Some settings not being saved / read correctly (FIXED!)
Moderator: djandruczyk
Hi. MT isn't saving my temperature setting of Celsius - it keeps reverting to Fahrenheit. Secondly, it isn't saving the fuel parameters. Keeps reverting to 1 cylinder, 1 injector and 12 squirts per cycle. I have flashed the correct parmeters with Megatune and verified they are burned correctly but MT still thinks they are the default settings. I haven't found any other settings that don't save so far.
Running latest git (0.4-modular) on OS X
- MS/Extra Guru
Re: Some settings not being saved / read correctly
what firmware EXACTLY? I don't see this behavior on my end with ms2-e 3.1woza wrote:Hi. MT isn't saving my temperature setting of Celsius - it keeps reverting to Fahrenheit. Secondly, it isn't saving the fuel parameters. Keeps reverting to 1 cylinder, 1 injector and 12 squirts per cycle. I have flashed the correct parmeters with Megatune and verified they are burned correctly but MT still thinks they are the default settings. I haven't found any other settings that don't save so far.
David J. Andruczyk
Sorry, should have said...
mtxloader...
mtxloader...
Code: Select all
Detected signature: "MS/Extra format hr_10 **********"
- MS/Extra Guru
woza wrote:Sorry, should have said...
mtxloader...Code: Select all
That's not exact. use megatunix and show me what's in the text VERSION field. the signature can be the same for multiple "compatible" firmware releases....
David J. Andruczyk
MS/Extra hr_10g ****************
I am having this same exact issue with the "1 cylinder, 1 injector, and 12 squirts of fuel per cycle" on a MS1 system running MS/Extra 029y4 with the Megatunix modular_0.4 code tree. Hopefully Dave is looking into this problem.woza wrote:Hi. MT isn't saving my temperature setting of Celsius - it keeps reverting to Fahrenheit. Secondly, it isn't saving the fuel parameters. Keeps reverting to 1 cylinder, 1 injector and 12 squirts per cycle. I have flashed the correct parmeters with Megatune and verified they are burned correctly but MT still thinks they are the default settings. I haven't found any other settings that don't save so far.
Jaguar E-Types, modified Merkur XR4Ti, Jensen-Healey
Linux = no virii or spyware, EVER
- MS/Extra Guru
StevenD57 wrote:I am having this same exact issue with the "1 cylinder, 1 injector, and 12 squirts of fuel per cycle" on a MS1 system running MS/Extra 029y4 with the Megatunix modular_0.4 code tree. Hopefully Dave is looking into this problem.woza wrote:Hi. MT isn't saving my temperature setting of Celsius - it keeps reverting to Fahrenheit. Secondly, it isn't saving the fuel parameters. Keeps reverting to 1 cylinder, 1 injector and 12 squirts per cycle. I have flashed the correct parmeters with Megatune and verified they are burned correctly but MT still thinks they are the default settings. I haven't found any other settings that don't save so far.
I have FIXED this issue, and is in the modular_0.4 push from 2/20/2011 16:50 EST. the bug was due to an API change that wasn't fully propagated through the code (i.e. coder error)
All controls that used "complex" math expressions (which isn't too many), were affected.
David J. Andruczyk
All controls that used "complex" math expressions (which isn't too many), were affected.[/quote]
Thanks Dave! I will give it a try later today or tomorrow.
This has fixed the fuel params page but still not saving my temp setting. Defaults to fahrenheit all the time...
- MS/Extra Guru
woza wrote:This has fixed the fuel params page but still not saving my temp setting. Defaults to fahrenheit all the time...
Just fixed that too, 17:48 EST
NOTE: may take one full load/save routine before it takes full effect, you may see output in console about "BUG couldn't figure out temp conversion!" Those should go away after a close/reopen.
David J. Andruczyk
Yes and yes! Fixed. Thanks Dave...
Yep, it filled Terminal like "War & Peace" first time and then it went away next time, as you said!djandruczyk wrote: you may see output in console about "BUG couldn't figure out temp conversion!"
Yamaha YZF1000 MSExtra 3.1
I am still getting this output everytime I run Megatunix. Is that normal or should it have gone away?djandruczyk wrote:Just fixed that too, 17:48 EST
- MS/Extra Guru
It should have gone away. Try changing the temp scale in megatunix (General Tab) to something else and back and then closing and reopening megatunix and see if it goes away.StevenD57 wrote:I am still getting this output everytime I run Megatunix. Is that normal or should it have gone away?djandruczyk wrote:Just fixed that too, 17:48 EST
David J. Andruczyk
