woza wrote:djandruczyk wrote:Woza: excellent report. I had a few minutes and revamped that routine to use "current" GTK/GDK calls, as GTK+ has been gradually transitioning to cairo for the backend rendering, and there's still places wihin Mtx that use the legacy api's which have started to become deprecated with the latests GTK+ editions available on macports/fink.
It SHOULD work now for at least that section, but I suspect it either may not render anything or may flicker badly, I have my mac with me, but no MS hardware, so I can't test it for a while, but would appreaciate your detailed results on if it works or not, how it renders (if it does), its general behavior and so on, and I'l try to tweak it as needed..
Thanks again!Code: Select all
git pull
Code: Select all
Already up-to-date
Please try again, the push failed initially and I missed it. its in there now.
