Kubuntu 10.10 won't come up in a graphical (KDE) menu as a VMWare virtual machine on my Mandriva system (I couldn't get it to compile since the 'configure' script couldn't tell I had libglade2.0 installed). Got a basic X-Window and Megatunix *finally* started but couldn't get it to recognize the USB/serial converter that worked so well for the XP virtual machine. <sigh>
checking for LIBGLADE... configure: error: Package requirements (libglade2.0 ) were not met:
No package 'libglade2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables LIBGLADE_CFLAGS
and LIBGLADE_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
[lll4386@louielouie megatunix-0.9.23]$ rpm -qa |grep -i libglade <-- query the package manager for any occurrence of libglade
libglade2.0_0-2.6.4-3mdv2010.1 <-- so it IS installed but not recognized
I had tried hacking the 'configure' script to no avail:
[lll4386@louielouie megatunix-0.9.23]$ diff configure configure~
16587,16588c16587,16588
< { { $as_echo "$as_me:${as_lineno-$LINENO}: \$PKG_CONFIG --exists --print-errors \"libglade2.0 \""; } >&5
< ($PKG_CONFIG --exists --print-errors "libglade2.0 ") 2>&5
> { { $as_echo "$as_me:${as_lineno-$LINENO}: \$PKG_CONFIG --exists --print-errors \"libglade2.0_0 \""; } >&5
> ($PKG_CONFIG --exists --print-errors "libglade2.0_0 ") 2>&5
16592c16592
< pkg_cv_LIBGLADE_CFLAGS=`$PKG_CONFIG --cflags "libglade2.0 " 2>/dev/null`
> pkg_cv_LIBGLADE_CFLAGS=`$PKG_CONFIG --cflags "libglade2.0_0 " 2>/dev/null`
16605,16606c16605,16606
16610c16610
< pkg_cv_LIBGLADE_LIBS=`$PKG_CONFIG --libs "libglade2.0 " 2>/dev/null`
> pkg_cv_LIBGLADE_LIBS=`$PKG_CONFIG --libs "libglade2.0_0 " 2>/dev/null`
16629c16629
< LIBGLADE_PKG_ERRORS=`$PKG_CONFIG --short-errors --errors-to-stdout --print-errors "libglade2.0 "`
> LIBGLADE_PKG_ERRORS=`$PKG_CONFIG --short-errors --errors-to-stdout --print-errors "libglade2.0_0 "`
16631c16631
< LIBGLADE_PKG_ERRORS=`$PKG_CONFIG --errors-to-stdout --print-errors "libglade2.0 "`
> LIBGLADE_PKG_ERRORS=`$PKG_CONFIG --errors-to-stdout --print-errors "libglade2.0_0 "`
16636c16636
< as_fn_error "Package requirements (libglade2.0 ) were not met:
> as_fn_error "Package requirements (libglade2.0_0 ) were not met:
Libglade is a 32-bit package and if I need the -devel package it is incompatible with my x86_64 platform - what do I do next? TIA!
-LouieLouie
No compile on Mandriva & Kunbuntu is a sucky VM
Moderator: djandruczyk
- MS/Extra Guru
Re: No compile on Mandriva & Kunbuntu is a sucky VM
louielouie wrote:Kubuntu 10.10 won't come up in a graphical (KDE) menu as a VMWare virtual machine on my Mandriva system (I couldn't get it to compile since the 'configure' script couldn't tell I had libglade2.0 installed). Got a basic X-Window and Megatunix *finally* started but couldn't get it to recognize the USB/serial converter that worked so well for the XP virtual machine. <sigh>
16592c16592
16610c16610
16629c16629
16631c16631
16636c16636
-LouieLouie
Specify --arch=i386 to the yum command line.
You might have libglade installed, but you do NOT have the DEVELOPMENT HEADERS installed (i.e. search for a package name that includes "dev" or "headers" in it. To compile an application agaisnt a particular library it needs the header files that correspond to that library, and you don't have them installed.
Unless you have more than 4GB of ram, and need individual applications to be able to address all of it at once, or are hosting VM's via a high end hypervistor (KVM/Xen) a 64 bit OS makes little to no sense, and you would be better off with a 32 bit version as it has much wider compatibility, esp with commercial closed source stuff like flash and java.
David J. Andruczyk
Thank you - I found a 32-bit Kubuntu 10.10 VM on vmplanet.net and followed the directions for installation. I did have to additionally install the libdtxm* packages but as it turns out, support for my mosChip 7703 serial/USB converter isn't in Ubuntu so MegaTunix couldn't find my device (that's still a +1 for installation success though). mosChip indicated it was supported under Fedora Core so I'll try some other 32-bit VM and possibly see if I can find a supported serial/USB converter for Ubuntu.
Curious--- What's the purpose for running Ubuntu in a VM?
I've been running megatunix (git) on Mandriva for awhile. Builds /works fine.
Once ALL the dev packages are installed there is no issue, just like Ubuntu.
(do make sure to rerun autogen.sh though, or configure will not be regenerated properly)
