MS2-Extra V3.1.*
Moderator: djandruczyk
MS2-Extra V3.1.*
Postby retired » Wed Jan 25, 2012 7:30 am
David,
Should MegaTunix work on V3.1.* (specifically 3.1.1)
On a Windows machine....
It's not entirely clear in your release notes but I've tried a borrowed MS2 and got this message
Prompting user for ECU family to interrogate...
Command "c" (MS-II Clock), returned 2 bytes
Command "A" (MS-I Runtime Vars), returned 169 bytes
Command "Q" (ECU Revision), returned 20 bytes (MS2Extra Serial310 )
Command "S" (ECU Signature), returned 60 bytes (MS2/Extra release 3.1.1 20110304 20:55GMT (c)KC/JSM/JB MS2)
Firmware NOT DETECTED, Enable Interrogation debugging, retry interrogation,
close megatunix, and send ~/MTXlog.txt to the author for analysis with a note
describing which firmware you are attempting to talk to.
I stick with 3.0.3y and its fine with Megatunix so I tried temporaraily upgrading it to 3.1.1 and get exactly the same message.
MTXlog file attached (that's from mine which is a 100% working MS2)
Thanks,
Rod.
Classic Mini "A" series 5 port 1360 turbo
MS2-E fully sequential siamese code
14point7 SLC widebands, inner and outer cylinders and after turbo
digital AFR data and digital displays via Tiny-IOx
retired
Re: MS2-Extra V3.1.*
Postby djandruczyk » Wed Jan 25, 2012 8:41 am
I admit I've been very lax with public releases lately. The DEVELOPMENT code does support 3.1.1 and the 3.1.1als (baldur/teknique) variant. The Windows side is still a bit flaky, due to architectural differences, and other items (and debugging under windows is a nightmare), but I can send you a development version if you are willing to submit bugreports/feedback on what works, what doesn't and what is incorrect compared to other tuning frontends (if you use them).
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby retired » Wed Jan 25, 2012 10:27 am
I'm perfectly happy to submit bugreports/feedback and comparisons to the other frontend, I would like to see yours work under windows and 3.1.1 if only to help someone out who uses 3.1.1 and in case I upgrade from 3.0.3y myself.
I prefer your front end (although it did take a while consructing a suitable set of guages) and the way it talks to the ECU rather than relying on an ini file.
You'll have to PM with how as I presume the file is too large to email.
retired
Postby jsmcortina » Wed Jan 25, 2012 10:30 am
Just a note that the only "current" release of MS2/Extra is 3.2.1
Postby djandruczyk » Wed Jan 25, 2012 11:21 am
jsmcortina wrote:Just a note that the only "current" release of MS2/Extra is 3.2.1
I'm actually working on 3.2.1 support. The changes aren't too major so supporting that only takes a little time and testing.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby techsalvager » Mon Jan 30, 2012 12:38 pm
I would also like a release for testing with 3.2.1 on windows
MS2extra
Mass Air Flow fuel and spark
Miata 1.6 turbo
TechSalvager is banned for ignoring admin warnings not to link to his childish videos.
techsalvager
Return to Megatunix (obsolete)
