Most of the online fun happened before the split to msextra from msefi, so the majority of the censorship comes from the lovely "ForumAdminTeam" on msefi.jsmcortina wrote:Evidence?djandruczyk wrote: as evidenced to many comments... (though most of them have since been removed/edited away)
We apply a very strict NON-DELETION and NON-CENSORSHIP policy here. Stuff is only removed in extreme circumstances.
Evidence?even most of the documentation that previously mentioned mtx has since edited me out)
I haven't to my knowledge done this and I've done most of the doc work in the last few years.
help new to megatunix
Moderator: djandruczyk
- MS/Extra Guru
Re: help new to megatunix
David J. Andruczyk
So that's stuff that happened 5 years ago then?
- MS/Extra Guru
No, I had a corresponding subforum on msefi until last year, However my subforum was completely deleted AGAINST MY WISHES on msefi. They're excellent at erasing history over there to suit what they want to believe....jsmcortina wrote:So that's stuff that happened 5 years ago then?
David J. Andruczyk
Did you find everything you need? I posted the url but any way with a normal 3.1.1 firmware file you only have to change the .s19 and the inin. definition from the one on the files to the ones i posted here. What do you think.
Juan
Juan
- MS/Extra Guru
I am working on it....juansh2385 wrote:Did you find everything you need? I posted the url but any way with a normal 3.1.1 firmware file you only have to change the .s19 and the inin. definition from the one on the files to the ones i posted here. What do you think.
Juan
David J. Andruczyk
Thanks a lot I am not in a hurry i was just asking in case I missed something. One question in megatunix the data that I enter let say in the pid Is going to be bound to the limits in the .19 and inin def.? If so I think is worth mentioning that maxing out the D term value to 6500 aparently have give good results and I would like to test this as well I am goin to post the inin with the modified values on max D in case they are need it.djandruczyk wrote:I am working on it....juansh2385 wrote:Did you find everything you need? I posted the url but any way with a normal 3.1.1 firmware file you only have to change the .s19 and the inin. definition from the one on the files to the ones i posted here. What do you think.
Juan
Thanks again
Juan
- MS/Extra Guru
Megatunix is configured to use the same limits as defined by the .ini.juansh2385 wrote:Thanks a lot I am not in a hurry i was just asking in case I missed something. One question in megatunix the data that I enter let say in the pid Is going to be bound to the limits in the .19 and inin def.? If so I think is worth mentioning that maxing out the D term value to 6500 aparently have give good results and I would like to test this as well I am goin to post the inin with the modified values on max D in case they are need it.djandruczyk wrote:I am working on it....juansh2385 wrote:Did you find everything you need? I posted the url but any way with a normal 3.1.1 firmware file you only have to change the .s19 and the inin. definition from the one on the files to the ones i posted here. What do you think.
Juan
Thanks again
Juan
David J. Andruczyk
In that case please use the limits specify in the las .inin. that I posted if is not too much of a bother as it has been reported to work better
Juan
BTW I am planing to install dev tools for megatunix and the one posted for .inin. definitions in the same linux ubuntu I hope they dont cause problem. My goal is to be able to change at least small stuff like limits defined in .ini. in both the megatunix plataform or ts I want to learn how the programs work etc. All this is really interesting to me
Juan
- MS/Extra Guru
juansh2385 wrote:In that case please use the limits specify in the las .inin. that I posted if is not too much of a bother as it has been reported to work better
Juan
git master now has support for 3.1.1_17. This support is alpha and several things are not expected to work perfectly, please thoroughly test and report. BE SPECIFIC, use comparison screenshots vs Tunerstudio. please post them on an image hosting service like imgur.com.
NOTE: Some tabs are slow to render, be patient if you have an older system.
David J. Andruczyk
great you'll hear from me soon The car is not with me right now as I am on a trip but I can not wait to test this out
So i try the code it started the car but run into some trouble there where missing "tabs" in the idle control setting wich did not let me control the idle valve correctly. For the moment I went back to Tunners studio But i am really interest in running megatunix. I know you ask for a more delailed trouble shooting but I am a little short of time and that is the only car i have. I will try again in a couple days and Hopefully i will be able to give you more detailed info thanks for the work so far.
Juan
Juan
- MS/Extra Guru
juansh2385 wrote:So i try the code it started the car but run into some trouble there where missing "tabs" in the idle control setting wich did not let me control the idle valve correctly. For the moment I went back to Tunners studio But i am really interest in running megatunix. I know you ask for a more delailed trouble shooting but I am a little short of time and that is the only car i have. I will try again in a couple days and Hopefully i will be able to give you more detailed info thanks for the work so far.
Juan
You need to provide more context as to EXACTLY what is "missing". To the best of my knowledge all controls are implemented. did you check with the scrollbars to make sure the controls you're referrign to aren't scrolled offscreen (common on low res displays)
David J. Andruczyk
