Is megatunix for me?
Moderator: djandruczyk
Can megatunix control stepper idle? and control all the extra input/output that I am controlling right now with TS. I will love to test Megatunix but so far I am not sure if it wil work for my applicaton I am currently runnin ms2 extra 3.1."2" for and eclipse 420a waste spark, stepper idle, fast idle for fan control and the fuel pump relay activation.
Re: Is megatunix for me?
Curious setup......fast idle for fan control and the fuel pump relay activation
Your fan runs anytime the fp is activated? Or did i read that wrong?
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
- MS/Extra Guru
juansh2385 wrote:Can megatunix control stepper idle? and control all the extra input/output that I am controlling right now with TS. I will love to test Megatunix but so far I am not sure if it wil work for my applicaton I am currently runnin ms2 extra 3.1."2" for and eclipse 420a waste spark, stepper idle, fast idle for fan control and the fuel pump relay activation.
Megatunix can support pretty much all features of the ECU. NOTE: a dev version is currently required for ms2-E 3.x
David J. Andruczyk
you read wrong my fans run in the fast idel output after a certain coolant temp and above a certain rpm What I try to say was that I was using a 4 wire stepper idle wich takes the the iac 1and iac 2 also fast idle output was for fan control and that I have another output for fuel pump But i havent seen in megatunix where to configure the outputs or where to tune a 4 wire stepper idlekjones6039 wrote:Curious setup......fast idle for fan control and the fuel pump relay activation
djandruczyk wrote:juansh2385 wrote:Can megatunix control stepper idle? and control all the extra input/output that I am controlling right now with TS. I will love to test Megatunix but so far I am not sure if it wil work for my applicaton I am currently runnin ms2 extra 3.1."2" for and eclipse 420a waste spark, stepper idle, fast idle for fan control and the fuel pump relay activation.
can you elaborate what would I need and thanks in advance
- MS/Extra Guru
juansh2385 wrote:djandruczyk wrote:juansh2385 wrote:Can megatunix control stepper idle? and control all the extra input/output that I am controlling right now with TS. I will love to test Megatunix but so far I am not sure if it wil work for my applicaton I am currently runnin ms2 extra 3.1."2" for and eclipse 420a waste spark, stepper idle, fast idle for fan control and the fuel pump relay activation.
Currently for ms2-e 3.x support, you'd need to run a developmental version. If you're on a mac/linux, you can just compile it from a git checkout. If you're on windows you can request a pre-release from me (might be buggy or crash), since it's still a developmental version.
David J. Andruczyk
OK i have both windows 7 and mac os x snow leopard wich one do yo recommend more and where do i get them?
- MS/Extra Guru
Like I said for 3.1.x for windows requires a DEVELOPMENTAL version built by me. For mac, you need to follow the "installing on OS-X" thread which is a little involved, due to the required pre-requisites, the benefit being once it's setup its quick to get to the latest version. It does require some familiarity with the terminal as there are several manual steps involved.juansh2385 wrote:OK i have both windows 7 and mac os x snow leopard wich one do yo recommend more and where do i get them?
David J. Andruczyk
thanks for the info I'll give it a try even down I am kinda new to mac os x and terminal etc
I'm running OSX 10.6.7 and MegaTunix from git with MSExtra 3.1.0, no issues using Linux Mint either with Parallels 6 software in emulation mode either platform.
As long as you follow the later instructions you'll be fine.
Yamaha YZF1000 MSExtra 3.1
