MegaTunix + MSTweak3000
Moderator: djandruczyk
Hey, i need a little help, is there a way to get he megatunix log to load in mstweak, ive tried everything, i have a rough map, and did a 1 hour long log i would like to use but mstweak just doesnt seem to like the megatunix logs.
this is my log
https://docs.google.com/leaf?id=0BxvpXT ... 1&hl=en_GB
this is my log
- MS/Extra Guru
Re: MegaTunix + MSTweak3000
If MStweak3000 can take a CSV log it should work. IT might be confused by the comment at the beginning, so try removing the first line.josephdouce wrote:Hey, i need a little help, is there a way to get he megatunix log to load in mstweak, ive tried everything, i have a rough map, and did a 1 hour long log i would like to use but mstweak just doesnt seem to like the megatunix logs.
this is my log
David J. Andruczyk
Still cant get it to work :S
Its available here, Its referred to in megamanual but there doesn't seem to be any forum any more.
http://www.megamanual.com/files/software/MST3000.zip
- MS/Extra Guru
As far as i remember MSTweak3K was designed to work with the REALLY old megatune xls style logs, which were in excel format. So if you take a mtx log, remove the first line that has the comment, renamed it to log.csv, load it in excel or open/libreoffice and save it in xls format, that tool MIGHT open it.josephdouce wrote:Still cant get it to work :S
You could also try OpenLogViewer which is in development, or MLV, but that is pay-for-ware, and I don't havethe ability to test mtxlogs on it for compatibility.
MTX DOES have a crummy log playback tool (logviewer tab), but it doesn't to table analysis yet, and its slated for re-implementation to be less terrible at some point.
David J. Andruczyk
Why are you unable to use it?djandruczyk wrote:MLV, but that is pay-for-ware, and I don't havethe ability to test mtxlogs on it for compatibility.
- MS/Extra Guru
Because I don't have it, and the crippleware version sits and hangs for upwards of 5 minutes or longer before its usable...jsmcortina wrote:Why are you unable to use it?djandruczyk wrote:MLV, but that is pay-for-ware, and I don't havethe ability to test mtxlogs on it for compatibility.
David J. Andruczyk
Current beta version is announced as nag-free.
