000010045b4e3 in gtk_container_show_all ()
#29 0x000000010045b4e3 in gtk_container_show_all ()
#30 0x000000010053d643 in gtk_scrolled_window_forall ()
#31 0x000000010045b4e3 in gtk_container_show_all ()
#32 0x00000001004290bb in gtk_box_forall ()
#33 0x000000010045b4e3 in gtk_container_show_all ()
#34 0x000000010049c77b in gtk_frame_forall ()
#35 0x000000010045b4e3 in gtk_container_show_all ()
#36 0x0000000100066386 in load_gui_tabs_pf () at tabloader.c:168
#37 0x0000000100023e11 in pf_dispatcher (data=0x0) at dispatcher.c:146
#38 0x000000010101105d in g_timeout_dispatch ()
#39 0x00000001010108e9 in g_main_context_dispatch ()
#40 0x0000000101013f81 in g_main_context_iterate ()
#41 0x0000000101014295 in g_main_loop_run ()
#42 0x00000001004d9cf0 in gtk_main ()
#43 0x0000000100047822 in main (argc=1, argv=0x7fff5fbff910) at main.c:144
(gdb) run
The program being debugged has been started already.
Start it from the beginning? (y or n) y
Reason: KERN_INVALID_ADDRESS at address: 0x00000000018b99e0
(gdb) backtrace
#1 0x000000010009848f in mtx_gauge_face_configure (widget=0x10298c1c0, event=0x1028f9d60) at gauge-private.c:633
#16 0x000000010049c77b in gtk_frame_forall ()
#17 0x000000010045b3a7 in gtk_container_map ()
#18 0x0000000100f8d9af in g_closure_invoke ()
#19 0x0000000100fa2f0e in signal_emit_unlocked_R ()
#20 0x0000000100fa4c64 in g_signal_emit_valist ()
#21 0x0000000100fa5034 in g_signal_emit ()
#22 0x00000001005fdf1e in gtk_widget_map ()
#24 0x000000010045b3a7 in gtk_container_map ()
#25 0x0000000100f8d9af in g_closure_invoke ()
#26 0x0000000100fa2f0e in signal_emit_unlocked_R ()
#27 0x0000000100fa4c64 in g_signal_emit_valist ()
#28 0x0000000100fa5034 in g_signal_emit ()
#29 0x00000001005fdf1e in gtk_widget_map ()
#30 0x00000001004290bb in gtk_box_forall ()
#31 0x000000010045b3a7 in gtk_container_map ()
#32 0x0000000100f8d9af in g_closure_invoke ()
#33 0x0000000100fa2f0e in signal_emit_unlocked_R ()
#34 0x0000000100fa4c64 in g_signal_emit_valist ()
#35 0x0000000100fa5034 in g_signal_emit ()
#36 0x00000001005fdf1e in gtk_widget_map ()
#37 0x000000010045b3a7 in gtk_container_map ()
#38 0x0000000100f8d9af in g_closure_invoke ()
#39 0x0000000100fa2f0e in signal_emit_unlocked_R ()
#40 0x0000000100fa4c64 in g_signal_emit_valist ()
#41 0x0000000100fa5034 in g_signal_emit ()
#42 0x00000001005fdf1e in gtk_widget_map ()
#43 0x000000010053d643 in gtk_scrolled_window_forall ()
#44 0x000000010045b3a7 in gtk_container_map ()
#45 0x0000000100f8d9af in g_closure_invoke ()
#46 0x0000000100fa2f0e in signal_emit_unlocked_R ()
#47 0x0000000100fa4c64 in g_signal_emit_valist ()
#48 0x0000000100fa5034 in g_signal_emit ()
#49 0x00000001005fdf1e in gtk_widget_map ()
#50 0x00000001004290bb in gtk_box_forall ()
#51 0x000000010045b3a7 in gtk_container_map ()
#52 0x0000000100f8d9af in g_closure_invoke ()
#53 0x0000000100fa2f0e in signal_emit_unlocked_R ()
#54 0x0000000100fa4c64 in g_signal_emit_valist ()
#55 0x0000000100fa5034 in g_signal_emit ()
#56 0x00000001005fdf1e in gtk_widget_map ()
#57 0x000000010049c77b in gtk_frame_forall ()
#58 0x000000010045b3a7 in gtk_container_map ()
#59 0x0000000100f8d8d2 in g_closure_invoke ()
#60 0x0000000100fa2f0e in signal_emit_unlocked_R ()
#61 0x0000000100fa4c64 in g_signal_emit_valist ()
#62 0x0000000100fa5034 in g_signal_emit ()
#63 0x00000001005fdf1e in gtk_widget_map ()
#64 0x00000001005fe05b in gtk_widget_set_child_visible ()
#65 0x00000001004fe566 in gtk_notebook_real_switch_page ()
#66 0x0000000100f8d8d2 in g_closure_invoke ()
#67 0x0000000100fa33bc in signal_emit_unlocked_R ()
#68 0x0000000100fa4c64 in g_signal_emit_valist ()
#69 0x0000000100fa5034 in g_signal_emit ()
#70 0x000000010050109b in gtk_notebook_button_press ()
#71 0x00000001004dfb2f in _gtk_marshal_BOOLEAN__BOXED ()
#72 0x0000000100f8d8d2 in g_closure_invoke ()
#73 0x0000000100fa33bc in signal_emit_unlocked_R ()
#74 0x0000000100fa4936 in g_signal_emit_valist ()
#75 0x0000000100fa5034 in g_signal_emit ()
#76 0x00000001005f71ae in gtk_widget_event_internal ()
#77 0x00000001004d8647 in gtk_propagate_event ()
#78 0x00000001004d9916 in gtk_main_do_event ()
#79 0x00000001008f1594 in gdk_event_dispatch ()
#80 0x00000001010108e9 in g_main_context_dispatch ()
#81 0x0000000101013f81 in g_main_context_iterate ()
#82 0x0000000101014295 in g_main_loop_run ()
#83 0x00000001004d9cf0 in gtk_main ()
#84 0x0000000100047822 in main (argc=1, argv=0x7fff5fbff910) at main.c:144
(gdb)
(gdb) backtrace
(gdb) run
(gdb) backtrace
(gdb)
- MS/Extra Guru
Re: segmentation fault
mjohnson575 wrote:Just installed megatunix and keep getting a segmentation fault
0.9.22 is old, retry with 0.9.23
traces are only good if you configured megatunix with "--enable-debug".
David J. Andruczyk
Thanks. Don't know how or why it downloaded 9.22
- MS/Extra Guru
Did 0.9.23 solve the issue?
David J. Andruczyk
No. I even got 9.24 and still get segfault. Could it be that I don't have the ecu hooked up?
- MS/Extra Guru
Are you choosing offline mode? which family and firmware did you choose?mjohnson575 wrote:No. I even got 9.24 and still get segfault. Could it be that I don't have the ecu hooked up?
0.9.24 is highly developmental, and only available via git. If you're going to use that YOU MUST compile it with debugging symbols (./configure --enable-debug ; make clean ; make ; sudo make install), and provide backtraces AS WELL AS CONTEXT to the crash. (i.e. where/when it does it, what was happening, what EXACT firmware you have on your ECU, and so on.
A non-debug build doesn't tell me anything in a backtrace, whereas a debug build will usually give me line numbers and a place to hone right in on.
David J. Andruczyk
Yes I choose offline mode. Im using ms1 029y4 I think that's right. Im going to try and load 9.23 here in a few minutes. Happy new year
- MS/Extra Guru
mjohnson575 wrote:Yes I choose offline mode. Im using ms1 029y4 I think that's right. Im going to try and load 9.23 here in a few minutes. Happy new year
OK, offline mode has several issues in the released versions. I'llsee if i can accelerate the release schedule for 0.9.24
David J. Andruczyk
Thanks! Got it working last night in offline mode. Even got guagedesigner to work. Thanks for the support.
