Firmware not detected
Moderator: djandruczyk
Postby darrens » Tue Mar 27, 2012 10:28 am
Hello,
Hope you can help, after a not using the tuning s/w/car for awhile then HD failure and an outdated backup I decided to install linux and give Megatunix a go. All good, however Megatunix connects but is unable to detect the firmware revision.
I have attached the MTXlog for info, I have been away, car been in storage so its ages since I've used MS.
Thanks for your help
Regards
darrens
Re: Firmware not detected
Postby djandruczyk » Tue Mar 27, 2012 12:58 pm
darrens wrote:Hello,
Regards
You need to provide WHAT FIRMWARE you are running, as well as the OS and MegaTunix version or Git hash.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby darrens » Tue Mar 27, 2012 2:20 pm
Hi, thanks for the reply
Firmware MS2/Extra pre2.0 beta 20070818
Megatunix v0.9.23
Ubuntu 11.10
Regards
darrens
Postby djandruczyk » Tue Mar 27, 2012 7:31 pm
darrens wrote:Hi, thanks for the reply
Megatunix v0.9.23
Ubuntu 11.10
Regards
That's not a "mainstream" firmware, hence I never created support for it due to it being a non-general release edition.
Mtx has support for MS2-Extra 2.1.0, 2.1.0d, 2.1.0e, 3.0.3w, 3.0.3y, 3.0.x, 3.1.0, 3.1.1_17, 3.1.x.als, and 3.2.1 as of the latest Git revision.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby anonymous.shyster » Mon Nov 26, 2012 6:06 am
I'm having the same issue. I'm running Ubuntu and Megatunix with the latest git revision compiled today (26 November 2012).
Upgraded to MS2/Extra 3.2.4 today (which I assume went fine as there were no issues with the installer). When I went to run Megatunix, it gave the "could not find firmware" error. I can provide a log if that'd be helpful tomorrow...
anonymous.shyster
Postby djandruczyk » Mon Nov 26, 2012 5:14 pm
Support added for 3.2.4 into the latest Git push (hash 7fe51d776a11c6a293d75d9adeba3dab1b8de5e8)
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby anonymous.shyster » Tue Nov 27, 2012 1:51 am
Thanks!
anonymous.shyster
Return to Megatunix (obsolete)
